Reply 55400 of 57953, by CMB75
smtkr wrote on 2024-12-07, 00:21:
🤣. Yeah, these brackets and io plates go missing more than the actual hardware 😁
Yeah, especially on NICs with low profile brackets if you’ve got cases with full height slots only.
Reply 55401 of 57953, by Masterchief79
My stuff finally arrived. Shipping times are a pain in Germany right now.
Hardly retro but still cool: HD7990 in great condition, just needed new thermal paste. Great card for Max Payne 3 which is what I'm gaming right now.
And this Pentium 4 670 R0. Just testing this for my 2005 build on a Asus P5ND2 SLI (NForce 4 Intel Edition chipset) and it's working suprisingly great and with no headaches. Look at this baby. I didn't even adjust the CPU voltage, this is all stock values.
Reply 55402 of 57953, by PD2JK
That's a pretty awesome OC, I didn't know such P4's had that much headroom. Then I wonder why they cancelled the possibility to bring out the first 4GHz at the time. Probably early yield troubles I guess.
Congrats!
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 55403 of 57953, by Jccwu
digger wrote on 2024-12-06, 22:16:
@Jccwu Oooooh, have you opened a dedicated topic for those metal card brackets yet? They're definitely worth a topic of its own. […]
It will make it easy to take orders, determine demand for the various variants you have or might consider making.
I'm sure you'll attract a lot of buyers.
Good work!
I have already attracted many buyers and continue to actively sell. But in my own country.
Sound card's music
Reply 55404 of 57953, by Masterchief79
PD2JK wrote on 2024-12-07, 11:12:
Congrats!
Thank you. 😀 They generally didn't OC well (at least until the 65nm Cedar Mill refresh came out, which you could OC to the moon). But there's also a million different steppings for Prescott and I haven't tested any other R0's yet. From a sample size of 1, this still seems like a pretty good chip. 4700MHz@1,4V crashed after 15 minutes of SuperPi 32M just to give you an idea.
I'm also suprised on how this mobo is holding up. It's not even recapped yet and there are "the quickly expiring kind" of capacitors installed. ^^
Reply 55405 of 57953, by myne
Might be time to delid it and replace the goo
It's kinda funny how fast we went from 1ghz to 4.
And it's taken a decade to get to 6.
I built:
Reply 55406 of 57953, by BitWrangler
Well it smooths out the curve a bit if you regard netburst as a cheat code. The higher you go over 2ghz though the less it's like electronics, meaning below that, you can lay out your CPU like a hotwheels track and expect your hotwheels car to follow it and stay on it when you let it go down the slope or shoot it from the catapult... then over 2ghz it's more like you either haven't got a hotwheels car any more but a paper aeroplane, or the track has lost it's edges, or both, and applying more oomph to the thing just has it going off anywhere. So then you're trying to contain it in tubes more than tracks, but get all sorts of problems around how to fit tubes together and change their shape without things bouncing off the joins. Then that only works for a bit, and you're wondering whether your signal is going inside or outside of them, then you're switching from bulk matter to dealing with everything atomically, or worse, quantum mechanically, the billiard ball has left the building.. or some of it has, there's still a 60% chance it's located somewhere around here. Anyway mix the metaphors how you like, trying to put hi-bounce powerballs down a marble run or something, but yeah, gets weirder the faster you try to go.
Reply 55407 of 57953, by Minutemanqvs
3 AGP cards showed up ad my local thrift store, the lot for around 10€ so even if the 2 first ones are low end, they will be useful one day. All are working.:
- Radeon 7000 VE
- Radeon 9200 SE
- Radeon X1650 Pro IceQ
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 55408 of 57953, by Ozzuneoj
myne wrote on 2024-12-07, 14:34:
Thankfully the physical limits of increasing frequency have been counteracted by insanely huge improvements in performance per-clock and per-watt.
I'd love to see a comparison of something like a 7800X3D or 9800X3D, pulling ~70-100 watts vs a top of the line Pentium 4 pulling ~115 with a single core.
This is about as close as I can come up with on short notice...
https://www.cpubenchmark.net/compare/1080vs52 … MD-Ryzen-7-7700
Of course synthetic scores don't tell the whole story (Passmark doesn't seem to benefit from tons of cache), but we're approaching something like 100x the performance for the same wattage versus the top Netburst chips. Or, in the case of the Ryzen 7 7700, almost 100x performance at a little over half the wattage. Really incredible if you think about it. And that was all in spite of Intel's 6+ year stagnation period.
Reply 55409 of 57953, by oh2ftu
Two computers:
One chenbro AT-case with a pullout-mobotray. Contained
- a DFI P5BV3+ rev B+ (MVP3 mobo with 1M cache)
- K6-2/350
- Some ram
- CT2940 ..
- Ati Rage 128
Went for it mostly for the mobo and case.
The other in an unknown case with PSU parallell to mobo next to the CPU
- MS-6340 KT133 mobo
- Duron 800
- Some ram
I gave a i5-2500K and some change for these. Not bad, not great.
Got to replace caps on both motherboards to get them alive.
Today I got myself a Soltek SL-02A++. I had one back in the day, still had the box with the previous (non-FCPGA) slotket inside.
Reply 55410 of 57953, by Linoleum
That CT2940 checks many boxes: IDE header, Midi header, OPL3 and almost as quiet as an AWE64! It's so good it will (sadly) replace my Audician32 Plus. Creative's mixer totally destroys Yamaha's...
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX4 100, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 55411 of 57953, by nfraser01
One of those odd MWave DSP modem/sound card combos. Are they as bad as people suggest?
Reply 55412 of 57953, by rasz_pl
nfraser01 wrote on 2024-12-08, 20:16:
Settled lawsuit bad.
Reply 55413 of 57953, by Masterchief79
Just bought this MSI FX 5700 Ultra this morning for 45€. No idea about the condition though.
Reply 55415 of 57953, by H3nrik V!
Masterchief79 wrote on 2024-12-09, 09:25:
Judging from the looks and lack of dust, it doesn't look like it's seen much use 😀
Reply 55416 of 57953, by luckybob
H3nrik V! wrote on 2024-12-09, 12:26:
That's what she said. ^.^
Reply 55417 of 57953, by Masterchief79
luckybob wrote on 2024-12-09, 14:56:
I'm more afraid of stuff like a warped PCB or other mechanical damage. I'm always expecting broken solder joints, memory artifacts or missing components and that sort of thing but I'm used to fixing that stuff by now. You can't fix a warped PCB and you can almost never tell by the pictures.
Although I would agree this card _looks_ fine. ^^
Reply 55418 of 57953, by BitWrangler
I've seen some very warped boards run great still though. Hurts your brain to look at, but works.
Reply 55419 of 57953, by Ahrle
Picked up Saturday. $45 Optiplex GX115 with cute 15" monitor and accessories
The attachment 20241208_051318.jpg is no longer available
Uninteresting system as such. Only 2 RAM slots, weak onboard GPU and no AGP. But! My first PC was a PIII-500 of this model. 😁 (With a Nokia monitor weighing like a smaller house)
Gonna throw in an HDD, a bit uncertain about graphics though. With PCI only, guess this thing is bound to be GPU crippled regardless? Best currently in stock, 16MB Matrox...
Current main: Inspiron 8100, 512MB, GF2 Go, 1600x1200, dualboot 98/XP.
