Pretty sure HIMEM is already set in my config.sys.
"Pretty sure" or *absolutely sure*?
It's your CONFIG.SYS, look and see. Put the contents of it in this thread.
Pretty sure. :p I've been messing around with the autoexec and config files a LOT via another thread I made for another game. So I need to go and check it.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Instead of "#" write the size of the RAMDISK in KB. For example, if you have 256 MB of memory, you have to set it to at least 193 MB, meaning you'd have to write 197632.
I had completely forgotten that HIMEM doesn't utilize more than 64 MB. If you have 64 MB or more of installed memory, then create at least a 1 MB RAMDISK, so write 1024.
EDIT: and I forgot that of course that's just with DOS 6. If using DOS 7 (Windows 95/98), IINM it sees up to 4 GB, so adjust accordingly.
"/t" is needed. It puts the RAMDISK at the top of the memory.
Type XMSDSK /? to see the commands.
P.S.
You don't have to load it at boot, and probably shouldn't.
eddmanwrote on 2024-11-20, 23:54:The game doesn't like too much free memory; it should be below 64 MB. Use something to eat up the additional memory. […] Show full quote
P.S.
EDIT:
You might also need to not load EMM386.
Awesome. Thanks for the suggestions. At some point I'll get around to testing it out, just as soon as I get some other problems sorted.
OS: Windows 98 SE
Fixed it! I tried the MS-DOS for Games shortcuts in C:\Windows. I sent both to the desktop. I tried the first one, which enables EMSS and XMS...? That seemed to do the trick and the game now works! 😁
OS: Windows 98 SE
Only problems I have now are that there's no speech. Just subtitles. Don't get much in the way of music and SFX during the opening sequence either.
I know this is a couple years old, but if you use PhilsComputerLab Autoexec and config and choose the “Conventional memory only…” option BASS runs great.
I was getting that same error in Dos6.22 and BSOD on Win98SE
