First post, by Mappy8088
Hello everyone, wondering if I can get some expert help with this issue, I'm at my wits end with this board.
Rundown:
Mobo was listed on ebay as working board, arrived and I plugged in a verified working 430W PSU (see pic), verified working Pentium II 400/100FSB CPU and 1 stick of verified working 256MB PC-133 SDRAM and a PCI POST card.
I have a motherboard wiring harness w/ a push button power switch and it also has a 2-pin power led that I hooked up to the mobo header. Hooked up a speaker too. Turned PSU on, pushed the power button and CPU fan turned on, power led came on and after 5 seconds it shut itself off. The POST card didn't light up or anything. No post beeps either. Emailed the seller asking when he last tested the mobo, he never responded but 2 days later I got a refund.
I did notice on the board that 3 caps needed replacement. Since I tested it and it wasn't working I thought I can just replace those and test again. 2 caps were very pregnant and the 3rd leaked at the top. They were all 10v 1000uF. I replaced with 10v 1000uF Rubycon series ZLH. I also noticed the coin cell battery holder was broken, so I replace that as well.
Put a new battery in and retested, the exact same symptoms happened. I noticed that after it shuts itself off after 5 seconds or so, it can sometimes turn itself back on and then turns off again. All within 30-40 seconds or so. Very rarely when I keep cycling like this, I have gotten random beeps. 1 long, 3 short or 1 long then turns off midway, or 1 long 2 short and 1 long.. Seems random and doesn't always occur.
So, given that 3 capacitors needed replacement, I decided to replace all the big caps around the PSU and CPU slot. They were all 1000uF 10v and 1500uF 6.3v. I replaced the 1500uF 6.3v with 1500uF 10v as it's all I had - also Rubycon caps. Still the same symptoms - and this is where I'm reaching out for help.
I've included a pic of the PSU tester and a pic of the mobo. There are green circles around everything I've replaced, hopefully you can see them.
Here's what else I've tried based on searching Vogons:
1. Tried a different CPU, this time a slocket with a PIII 933/133fsb
2. Tried a different stick of known-good RAM
3. Tried a different 3-pin fan because someone mentioned maybe RPM was too slow on some fans. Also, I've seen videos of people with VA6's that don't use a fan plugged in at all, so maybe it's not necessary on the VA6 boards?
4. Discharging the CMOS by shorting pins 2&3
5. Tried with an AGP video card plugged in (no video blip when it turns on btw)
6. Tried with a keyboard plugged in (keyboard lights do come on, then go off when the computer turns on, otherwise no difference in behavior)
Thanks in advance for taking a look. I'd really like to give everything I got to fixing this; they just don't make this retro hardware anymore and I'd like to keep it out of the landfill - was hoping this would be my forever board but the universe has other plans so far.
The attachment psu_output_1024_625.jpg is no longer available
The attachment my_mobo_replaced_caps_parts.png is no longer available
Reply 1 of 15, by Mappy8088
Not sure why my images went missing all the sudden.
Reply 2 of 15, by Repo Man11
Since I have a BIOS chip programmer, if it were me at this point I would try reflashing the BIOS. But if you don't already have one, it would be a bit much to expect you to buy one on the somewhat slim chance that it would solve this issue. If you enjoy this sort of thing (messing about with old computer hardware), they are a worthwhile investment. I received a dead Tyan S1854 in a parts lot I purchased and I reflashed the BIOS and it then worked perfectly.
Reply 3 of 15, by PC@LIVE
Hello, it's been a long time (a few years), that I write here about the problems and solutions of the motherboards, unfortunately this symptom that you describe, seems very similar to an ASUS that I have in repair, in the MB ASUS I identified a Mosfet (or regulator?) Fault, it is located near the AGP slot, I think that when the post code (by the way an ISA-PCI Post Card, displays the last error code), reaches the video display, the Mosfet activates, but being short it turns off the MB.
If you want you can give him a check, but if that's ok, it could be something else around.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 4 of 15, by oh2ftu
check for shorts on all rails (without any CPU, RAM or addon cards installed).
Still, with just a bare board, check for voltages.
A thermal cam would show something as well, if you have access to one.
Just yesterday I recapped a SS7 board that showed absolutely no life until a recap.
Reply 5 of 15, by Mappy8088
Repo Man11 wrote on 2024-12-07, 06:12:
Good idea, I do have a TL866II. I pulled the chip, peeled back the Award label and it's an Amtel chip (Amtel AT49F002NT / 90PC / 9928). I chose that chip in the software and did a read. The read seems to have worked without issues as I can see the ASCII text, etc. I saved it to a .bin file just to have. At this point, if the read went ok does that mean it's probably ok? If not, should I try reflashing and with with BIOS? (from the ASCII text it looks like it was 4.51PG 12/20/99)
Thank you all for your responses! I'm tackling this step by step, so I'll address each suggestion and hopefully we'll get this fixed.
Reply 6 of 15, by Nexxen
Correct me if wrong,
the board comes back on by itlsef after a while?
Do you have an oscilloscope?
Can you post a pics with readable ICs of the half where the PSU connector is?
