First post, by dukeofurl
I recently replaced my CRT monitor with a new one. When jazz goes into the level, the game no longer takes up the entire screen. It also appears to be stretched out with some weird geometry. I'm running in Windows 98 but it was ok on my previous monitor.
The resolution is ok in the menus, and other games of a similar era seem to be ok. Does jazz use a weird resolution that maybe my new monitor doesn't know how to deal with?
Reply 1 of 14, by Tiido
From what I know, the game uses a tweaked resolution in-game which will appear as a new resolution to the monitor and thus there are no geometry presets for it unless something is set before which seems not to be the case.
Reply 2 of 14, by dukeofurl
Hmm I suppose it depends on my monitor, but I wonder if I can stretch, squeeze and adjust this thing to appropriately fill the screen, while not having it effect the display in other resolutions which already appear correctly. Will give it a shot tonight.
Reply 3 of 14, by jmarsh
It's not really a tweaked mode, it's 320x240 (@60Hz) with vertical blanking so only 200 lines are visible. It's normal for it to appear letterboxed.
Reply 4 of 14, by Jo22
Didn't Jazz have this 320x199 resolution thing going on to make it run in 60 Hz?
Because 200 line modes are 70 Hz by default (on VGA; CGA and EGA were all 60 Hz)?
Reply 5 of 14, by dukeofurl
I was able to adjust this via the monitor settings to fill the screen without ruining settings for other resolutions btw. I was just surprised by the screen here. I've played Jazz off and on since it came out on various monitors and don't remember it ever coming up this way by default.
Reply 6 of 14, by jmarsh
When you say "other resolutions", did you make sure to test 640x480 (since that's what the monitor would be seeing it as) ?
Reply 7 of 14, by dukeofurl
jmarsh wrote on 2024-11-12, 03:18:
Yes, that's exactly what I was worried about, but it seems ok when I try other 640x480 stuff.
Reply 8 of 14, by leileilol
The 60hz letterboxing is real. There's a few other games that do similar (like The Incredible Machine / Sid & Al's Incredible Toons)
Reply 9 of 14, by dukeofurl
Well how about that, heres a clip of jazz on my particular monitor around 20.10, with the letterboxing. The initial treatment of the game by my monitor was wrong but I guess full screen stretch is wrong too.
https://youtu.be/CaNDeyYP98A?si=CsHdhqAgPXDQxkiA
Reply 10 of 14, by clb
Here's what comes out from the digital Feature Connector when playing Jazz Jackrabbit on a Tseng ET4000/W32p adapter:
The attachment JAZZ.png is no longer available
Effectively the game is outputting 320x224 pixels (if one crops 4 pixels of black VGA border from all sides).
But overall, it is like a 320x240 60Hz Mode-x style geometry (i.e. square pixels), but with effectively only 320x199 pixels being actively rendered to. The rest at the bottom are held black.
Reply 11 of 14, by Azarien
dukeofurl wrote on 2024-11-11, 23:29:
I think part of the tweaked resolution is that the intended aspect ratio is 16:10 (-ish) so all the squares are square etc., and filling the whole 4:3 screen is not how the game should look like.
Reply 12 of 14, by DesktopDynamite
Hello, I stumbled on this post as I seem to have encountered same issue, mine seems fish eye geometry.
I am using the ARK 2000MT 2MB Video card on an AOC 7 VLR CRT on my recent Pentium MMX build. Other games run fine.
This issue only appears during the demos and actual gameplay, but not during game options and game credits.
Attached photos showing Jazz Jack rabbit during settings screen, demo and during gameplay.
Reply 13 of 14, by NeoG_
Access the OSD geometry controls and use the pincushion setting to remove the curved edges. I'm guessing the slightly strange display timing means the monitor is not applying the saved geometry settings by default and it needs to be adjusted manually.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 14 of 14, by DesktopDynamite
NeoG_ wrote on Yesterday, 05:11:
Ok thanks all for your support. Managed to adjust using the actual monitor pincussion settings, and also tweaked other settings to make the image large enough to fill the black borders. When reverted back to plain ms-dos prompt all was OK and visible.
