First post, by MSxyz
I've acquired a Kingston Turbochip 133 upgrade module. Basically it's just a small PCB with an Amd 5x86 in PQF package soldered and a couple of voltage regulators. Oh, there's also a small fan glued on top of it (yeah, glued) that gets the power directly for the CPU pins. It was marketed as a cheap plug-in upgrade for motherboards that supported only 5 Volt 486s. Old motherboards simply recognize it as a 486DX or DX2; sometimes even the speed reported by the BIOS is not correct. Cache seems to be locked in WT mode. Any software using CPUID will correctly report it as an Amd 5x86, though.
At any rate, I was wondering if it's possible to set it in 3x mode without heavily modding (ie. using a soldering iron) the PCB. Unless it's under the fan, I've not seen any jumper. Yet, I recall reading of people running those upgrade modules at 150Mhz by adjusting the multiplier. Although it is stable also at 160 MHz, I'd like to test it on a couple of ancient (late '91-early '92) motherboards in place of a 486DX-50. In one case, changing the bus clock is not even an option unless I use a different crystal.
