First post, by lkawa84
Hallo,
I have a problem with a cd drive under dos, the drive is connected to a sound blaster 32 ct3670 card, I used the universal driver oakcdrom.sys the drive is not detected. With the Creative Labs CT2800 Sound Blaster 16 card, the drive theoretically worked reading discs, but when trying to install or copy from the disc, messages appeared that there is too little space on the hdd and in addition, all programs from the hard drive run very slowly. After disconnecting the cd drive everything is back to normal. In the computer I have a hard drive connected, a gotek is connected as a floppy drive and in the ISA slot CH375 ISA-2-USB. Maybe someone will be able to give me some hints, I also attach pictures of autoexe.bat and config.sys
Reply 2 of 2, by lkawa84
weedeewee wrote on 2024-11-16, 20:49:
hints: IDE IO port IDE IRQ OAKCDROM IDE IO port parameter, FYI : Re: oakcdrom.sys revisited […]
hints:
IDE IO port
IDE IRQ
Can you explain in a little more detail because I don't quite understand
