Reply 55220 of 58555, by lolo799
PD2JK wrote on 2024-11-21, 09:17:
Here you are. I have a 600 DPI version as well, but 15MB is too large to attach it. PM me if you're interested.
I didn't remember Trust was selling Iomega hardware in the middle of their rebranded stuff.
Those ubiquitous speakers were sold by everyone it seems, I recall the ones from Pearl...
Reply 55221 of 58555, by revolstar
Picked up deez 2 bæd boyz for free today. One of them will be the new home for my Win98 rig! 😁
Win98 rig: Athlon XP 2500+/512MB RAM/Gigabyte GA-7VT600/SB Audigy/GF FX5700/Voodoo2 12MB
WinXP rig: HP RP5800 - Pentium G850/2GB RAM/GF GT530 1GB
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 55222 of 58555, by pitchshifter
Got my first aureal, the Diamond Sonic Impact. Going right away to my slot 1 P3. 🤤
Any late 90s games to try?
Reply 55223 of 58555, by Kahenraz
If you are installing this alongside a Creative Labs card, make sure to install the Aureal drivers *after*, otherwise Creative's a3d.dll will overwrite Aureal's. To get the most benefit out of this card, you will also want to run your games on Windows 98.
Reply 55224 of 58555, by CMB75
Great, I bought a Core2Quad Q9650 on eBay and a Xeon E7-4880V2 was delivered today. I've contacted the seller, let's see what happens.
Reply 55225 of 58555, by zuldan
On-topic, I got a CT4620 + CT4660 in, the Live! 'Gold' version.
The attachment DSC_2419.JPG is no longer available
Very nice. Is that just a standard IDE cable?
Reply 55226 of 58555, by Nunoalex
I got a quite common VGA card a Trident tvga 8900CL-B
But it has this big "Q" logo and I cant remember what company uses this logo
Do you guys know ?
Thanx
Nuno
Reply 55227 of 58555, by PD2JK
zuldan wrote on 2024-11-21, 17:11:
Yes, it's a standard 40p IDE/PATA cable. I assume it is the one that is supplied in the box/package.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 55228 of 58555, by pan069
Nunoalex wrote on 2024-11-21, 18:15:
I got a quite common VGA card a Trident tvga 8900CL-B […]
Do you guys know ?
Thanx
Nuno
I thought Compaq used a Q logo. Not sure about this particular Q though, it doesn't look Compaq style enough. 🤔
Reply 55229 of 58555, by BitWrangler
Do you guys know ?
Thanx
Nuno
I think it's this puppy https://theretroweb.com/expansioncards/s/qdi-tvga8900cl
CL should be almost as fast as the 8900D.
I was screwing around with some Tridents recently Lowend 486 ISA VGA Graphics Quick Test, Mostly Tridents plus Oak, ATI, Tseng ....
Reply 55230 of 58555, by Nunoalex
BitWrangler wrote on 2024-11-21, 19:25:
I think it's this puppy https://theretroweb.com/expansioncards/s/qdi-tvga8900cl […]
Do you guys know ?
Thanx
Nuno
QDI !! Yes ! thank you
It is QDI that uses tha logo
Reply 55231 of 58555, by CMB75
Today's arrivals, some nice perforated slot covers. Having all covers on a system equal makes my inner Monk feel satisfaction.
The attachment Perforated-slot-covers.jpeg is no longer available
The Roland MT-32 makes me happy, an unwanted 15-core Xeon doesn't.
The attachment Roland-MT-32-Xeon-E7-4880V2.jpeg is no longer available
Reply 55232 of 58555, by Wes1262
So the X800XT seems to work fine.... except the DVI port doesn't. I did the usual cleaning with plenty of contacts spray which solved this problem on other cards but the DVI port refused to work. Black screen, but I can load into Windows. I just don't get anything on screen. Maybe something could be broken on the card? Is this a common issue that you folks know? Or should I try again with cleaner/newer cables, more contacts spray?
Reply 55233 of 58555, by Ozzuneoj
Wes1262 wrote on 2024-11-22, 06:45:
It is very common for heavier cards to have damaged SMD components near the DVI\VGA ports from my experience. I assume it happens when cards are stacked together or put in a box, the metal back plates from other cards scrape parts off.
The most fragile ones are the little three or four leg inductors (filters), but I believe those are usually just on the VGA pins of the DVI port.
There is an example of this kind of damage on a 6800 Ultra in this thread.
I would start at the DVI port and go over all of the components with a magnifier and good lighting. Hopefully it is just a damaged surface mount component.
Also, have you tried a DVI to VGA adapter on that port? It uses a totally different signal path, but it would be worth checking, just in case.
Reply 55234 of 58555, by Wes1262
Good Idea! I will try with a DVI to VGA adapter. And I will take a pic of the DVI area. To be honest the card was stored in a cardboard box on its own and is in pristine condition. I think it's more probable that components blew up rather than being shaved off the card.
Reply 55235 of 58555, by Kahenraz
This kind of damage is also common when cards are stored directly on top of each other. The tiny ceramic capacitors directly under the CPU die can become caught between the metal fins if another card and will easily crush or sheer off.
See here for some photos of this.
NVIDIA GeForce 4 Ti 4200 triage and repair
Reply 55236 of 58555, by Nexxen
BitWrangler wrote on 2024-11-19, 13:53:
Nexxen wrote on 2024-11-19, 09:43:
Bought 2 286 boards. One does post (3x ic chipset) - https://theretroweb.com/motherboards/s/leadma … inc-lm-103fs-16 […]
The other does not (HT12 chipset) - ??? no idea which one it is but can you spot "what's wrong with this picture"? (placebo quote)
Probably this one: https://theretroweb.com/motherboards/s/lucky-star-cm-286ghs
Heh, KBC in the 287 socket. Did you notice that after it didn't POST ? Or it doesn't POST with it put in the right place? There's a possibility that chip is toast now, you could try it with only 512kb in and the KBC out altogether. Also some boards do nothing without a battery on the header, and some do nothing until you bridge the keylock switch.
[seller's pics]
Arrived today.
KBC does work indeed. Tested in 2 other 286 boards.
BIOS stops at 03, but on the other 2 POSTs pretty well.
Clock chip works too.
Probably I just have to restore all the corroded traces and it's good to go. Lucky me I guess.
Edit: BIOS isn't its own, someone stuck 2 chips for the Octek Fox ii 286 and not Lucky Star CM-286GHS.
Also, BIOS version is newer than the one on TRW, I'll have to upload the images. Cool! 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 55237 of 58555, by mtest001
Finally bought a PS/2 bracket for my Pentium MMX setup. I'm trying to install all possible options on its HOT-569 mobo.
The attachment 20241122_231215.jpg is no longer available
I hate to do this but I had to buy it brand new. It is quite difficult to find such parts second-hand...
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 55238 of 58555, by Shponglefan
mtest001 wrote on 2024-11-22, 22:28:
Make sure to double check the pinout on the motherboard before installing. Pinouts on PS/2 adapters are not standard.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 55239 of 58555, by mtest001
Oh yes absolutely, in any case the header on the mobo is 1 x 3 and the bracket came with a 2 x 5 molex as seen in the picture, so it would not even fit.
