/MZ wrote on 2024-12-02, 11:04:
Joseph_Joestar wrote on 2024-12-02, 08:55:
/MZ wrote on 2024-12-02, 08:44:Maybe the Celeron 533A is also fun to play with. I read somewhere that Intel forget to make some of them PGA incompatible.
It might depend on the stepping.
I have a Coppermine Celeron 600 which is officially supported by my Abit ZM6 and works just fine. It's of the cB0 stepping, and I specifically bought it because of that. Some old forum posts on Anandtech indicated that only the Celeron 600 variants of that stepping will work in that board.
It seems like I got the wrong stepping, but will try it in an PGA Adapter anyway. All my other Coppermine CPU are 700mhz or faster, but with this FC-PGA adapter they should also run on an old 440BX board.
Hmm, I was going to say that your slotket adapter wouldn't be able to work with an FC-PGA CPU. From what I recall there's a reset pin in a different place to stop PPGA and FC-PGA being interchangeable. But it looks like your adapter specifically states that it's an FC-PGA adapter, very nice 😀
PD2JK wrote on 2024-12-02, 15:18:Began restoring the Highscreen 08/15 bigtower. First things first, getting that bomb off the UC4915-A mainboard. […]
The attachment DSC_2548.JPG is no longer available
The attachment DSC_2549.JPG is no longer available
(After cleaning with vinegar and alcohol) Could've been worse!
Wow, lucky! It always seems like Nickel Cadmium cells don't corrode as destructively as Nickel Metal-Hydride. Looks like that board would be a tough fix if it was more corroded.
I got this great Toshiba SCSI 4x Caddy-type CD-ROM drive for cheap, the one below. The one above is my XM-3301 that needed entirely re-capping to work and the power supply replaced: Re: What retro activity did you get up to today?
The attachment IMG_4974 (Custom).JPG is no longer available
But this Toshiba XM-3501 4x external drive worked playing an audio CD for half an hour or so then broke, looping audio? Checking with the multimeter the voltages were going crazy, 12v was going from 3v to 17v and back again, similar for 5v.
This drive used to be used with a Mac SE/30 and has clearly lived in a shed for a looong time since the connectors have rust spots. The power supply board seems to be the fault since the drive is thankfully still working fine after those voltage spikes. With the XM-3301 drive I couldn't figure out what broke the PSU board and replaced it with a 12v input with a step-down 5v board in there. With this Toshiba made external drive I really really want to get the original PSU working this time.
When powered the 'Skynet Electronic' CID-0503 PSU just makes a ticking or clicking kind of sound and the voltages on the output side fluctuate wildly up and down.
I found a couple of bad caps on the PSU board but they weren't important ones and there's not much evidence of caps leaking except for some weird fluid I found on that big diode in the front, which I think might have come from the adjacent cap but those caps are good quality matsushita / panasonic ones, they still all test as good when removed from the circuit. That diode also tests as good after being cleaned.
The attachment IMG_4977 (Custom).JPG is no longer available
The opto-coupler was showing voltages on the receiver side so it looks like the feedback circuitry is working from what I can tell.
The attachment vlcsnap-2024-12-02-15h42m08s023.png is no longer available
Checking the thermal camera this small diode at the front, a Littelfuse P6KE82 TVS diode is getting really hot as soon as the power supply is powered up. From what I've briefly read, a TVS diode is there as part of the circuitry to prevent overvoltage / voltage spikes and it tests properly as a diode when out of circuit. I don't think this is the fault but is definitely another symptom of the main fault. So I've looked at what that connects to and the main thing I can see in its path is the main MOSFET which is an FEC brand 2SK2003 N-channel MOSFET, which is testing really weirdly for a MOSFET, so I think it's broken:
The attachment 2sk2003-odd-reading.JPG is no longer available
But I've never fixed a switch mode power supply before that's more complex than just bad capacitors, so I'm kind of lost. It's an old part too so the replacement MOSFET with the same part code costs as much as a I paid for the CD-ROM drive itself. I'm wondering whether I can trust the sites that say that recommend alternatives based on the MOSFET specifications, I have no idea what most of those specs mean.
Should I check the SK-8085 controller to see if that's driving the MOSFET properly or is the odd MOSFET enough of a 'smoking gun' to conclude that's the fault?
