Reply 40 of 57, by feipoa
- l33t++
AC: it takes too long to create a complete cfg file. If you want to append to the file I already started, I'll check out the other settings. I'm curious what numbers your board has to offer.
MikeSG, unfortunately, CAS Pulse Width has no bearing on performance.
I only ran a brief comparison of 4 motherboards; SiS Rabbit also beats C&T by a respectable amount. The other setting which would have an impact on performance is Force RAS High. Disabling this offers another boost, but no matter what other BIOS settings I try, disabling Force RAS High returns HIMEM errors. Curiously, disabled is the BIOS SETUP DEFAULT value for it. AC, are you able to leave yours disabled and avoid HIMEM errors?
