Socket 5/7 underclock! Aiming for the abyss!
First post, by Sphere478
Spawned from a fun discussion on discord the thought experiment was put forth how slow can you go?
I think 7mhz is possible, but I don’t have the hardware to do it.
I can pull off 50mhz though.
Let’s see those underclocks!
The theorized secret sauce:
Mobo: Lucky Star 5V-1A
Lucky Star 5V-1A / 5V-1B review - scaling form XT levels to K6-II levels
The cpu:
Cyrix 366gp
(Solved) Cyrix 400gp/366gp multiplier settings
This mobo supports 6-8mhz fsb
And the cpu supports 1x multipler
Bonus points: make it to windows for a screenshot, and do it without a heatsink!
Sphere's PCB projects.
Reply 2 of 29, by dionb
Some So5 boards had *very* low FSB options (as they were basically using 486 PLLs). One I had myself: Spring Circle P5C01. It had options down to 16MHz. That might not sound slower than the other options but...
This is a board with SiS 5511 chipset and a 6205 VGA chip using UMA. So the memory bandwidth with 16MHz FSB is shared between CPU and VGA. It was *SLOOOOOW*, running Windows XP not quite as slowly as on my Pentium Overdrive I was running at 16MHz (16MHz 32b bus x 1 by removing fan), but being in same ballpark.
Reply 3 of 29, by Repo Man11
Ugh, sounds like torture to me. I recently used my TXP4 to test a K6 300 I have to make sure it works. And it does, but the difference between 6x83 with 256K L2 cache and 4.5x66 with only the motherboard's 512K L2 was night and day.
Reply 5 of 29, by zyga64
Shuttle HOT-541 (430 FX) and HOT-553 (430 HX) have very flexible PLL. You may go down to 16MHz FSB.
Below is table (frequencies are measured with osciloscope). At 16MHz FSB motherboard was still able to boot-up with PCI Trio64V+
This is my HOT-553 with Pentium 120 (CPU multiplier set up as 1.5), I also have Cyrix 6x86 so I may try with 1x multiplier as well (in the future).
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 6 of 29, by BitWrangler
I just had a thought... while Cyrix 6x86 and MII class might have a functional 1x multiplier (Implemented multis can vary with time, fab, and OEM version, apparently identical ST/IBM/Cyrix versions of same model have shown differences.) ... it might not be slower than a P54 or P55 at 1.5x ... because that core is particularly fast on 16 bit code... anything you need about "486" fast is probably mostly 32bit by then... anything you want TurboXT/286 fast is probably 16 bit code. It might get brought more into line with L1/L2 kneecapping, as then the 50% loss of memory speed is gonna show.
Reply 8 of 29, by rmay635703
Some socket 4 boards had very low undocumented FSB settings, when I’ve tried very low FSBs on either socket 4 or 5 the board would usually freeze during post
Dumber idea but several socket 5/7 boards would allow a voltage greater than 3.5 volts.
My m571 could overclock a k5-or133 to pr200 using 4.1 volts (undocumented)
Such voltages would enable a socket 4->7 interposer and a 1x multiplier using a p60/66
Reply 9 of 29, by BitWrangler
rmay635703 wrote on 2024-12-06, 06:34:
Yes the same clockgen chips that gave some 486 boards "high" 60 and 66 settings were in use on some socket 4, so you can get the "486" speeds like 40, 33, 25, and maybe 20, 16.
edit: Oh by the way, I noticed in some clockchip data sheet, that when the lowest frequencies were used, the DMA/floppy and USB if used reference frequencies went to something different also. It seems possible therefore, that some low speeds may be floppy and soundblaster incompatible, and USB may need to be disabled. Ideally you can look up the datasheet and read what your clockchip does, but many refs only have basic settings or you need to infer things from "close family" chips because that specific one is missing. Anyway, get a hang on boot, try PIO HDD only, no floppy or USB and see if it goes further.
Reply 10 of 29, by j^aws
Sphere478 wrote on 2024-12-06, 04:02:
Still waiting for someone to hit 7mhz core clock on socket 5/7
I tested this configuration a long time ago, even slower than 7MHz using Socket 7 board with working Turbo header on a K6-III+, slower than an IBM XT, measured using various benchmarks:
WIP 2: The 6-in-1 Turbo-switched Socket 7 - from XT to 500MHz; dual Tseng powered...
Speedsys 0.45
The attachment speedsys045.JPG is no longer available
NSI 0.9
The attachment nsi09.JPG is no longer available
Topbench 3
The attachment topbench3.JPG is no longer available
Landmark 2MHz
The attachment landmark2.JPG is no longer available
A 4.77MHz IBM XT should be around 0.5 Speedsys, NSI around 1.0 and Topbench around 4; so these benchmarks give an idea of how slow it is. Board boots fine and managed to test with a speed sensitive game as well. Currently all in storage but will return someday and finish.
EDIT:
Dhrystone 268 (IBM XT around 300)
The attachment dhrystone268.JPG is no longer available
Reply 12 of 29, by Disruptor
j^aws wrote on 2024-12-06, 18:45:
Speedsys
Please may you post the cache chart of SpeedSys?
(You can skip extended memory test of course)
Reply 13 of 29, by j^aws
Disruptor wrote on 2024-12-09, 06:50:
Speedsys
Sure, luckily managed to grab these at the time:
K6-III+ at 100MHz with Turbo enabled:
The attachment 100mhzturbo.JPG is no longer available
K6-III+ at 100MHz with De-Turbo enabled:
The attachment 100mhzdeturbo.JPG is no longer available
Sphere478 wrote on 2024-12-09, 06:32:
Wow! Very nice!
Thanks!
Reply 14 of 29, by Disruptor
Impressive chart.
j^aws wrote on 2024-12-09, 18:58:
Thanks!
Yes but SpeedSys shows now 9.26 and not the 0.45 from above. Has this low value not been reproduceable?
Reply 15 of 29, by j^aws
double post
Reply 16 of 29, by j^aws
double post
Reply 17 of 29, by j^aws
Disruptor wrote on 2024-12-10, 14:37:
Impressive chart.
Yes, it's reproducible - the test just takes a very long time to complete. The 0.45 Speedsys is with all caches disabled (L1, L2 and L3), so there isn't a cache graph from Speedsys. Were you expecting L1 still to be enabled for 0.45? You can see in the table below the various baseline configurations for caches and Speedsys scores:
The attachment Speedsysbaselines.png is no longer available
Reply 18 of 29, by Ahrle
Wonder if this could be used to reach the "sweet spot" for old games, requiring 286'es and such (reason for the turbo button on 3/486 cases)
Current main: Inspiron 8100, Tualatin 1133, 512MB, GF2 Go, 1600x1200, dualboot 98/XP.
Reply 19 of 29, by j^aws
Ahrle wrote on 2024-12-10, 19:02:
Wondering if this could be done to reach the "sweet spot" for old games requiring 286'es and such (reason for the turbo button)
Yes, indeed this does occur with the range of speeds available. Something to also consider is the VGA speed where animations can be too fast still, even with the correct CPU speed; so slowing down this aspect also helps.
