First post, by DustyShinigami
- Oldbie
Hi
I hope this is the right section for this. I've discovered there's a problem with the Direct3D Hardware rendering of my graphics card. I suspect it could be related to a certain driver file, but I'm not sure how best to correct it. In the DirectX Diagnostics Tool, everything is marked as Final Retail, all except one, which is Beta Version. A file called quartz.vxd. It says it's unsupported and could cause problems. And that I should reinstall DirectX Media for the latest version. I'm not sure how long that issue has been there, but I did install DirectX 7 before I saw it. It was required for Hogs of War. Is DirectX Media a different tool/driver? Or is it just part of DirectX in general? I did reinstall DX7, but that didn't resolve it.
If I try and test Direct3D, Software Rendering is perfectly fine. No issues. But when it comes to test Hardware Rendering, all I get is a black screen. The menu is super slow in Hogs of War, too. And starting the tutorial, I'm greeted with a black screen. This could also be related to some other issues I've been experiencing, which I've mentioned in other threads. The mouse cursor in Broken Sword 1 for instance. With Direct3D enabled, the cursor and sprites flicker. Disabling it cures the problem. I have downloaded several older drivers for my Riva TNT, and I've installed only one previous one so far, which has made no difference, so I have my doubts that's going to make much of a difference at this point.
Any ideas? Thanks.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
