parabellum wrote on 2024-11-14, 13:38:
Progress!
just got two kmm5361003cg-7 sticks, installed it alongside 30 pin dimms, and IT POSTED
Remaining problems : keyboard does not work, wrong ram size - 8MB missing
Great result, but there is still something to fix.
For RAM, it is not said that there is a problem, sometimes in the 486, you have to find the right combination, maybe if you try a single RAM at 72 pin, you will see if it is read with the right capacity, sometimes and here you would need the manual, mixing banks of different capacity, it can give strange results, less memory is seen than the one actually available, maybe if you remove the 4 RAM at 30 pins it could read 16 MB (?)
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
