First post, by Harry Potter
Hi! I'm totally sorry about this, but this is new, and I can't figure this out myself. I have a laptop as stated in the subject, and I've been trying to install a new hard drive on it. I have one to install. I found the site https://mans.io/files/viewer/295754/23 which describes how to install the drive. It mentioned to pull a lever, but I can't find the lever. A few minutes ago, I looked inside the compartment mentioned and didn't recognize the connection. 🙁 I looked elsewhere but saw nowhere the drive can fit. Do I have the wrong directions? How do I do it?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 1 of 23, by BitWrangler
So you opened the compartment and there's an empty hole with a weird connector at the bottom? Sounds like you need a caddy, which is kinda unfortunate.
One guy who is an NEC expert on here is TheCreepingNet so maybe he will have ideas.
Reply 2 of 23, by MAZter
You need connector, or whole caddy. I think they are interchangeable with 4000 series:
The attachment Screenshot.png is no longer available
The attachment screen.jpg is no longer available
The attachment 2024-09-22 16.34.53.jpg is no longer available
The attachment 2024-09-22 16.34.46.jpg is no longer available
Reply 3 of 23, by Harry Potter
MAZter, I thank you. Now, where can I get the caddy?
Reply 4 of 23, by BitWrangler
Frequently, cheapest to most expensive options usually go... buy dead drive with caddy still on (Search for known drive models. Examine pics carefully), buy dead/broken 2nd machine with HDD still in, buy working HDD with caddy on (Again, take a real close look at pics, do not buy from anywhere using stock pics only actual item pics), those are all eBay/Vintage-classified options, but lastly, NEC / IT supply specialist, "refurbished" or new drive with caddy on... which they charge a few hundred for because they keep all that old shit for business critical systems for corp clients.
Reply 5 of 23, by Harry Potter
I believe I found one. 😀 Thank you. BTW, it's just the connector and costs $9.99.
Reply 6 of 23, by MAZter
Harry Potter wrote on 2024-11-13, 14:04:
where?
Reply 7 of 23, by Harry Potter
Sorry. On eBay. Do you want a link?
Reply 10 of 23, by MAZter
Harry Potter wrote on 2024-11-13, 15:57:
I don't understand why I should PM you, but the link is
2019 year Dell laptop HDD connector for Vintage NEC laptop? Is it some kind of joke? Ok, good luck.
Reply 11 of 23, by Harry Potter
You're probably right. I'd better check again.
Reply 12 of 23, by Harry Potter
It might fit, and if it doesn't, I may be able to return it, and if it's too late, I'm not all that deep in the hole. 😀
Reply 13 of 23, by 3lectr1c
Harry Potter wrote on 2024-11-14, 00:47:
That's not going to fit, you're wasting your money and your time.
Owner of https://www.macdat.net, the largest vintage laptop documentation resource on the web!
Reply 14 of 23, by MAZter
3lectr1c wrote on 2024-11-14, 15:28:
What's even worse is the seller's time and money (in case of return).
Reply 16 of 23, by sdz
It won't.
Reply 17 of 23, by 3lectr1c
No random adapter you find is going to work, you need that specific one for that model of laptop.
Reply 18 of 23, by Unknown_K
You need the whole caddy if you expect to get the drive in an out in one piece.
Isn't this the correct one?
https://www.ebay.com/itm/174793809575
Reply 19 of 23, by 3lectr1c
That looks like the one for the original generations Versas (Ultralite Versa, Versa E, Versa V, Versa M, Versa P). Not sure whether or not the Versa 2000D used the same one or not.
Edit: the connector on the original Versa caddy and the photos shared earlier on looks to be different.
