First post, by DustyShinigami
- Oldbie
Hi
I'm currently looking into and trying to understand how to get CD audio to play in DOS, specifically for a game, and whether it needs to be analog or digital. There's an issue I'm trying to investigate where audio tracks are not playing during gameplay. A couple of other games haven't been an issue, such as Quake and Blood. They just work. But I'm wondering if some may require a different approach to get working. I've tried connecting a cable from the CD-ROM's Audio Output to the sound card, which was the old way of getting the audio to work, but it doesn't appear to be helping at all. And I'm not sure if there's something I can do in DOS to find out if the volume needs adjusting? Not a problem in Windows of course. I'm also not sure if digital audio is enabled in Windows. I need to check, but I'm sure it is. I just don't know if this is something I need to enable/configure in DOS? I don't think I have separate ports on the CD-ROM or sound card - one for Analog and one for Digital. There appears to be just one on each. I'd need to check again.
I believe the cable was originally connected from the CD-ROM to the motherboard. I'm guessing this would have been to get CD audio to work via onboard audio? I'm not even sure if the cable is working or not; I've not been able to check. Is it just a case of putting an audio CD in and loading/playing it via an audio mixer/control panel? Again, that would most likely work fine under Windows, but it's getting it working under DOS that's the issue. I need some way to test if it's working correctly as it should whilst under DOS. The CD-ROM driver is all set up and working under DOS. As I said, audio has worked for Quake and Blood, so I'm just totally at a loss as to why this one particular game isn't working.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
