The last X-Fi Support Pack 8.0 (Refresh 3) from daniel_k is the worst package, it is based on the Gigabyte X-Fi driver for its i […]
Joseph_Joestar wrote on 2024-10-18, 04:06:Out of curiosity, is this fix different from what DanielK did in his latest X-Fi driver pack? I know that Creative's official X-Fi driver had some bugs with OpenAL, and I was glad that they were not present with DanielK's drivers. That said, I never used EAX on anything newer than Windows 7. Are there additional issues with Win10/11?
The last X-Fi Support Pack 8.0 (Refresh 3) from daniel_k is the worst package, it is based on the Gigabyte X-Fi driver for its integrated sound... On the other hand, these are typical problems in daniel_k's drivers mod:
- Mode control on the remote unit does not work (Titanium Fatality).
- No microphone effects.
- "What U Hear" does not work if you do not install the Data file from win xp... but if you install it, you will lose WaveRT.
- The total harmonic distortion (THD) is off the charts.
- The branch 2.40.XX overload the DSP signal, which causes distortion at high frequencies and when using EAX filters (exaggerated reverb). All modified drivers of daniel_k based on that version have this issue.
The drivers modified by "Antes533" have another purpose; they have fixes and improvements, and these are their main advantages:
- The APO (responsible for rendering the sound) has been replaced with one of the highest quality; Scene depth, stereo and FX effects have been improved.
- The stability of the driver in general has been improved.
- Compatibility with the latest versions of Windows.
- 88.2kHz and 176kHz modes restored.
- Harmonic distortion has been improved.
- Being based on the official v2.17 drivers, these do not overload the DSP signal (unlike the 2.40) so the EAX effects are heard correctly without exaggerated reverberation.
- Other undocumented changes.
So it would be a kind of definitive drivers, saludos!
