Cyrix appreciation thread
Reply 420 of 548, by feipoa
DarthSun wrote on 2024-11-09, 16:08:
feipoa wrote on 2024-11-09, 04:37:
DarthSun wrote on 2024-05-01, 14:35:
You need a good setup and you're near Intel or better ... […]
The attachment 225621_f7pmpngptgjtqdil_quadrogrup.jpg is no longer available
The attachment 225621_lbwvpzq8fwpv2eef_g1_nature.jpg is no longer available
The attachment 225621_vlecayuuhih4p34l_g1_q2strefresh.jpg is no longer available
Nice! These belong in the 686 Benchmark thread. I also ended my testing at about 600 MHz.
Thanks!
The full test here.
I mean, you should post them in the 686 benchmark thread where the topic fits the contents.
Reply 421 of 548, by DarthSun
feipoa wrote on 2024-11-10, 00:07:
Thanks!
The full test here.
I didn't know, I thought each Cyrix model could go here, sorry.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 422 of 548, by feipoa
they can go in both places.
Reply 423 of 548, by elmatero
On ebay there is actually a very rare Cyrix M-II 333 2.2 volt with gold top for sell. I didn't know that this 4x66 Mhz versions were made with gold top. In the Internet i found only photos of 333GP 2.2V cpus with white aluminium heat spreader.
https://www.ebay.com/itm/267063937743?_trkpar … %3Avlp_homepage
ATX 1998 build: IBM 6x86MX-PR266@208MHz on Tekram P5MVP-A4, 128MB SDRAM, Ati Rage Pro Turbo AGP 2X 8 MB SGRAM, Yamaha YMF719e, Adaptec 1200A IDE 100, Windows 95b
Reply 424 of 548, by myne
Kinda funny to see "fan/heatsink required"
It's like seeing "petrol required" on a car.
It's just expected now.
I built:
Reply 425 of 548, by BitWrangler
You'd think it would be well enough known by Pentium class times, but you could just get away with running some of the slower 1.5 multi socket 5 intels with no sink, by the C0 and later steppings, so I guess the cheap builders did. Maybe the 6x86L could cope with it sometimes also.
Reply 426 of 548, by rmay635703
elmatero wrote on 2024-12-06, 09:44:
That “gold” mobile MIIv chip isn’t found on cpu-world or any of the usual suspects so it might be uncommon. (Examples I’ve seen are black or silver)
Gold tops are associated with a specific production fab and “era”. Black and Silver “cheap” flip chips later.
IBM made most of the late era cheaper silver flip chips as an example. 2.2v barely launched when National was making silicon and ST couldn’t handle the 2.2 volt process (from what I remember)
To know for sure the code on the bottom or back of the chip would need to be decoded, if the code doesn’t exist usually that meant a low production unit early in the process (Cyrix usually sold its engineering samples just like they did retail chips)
4x 66mhz was a strange setup for an MII to start with considering most Cyrix and Even IBM pr333s were always 83x3 and Cyrix would almost always choose 100x2.5x for pr366 considering how overhead constrained they were.
I can only imagine 4x 66 was chosen so builders could use up obsolete motherboards
Reply 427 of 548, by elmatero
This gold MIIv was made by VIA (v letter after MII), it's interesting if was made in Taiwan?
In year 2000 Via still advertised MII models MII- 300, MI- 333, MII- 400 and MII- 433 . Probably this 333 was this goldtop 4x66MHz.
https://web.archive.org/web/20010330152155/ht … roducts/mii.htm
Reply 428 of 548, by myne
rmay635703 wrote on 2024-12-06, 15:14:
Cyrix mostly angled for the upgrade markets.
What do you upgrade your p100 to in the late 90s?
Pentiums weren't really available and AMD had moved on to ss7/462.
So Cyrix and a few others were the only options.
I built:
Reply 429 of 548, by elmatero
myne wrote on 2024-12-09, 00:53:
Cyrix mostly angled for the upgrade markets. What do you upgrade your p100 to in the late 90s? Pentiums weren't really availabl […]
2.2 volt and 4x multiplier was't an upgrade part for obsolete mothetboards 😉 . It was rather part for embeded computers.
Reply 430 of 548, by rmay635703
elmatero wrote on 2024-12-09, 09:29:
That makes sense considering how rare a laptop MII was.
I had obsolete motherboards (from circa 1996) that didn’t support PC100 but did support 2.2/2.4/ or 2.5 volts.
They always supported 75mhz FSB if not 83mhz which meant better options existed for overdrives.
I was guilty of running many. K6-2’s at 2.5 volts and using the 6x multiplier at max FSB
elmatero wrote on 2024-12-08, 21:35:
I had forgotten the VIA chips went back to gold, I could swear the pr433 I had was a black top, ah well
Reply 431 of 548, by elmatero
rmay635703 wrote on 2024-12-09, 15:26:
Lucky you i have motherboard from late 1997 that has minimum volatage of 2.8 , 3,5 multiplier (max) and maximum fsb of 75 mhz 🙁
Reply 432 of 548, by StriderTR
I was literally just digging through some boxes of tech stuff that was donated to me, I found this single poor little CPU sitting on the bottom... undamaged, no bent pins!
It will be given a proper home until it can be tested ! 😀
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 433 of 548, by elmatero
Odd 208MHz i like it 😀 I have the same PR 266 but from IBM. In my case 83 MHz bus cause problem with buildin IDE controller (registry error afer reboot of windows) on my Via MPV3 board. Even with the proper PCI divider set i have to insert Adaptec IDE card to solve this Issue.
Reply 434 of 548, by StriderTR
elmatero wrote on 2024-12-10, 07:38:
Just glad it survived in the bottom of that box. Thankfully it was mostly cables and adapters.
I have an IBM branded PR166+ in my current DOS build, may drop this one in there to test it, and if it works, it's a bit faster. Though for most DOS games I play, the current PR166 (133MHz) is good enough. 😜
DOS Build: https://theclassicgeek.blogspot.com/2024/02/a … s-3x-retro.html
Reply 435 of 548, by BitWrangler
I was just eyeballing my IBM PR266 wondering what to do with it also. Does anyone know anything about the letters at the end of the product code? GD, GE, GF? Only the gold ones of IBM seem to have Gx, the blacktop gets Hx designations.
Reply 436 of 548, by elmatero
G- gold top
H- Black aluminium top
-A -B -C-D -E -F its IBM chip revision info
GF and HF Are the newest one's made in 0,25 um.
Reply 437 of 548, by BitWrangler
Oh nice, thanks, mine is a GF, I was hoping that meant it was latest revision.
Reply 438 of 548, by elmatero
Full identification guide is here https://www.cpushack.com/CyrixID.html
Reply 439 of 548, by BitWrangler
Awesome thanks, I forgot that site existed, years since I've been there. I guess google doesn't like it much or something when I'm looking up CPUs, would rather send me to the, relatively informationless for non-intel parts, cpu-world.. another thing with them yesterday, looking up AMD CPCC 286es and they only show the ceramic top with the date codes, WTF all the info is on the bottom you numskulls.
