Reply 140 of 178, by ruthan
- Oldbie
IM a bit lost if Freesynch and Gsynch monitor compatibility means that monitor can run on any requested refresh rate from 30 to max (so 70 or 72 is included) and even if yeah, if it needs some driver to make it happen or its only monitor thing.
There is also videocard part, are all modern cards still stupporting this mode, because of BIOS and CMS, legacy boot option or it was somewhere in past removed?
Im already using "some box middleman" to get VGA picture on my modern monitors anyway.. Its ATEN VC-160:
https://www.aten.com/eu/en/products/professio … nverters/vc160/
I just got it to get some picture from old machines in my primary computer room. It supports up to 1920x1200@60Hz (officialy 1600x1200@60Hz), so far i not played on it much.. but at least in Windows settings i set 120 Hz some lower resolutions.. Picture is sometimes all over the place, so you sometimes need to use physical buttons on it adjust it.. or change resolution twice.
I not even checked in my Freesynch / LG G-SYNCH compatible 144Hz / 2560x1440 monitors controls, what refresh rate its actually reporting, im glad that monitor is able to detect 4:3. Im not at my main lair right now, i cant check it.
I never was in perfect sound thing, neither perfect picture, but i care about it, so is nice to read some hints and be able to improve my setup, when is without big pain. I so i had at least that DELL 2209 and IPS panels and 3x 144 Hz Freesynch Nano IPS 27..
Primary message from here is that i could and need just better box like OSSC/ Retrotink, someone already made it..
CRT Terminator is nice, as far as understand better solution, but it needs free ISA slot and more modern machines, PCI version would better.. as lots of new things its costly for just 1 machine, its not portable box to quickly reconnect it to other machine. In guess theory it would be possible make it as external solution and only by some ISA to external box adapter for every machine, where you want to use, because its just some ISA connecto and cable it would be quite cheap to produce.. and whole thing would make economycaly more sense.
At some time it may get cheaper or there would be some better or worse clone, or something even better. When i will i mood and feel that i need it, i will order it.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
