First post, by TheStrayChow
Hi guys,
I've just fired up an old pentium from around 1997 and the main OS partition has Dos 6.22 and windows 3.11 (Workgroups) installed.
On first boot, the machine would boot to DOS 6.22 ok and then if i were to manually try and boot into windows 3.11, it would freeze indefinitely at the splash screen.
After running a scandisk on the drive, it seems there were a few damaged sectors and the DOS folder became corrupt.
Now when i boot it drops to c:\ prompt grumbling that command.com can't be found.
This machine has a load of windows 3.11 utilities, out of print old bespoke applications and drivers and connectivity for old hardware (vinyl cutters, plotters and such) with finnicky configurations. What steps can i take to re-instate DOS 6.22? When browsing this disk from another windows installation i can see all the files are now free of corruption and nearly everything 'except' the dos folder still exists.
Cant i try and recreate the old DOS folder and copy the DOS files back to the DOS folder and hope that the original config.sys/autoexec.bat still point to the same locations and files and hope for the best? or will i need to re-run the DOS setup.exe to inflate the compressed files first? I havnt installed DOS for about 20 years... so is it a destructive process where it will attempt to fdisk the c: drive as per the installation?
Any helps, (steps!) would be greatly appreciated. I have the DOS 6.22 files burnt onto a floppy-emulated CD but have no floppy disks to use to aid the process.... any advice would be amazing.
