Reply 180 of 1256, by Joseph_Joestar
- l33t++
Joseph_Joestar wrote on 2023-08-07, 18:17:From what I gather, this indicates EFX 1.0 support, which may supersede EAX 5.0 (not entirely sure about that). The same entry appears in my log file, and it may explain why UT3 and Gears of War behave that way. Since both games were released in 2007, around the time when Vista started shipping with new PCs, it could have made sense for developers to use this approach.
Since I was doing some EAX testing, I decided to revisit Unreal Tournament 3 today. As before, here's my UT3 Launch.log when using an X-Fi Titanium:
Init: ALAudio device requested :Init: ALAudio device opened : SB X-Fi Audio [0001]Init: AL_VENDOR : Creative Labs Inc.Init: AL_RENDERER : SB X-Fi Audio [0001]Init: AL_VERSION : OpenAL version 1.1Init: AL_EXTENSIONS : EAXEAX1.0EAX2.0EAX3.0EAX4.0EAX5.0Init: Device supports: EAX4.0Init: Device supports: EAX-RAMInit: Device supports: ALC_EXT_EFXInit: Found EFX extension with 4 effect slots and 4 potential sendsInit: ...'reverb' supportedInit: ...'equalizer' supportedInit: ...'low pass filter' supportedInit: XRAM : YESInit: ALAudioDevice initialized.
And now, here's the same log when using an Audigy 2 ZS:
Init: ALAudio device requested :Init: ALAudio device opened : SB Audigy 2 ZS Audio [EC00]Init: AL_VENDOR : Creative Labs Inc.Init: AL_RENDERER : SB Audigy 2 ZS Audio [EC00]Init: AL_VERSION : OpenAL version 1.1Init: AL_EXTENSIONS : EAXEAX1.0EAX2.0EAX3.0EAX4.0Init: Device supports: EAX4.0Init: Device supports: ALC_EXT_EFXInit: Found EFX extension with 2 effect slots and 2 potential sendsInit: ...'reverb' supportedInit: ...'equalizer' supportedInit: ...'low pass filter' supportedInit: XRAM : NOInit: ALAudioDevice initialized.
Note this line on the X-Fi:
Versus this line on the Audigy 2 ZS:
The slots that the log file is referring to are described here. To summarize, with EAX 4.0, two out of the four slots are permanently assigned to reverb and chorus, leaving the other two slots free. However, with EAX 5.0 all four slots are always free to be used as the developer sees fit, which is what this log reflects. In conclusion, my hunch that Unreal Tournament 3 uses EFX to utilize EAX 5.0 functionality seems to be correct, and my previous assessment that it tops out at EAX 4.0 was wrong.
Lastly, note how the game actually detects EAX 5.0 capabilities on the X-Fi, while not finding that on the Audigy 2 ZS (see the lines right below Init: AL_EXTENSIONS : EAX).