Check if this one works as expected:
https://www.alldatasheet.com/datasheet-pdf/vi … M/US3004CW.html
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 7 of 15, by rasz_pl
That does sound like for example short on CPU power rail.
Check continuity/diode reading on all 4 big mosfets next to CPU slot, also measure all voltage rails on ATX connector against ground.
Abit was infamous for going with cheapest most counterfeit capacitors, pretty much all Abit boards leaked, might be worthwhile to check if capacitor juice didnt eat something.
Reply 8 of 15, by Mappy8088
Nexxen wrote on 2024-12-07, 17:10:
Correct me if wrong, […]
Ok, after I read your comment I tested a bit more to confirm. Oddly this is what happens. Flip on PSU from the back, Push the power button on the harness, computer comes on for a count of 3, turns off. There's some type of 'cool down period' where it will not turn on again right away. I figured out, it doesn't turn on by itself like I thought, but it's something very sensitive. Ex. after about 30 seconds of me not touching it after it powered itself off, if I just barely touch the pad of my finger to even one side / one wire of the the power button it will turn itself back on, this time for like a count of 60 before turning itself off again. No BIOS beeps either. I repeated this 3 times in a row to make sure.
I even made sure the wiring harness that goes to the pin headers was held down so as to rule out it moving and touching something on the header and starting it again - it's really just something very sensitive that re-activates the power. I have also tried pressing on the mobo, pressing caps, chips, slots, etc and it won't turn itself back on that way. Truly something odd is happening. Lastly, I even tried using two 1-pin dupont connector wires (like for Arduino's) connected to power-on header pin1 and pin2 and all I have to do to turn it on is touch the tip of one of the wires with my finger. I don't even have to touch the wires together. Some type of power-sensing issue?
I've attached a picture as requested. Let me know if you need me to read something on a chip that won't show up in the pic. I just replaced all those large caps
I do have a oscope, nothing professional, just an Adrian Black reviewed Zoyi ZT-703S that I don't know how to use yet. I'll look at the board to see if I can find that chip you mention above.
Reply 9 of 15, by Repo Man11
Mappy8088 wrote on 2024-12-07, 16:59:
I'd say that at this point it is almost certain the problem is something else. If it were me, I'd probably make sure that I had the most up to date BIOS on the chip.
Reply 10 of 15, by Nexxen
Mappy8088 wrote on 2024-12-07, 18:28:
Ok, after I read your comment I tested a bit more to confirm. Oddly this is what happens. Flip on PSU from the back, Push the […]
Check the component I linked the datasheet to.
My guess is the power on circuit not working, I had it before and it behaved like in your case.
Reply 11 of 15, by Mappy8088
rasz_pl wrote on 2024-12-07, 18:02:
Ok, had to watch a video on how to test mosfets. I have 3 PHP 55N03LTs that I tested. Check me if I"m doing this right.
Fluke on Diode mode
Spec sheet for the 55N shows when facing the chip, left pin 1 is gate, center pin / pad is drain, last pin right is source
Power and everything else is removed from the board
Touch my fingers on all pins for a second
Red lead from fluke to center pin 2 (drain)
Touch the Black lead from fluke to the rightmost pin 3 (Source)
Fluke beeps like in continuity mode, then starts counting from 0.2v and keeps going up to 0.8v, etc.
All three of these respond the same.
I've included a picture of the topmost one w/ pins marked.
Reply 12 of 15, by Mappy8088
This is what I got, not sure if it's supposed to behave this way. The pins not connected to ground, some are solid 0 while others count up in ohms until it reaches 0 and some are solid ohm, like pin 1, 2, 12.
Reply 13 of 15, by Mappy8088
Repo Man11 wrote on 2024-12-07, 18:45:
Yep, agreed about having the latest. I found 4.51PG-7L on the Retro Web and flashed the existing BIOS with it. No change in behavior.
Reply 14 of 15, by rasz_pl
Mappy8088 wrote on 2024-12-07, 19:20:
>I have 3
arent there 4 big ones and 2 smaller ones near the cpu slot? with mosfet the most common failure mode is being shorted, imo no need for more elaborate testing
Put a scope on slow timebase on:
- pin6 powergood of US3004 https://www.alldatasheet.com/datasheet-pdf/vi … SEM/US3004.html
- atx connector pin ps_on and powergood
- check both sides of all four coils, one side is being switched and will have messy reading but other side should have clean stable voltage at least for those couple seconds its running
- poweron pins you are shorting
power it on and watch what happens.
No post codes means either corrupted bios or cpu not running at all.
Afaik VIA 686 controls powering on, does it even without bios and doesnt have any facility to turn off on its own without running bios. Board should not turn off even with BIOS chip removed. It will however turn off if it doesnt like ATX supply or US3004 powergood.
Reply 15 of 15, by Nexxen
US3004
Check if all the input voltages are there; do the same for output voltages.
If the I/O aren't consistent, it'll shut down.
Pin14, what happens when you power on?
Pin6?
Btw, they cost 2€ for 2 pcs on Ali's Press.
