Reply 60 of 102, by LSS10999
Been thinking about the possibility to "replace" the AGP slot with PCIe using a PCI-PCIe bridge (e.g. PEX8112) in reverse mode, considering 440BX's AGP uses 3.3V which the bridge chip can just use it.
The questions would be
- Whether 440BX's AGP bus can run reliably operate at overclocked rates like 89MHz, 100MHz or even 133MHz.
- How to provide adequate power for cards that draw a bit more but without a dedicated power connector (usually those between 25W-50W range).
- Whether the PCI(X)-PCIe bridge in reverse mode can handle overclocked PCI host (higher than 66MHz). Couldn't find any info from datasheets but in this thread some tests done by sdz might provide some clues.
If 440BX's AGP bus can really operate at overclocked rates without issues, and that PCI(X)-PCIe bridges in reverse mode won't mind, then the issue with AGP when using FSB133 CPU with 440BX would become irrelevant if the clock generator can be configured for 133/33.
Reply 61 of 102, by myne
He said somewhere it worked up to at least 95mhz.
I have thought that a potential board should have a 1x slot between the agp and board edge, that's directly wired to a 16x slot(1x actual)
This would allow someone to build an agp to pcie adapter, on one custom, 2 finger board.
Ie, it takes agp from the agp slot, feeds it into the 1x slot, and it "pops out" on the 16x slot. Alternatively, many of the mining risers just used a usb cable, so something that crude is possible too.
As far as I've looked, there's no reason in the specification that the chipset must supply the clock. Even Intel's drawings show a 3rd source, and later chipsets don't supply it.
I'm guessing they were just being cautious, in the early days ensuring that the clock was of the right "shape" and timing.
I'm pretty sure that if someone modded a bx with a separate clock as we discussed a page or so ago, it'll work.
See pic
As for power.. Well, if you're building a board, you'll be making sure a pcie slot can provide... ?75w? And agp whatever the highest was
I built:
Reply 62 of 102, by LSS10999
myne wrote on 2024-12-02, 13:58:
It seems standard AGP is rated at 25W just like PCI. There was an extension to AGP called AGP Pro which could be found on some boards, that had additional connections to allow drawing up to 50W/110W.
EDIT: From the AGP Pro specification, it seems there were no signals in the pins added by AGP Pro -- just VCC3.3, VCC12 and GND. So nothing's required on the chipset side to implement this.
Reply 63 of 102, by RayeR
PCIe slot itself allows upt to 75W, it's given by numbers of assigned power pins. you just route 12V and 3V3 from ATX PSU to slot. For more you need to use extra power connector(s) on PCIe VGA...
In age of AGP cards most of them had power consumption below AGP slot limit...
Reply 64 of 102, by rasz_pl
I think I found first real bug in Intel reference design 😀 Q5 Q6 Q8 are marked 2N7002 but use 2N7000 pinout.
Pages 12 13 PIIX4E, symbols PIIX4E, 74F07, 74HC10, 74LVC14, 74HC112, 2N7000.
Reply 65 of 102, by LSS10999
RayeR wrote on 2024-12-02, 17:50:
PCI and standard AGP were only rated 25W. AGP Pro existed in a few boards to allow extra power than standard AGP, but it eventually became irrelevant as video cards requiring more power included dedicated Molex or 12V connectors instead.
Still, there existed a few PCI video cards (actually PCIe GPUs behind a reverse PCI-PCIe bridge onboard) with TDP rated above 25W, so it's possible this 25W is merely a rated value and how much the bus can really handle depends on external factors, like board design (regarding power lines), and perhaps the presence of a card with its own power connector (e.g. some X-Fi models like SB0550, SB0460).
EDIT: The question was mainly about concerns I had with use cases of existing PCI-PCIe reverse adapters for plugging PCIe cards to PCI slots. Those adapters usually do not have an external power connector, and PCIe video cards rated between 25W-50W (which is above PCI power rating while below PCIe power rating) do not have power connectors either. Yet the video card in question does work okay on my system for the time being.
For new designs, this question may not be as relevant with proper power layout.
Reply 66 of 102, by myne
Either way, there's no point delivering more than any real would board delivered.
Any card that needed more was built with power plugs.
I built:
Reply 67 of 102, by myne
rasz_pl wrote on 2024-12-02, 20:53:
Interesting. Mistake or trap?
Historically, map makers would put in fake roads or towns to find copiers.
I built:
Reply 68 of 102, by rasz_pl
Reference design is the stuff you give your clients, you want it copied. Mistake is in suspend circuit and even the intel-se440bx-seattle didnt implement it like in this diagram.
Reply 69 of 102, by myne
https://www.alldatasheet.com/html-pdf/170639/ … 3/1/2N7000.html
That shows them both on the same datasheet
I built:
Reply 70 of 102, by rasz_pl
Yes. If you look closely 2N7002 is a SOT23 package while 2N7000 is TO92. Someone at Intel must have put 2N7000 at first, but then most likely someone else realized they should spec SMD part and just swapped part number without correcting diagram symbol 😀 Gate-Source swapped around.
