First post, by zwrr
I already own the SC-55, SC-55ST, and SC-88Pro, but I've always been bothered by the SC-55ST not having any display panel, I really like having a large and bright channel spectrum display.
Now I have the opportunity to get a SC-50, according to the information on the Internet, it is a SC-55MKII with the MT-32 ROM removed, and some people also say that the wavetable data of the SC-50 has been weakened and the accuracy of the samples has been reduced relative to the MKII.
I would like to hear some advice, between the SC-55ST and the SC-50, without considering the MT-32 compatibility, which one should I keep?
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
Reply 1 of 3, by Spikey
The SC-55ST is the SC-55mkII in terms of patches and polyphony but has the original SC-55 DAC, and lacks a screen.
The SC-50 is the SC-55mkII in terms of polyphony and DAC but lacks the MT-32 tones.
Both have the same wave ROM except for the 1MB MT-32 tones that the SC-50 lacks. The wavetable data is unchanged in SC-55mkII vs SC-50, literally the difference is the MT-32 tones (which IMHO are overrated).
I would definitely say the SC-50 is a better product in each way minus the MT-32 tones - audio (18-bit audio, better DAC), visual (screen).
If the MT-32 tones become important, then a mkII is needed. The SC-50/55mkII are the best SC-55's that exist with screens though (IMHO).
Reply 2 of 3, by EmperorGrieferus
Spikey wrote on 2024-09-11, 18:38:
The SC-55ST is the SC-55mkII in terms of patches and polyphony but has the original SC-55 DAC, and lacks a screen. The SC-50 is […]
SC-50 does have less samples compared to SC-55ST, being close in sound to the SC-7. It's especially evident in Descent level 1 soundtrack, because instead of using "proper" TR-808 cymbals, it uses standard SC-55 cymbals, albeit pitched down.
Reply 3 of 3, by EmperorGrieferus
zwrr wrote on 2024-08-24, 10:33:
SC-55ST for sure, because, as you and me said earlier, SC-50 has less samples in the wavetable compared to SC-55ST.