Reply 71 of 102, by RayeR
Yes, quite a common mistake. I was 'happy' to make a such bug when replaced miniHDMI connector by big HDMI. It looks the same single row of pads so i just swapped it 1:1 but the pinout is different! The biggest fun was that we got image on monitor so nobody noticed a problem for several months. Then someone tried 4k output and it didn't work on _some monitors. We all wonder why. It just run via SE instead of diff pair. Fixing a bad transistor package is much easy but depends on how many boards 😀
Reply 72 of 102, by rasz_pl
Another mistake, first PCI pin B14 (Reserved) pulled hard to ground. Reading PCI spec board build like this violates PCI spec and loses its PCI certification 😀
Done pages 15 agp, 16 17 PCI. PCI, AGP, 74AS07 symbols.
Reply 73 of 102, by myne
I did see some confusing pins in the p2b boardview.
That, and the fact I couldn't at the time get component values was why I did this.
I found them in the bom file. I'm slowly working on a powershell script that will hopefully turn a fabmaster asc boardview +Asus bom backup into a pcb.
So far the ASCs are all in tables. The bom is a bit more quirky.
Then it's theoretically straightforward task of writing all the table data into kicad files. I already tested it with the pcb edge, and that worked.
I'm sure there will be problems though. Writing 900 footprints and aligning them is bound to be problematic.
In theory it will work. I tested the pcb edge and that worked - albeit kicad and asc work differently. Asc uses 5 points to make a rectangle, but kicad uses 2.
Still, I think the reference is important even if it's fairly unique. The script will never write a good schematic.
I built:
Reply 74 of 102, by myne
If anyone's interested in the progress of that script.
It currently works on "ASUS_Motherboard_P2B_1.12" and gets as far as a bunch of mostly correct tables.
I'll leave it to you to find the files.
I built:
Reply 75 of 102, by rasz_pl
You dont want to upgrade Kicad and I have disabled PowerShell (for security reasons) 😁 Will try on another computer later.
Reply 76 of 102, by myne
Heh.
There's nothing special about it yet.
It's not even at the point where I'd call it a useful list of CSVs.
It's close to that. But not quite.
I built:
Reply 77 of 102, by myne
This:
                             華碩電腦-備份資料
單階材料用量明細表
製表日期:02/11/28 17:07:46 有效日期:02/11/28 列印版本: 頁次:1
主件料號:60-M6P260-17 目前版本: 來源:M 發料單位:PCS 生產單位:PCS
品名規格:P2B/URM2/ICS 主件數量:1
R1.12
項 燒 來 發料 組成用量 生效日期 圖號 特 保 Dis
次 元件料號/品名規格 源 單位 底數 失效日期 插件位置/ECN 性 稅 app
10 02-010137154 P PCS 1.0000 99/03/25 N Y
INTEL FW82371EB PIIX4E IC
F-II A0 SL2MY U9,
20 02-010144356 P PCS 1.0000 99/03/25 S Y N
INTEL FW82443BX IC ECN:PE-8-2-T053
440BX C1 SL2VH U7,
MARKING:INTEL/AGPset/FW82443Bx/xxxxxxxx/SL2VH/INTELxxxxxx/xxxxx
QVL:INTEL,
(02-010144326 ) 1.0000 99/03/10 Y
INTEL FW82443BX IC
440BX SL2T5
30 02-230278100 P PCS 1.0000 99/03/25 Y N
WINBOND W83781D PQFP48
H/W STATUS MONITORING IC U6,
MARKING:W/W83781D/xxxxx
QVL:WINBOND,
40 02-230397721 P PCS 1.0000 00/01/18 S N N
WINBOND W83977EF-AW P128
VERSION E U4,
MARKING:WINBOND/W83977EF-AW/xxxxxxxxxxxxxx/xxxxxExxxxxxxxxxx
QVL:華邦,
(02-230397714 ) 1.0000 00/01/18 N
WINBOND W83977TF-AW P128
VERSION D
MARKING:WINBOND/W83977TF-AW/../xxxxD..
QVL:華邦,
Continued for several pages with footers
To this:
UnitID ListNumber ComponentType                  UnitDetails
U9 10 INTEL FW82371EB PIIX4E IC F-II A0 SL2MY
U7 20 INTEL FW82443BX IC 440BX C1 SL2VH
U6 30 WINBOND W83781D PQFP48 H/W STATUS MONITORING IC
U4 40 WINBOND W83977EF-AW P128 VERSION E
Was not easy.
I'm no powershell guru, so I'm sure someone can do it all in 3 lines, but I couldn't. I'd probably do some of it differently now I know how, but whatever. It's fast enough.
Onward.
I built:
Reply 78 of 102, by rasz_pl
Ah.
Boardviews contain pad and net info, should be enough for https://forum.kicad.info/t/how-to-import-a-ki … schema/13178/10
Painful output, but still better than doing everything from scratch 😀
Reply 79 of 102, by myne
Getting closer!
100% generated from the files.
Buggy, but enough for one day.
I built:
