First post, by DustyShinigami
Hi
I came across a bit of info yesterday that was disappointing to learn. This was from a very old thread on these forums, so I'm not sure if new workarounds have been discovered since. I understand that .cue and .bin CD images won't work in DOS? In order to play games without the CD that use audio tracks? If so, is there no workaround for this? I've still yet to try SHSUCD, but have it ready to be installed/configured.
One game that has come to mind is my original DOS copy of Sam & Max Hit the Road. I didn't own it back in the day sadly, but was also surprised to learn that there's no way of actually installing it...? A folder and some files have been placed on the C drive, but there was no option during installation to choose the directory. The setup is more to configure the audio; it looks to run straight from the CD and loads up the speech and music etc. My copy is in pretty prestine condition too, so it would be great to preserve it and use an image file. 😀
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
Reply 1 of 9, by auron
it's not so trivial because the signal path is totally different. you're not inputting a stereo audio signal into the card where it's expected to be mixed in hardware, instead you're trying to read the audio data from a software running in the background, so in addition some kind of software mixer would need to be running to do this in DOS. both would also probably come with noticeable overhead on slower machines. it's probably possible in win9x with the right card/drivers though.
it's why a hardware optical drive emulator with CD audio out is a useful device.
Reply 2 of 9, by jmarsh
The Lucasarts talkie games didn't need any sort of CDROM emulation; you can just copy the CD contents into a directory on the HDD and run it from there.
Reply 3 of 9, by feda
Sam & Max does not use Redbook audio tracks. There is a version that includes some bonus audio tracks for listening, but they're never played by the game.
Reply 4 of 9, by DustyShinigami
feda wrote on 2024-12-09, 17:42:
That’s something at least. Thanks for the heads-up. 😀
OS: Windows 98 SE
Reply 5 of 9, by DustyShinigami
jmarsh wrote on 2024-12-09, 16:49:
Oh cool. I’ll do that now. Thanks. 😁
OS: Windows 98 SE
Reply 6 of 9, by DustyShinigami
auron wrote on 2024-12-09, 15:26:
I see. Is the hardware optical drive emulator similar to the emulated floppy drive? In that it reads image files? How does that work exactly? Thanks.
OS: Windows 98 SE
Reply 7 of 9, by JQW
The game did use the audio track, but only for one particular scene some way into the game. I can recall playing the game with a particular GM capable sound card back in the day, and as that card didn't have any inputs for CD audio, that portion of the game was silent.
Reply 8 of 9, by auron
DustyShinigami wrote on 2024-12-09, 17:48:
look for ZuluSCSI/ZuluIDE, though can't speak to how far the cd audio support is perfected as of right now. they also still seem to require an add-on DAC to do this.
Reply 9 of 9, by DustyShinigami
I’ve only briefly looked into ZuluSCSI/IDE, so I’m not quite sure how that works, but I don’t suppose any new developments have been made to get redbook audio CD images working in DOS? It would be SO awesome if that became a reality! 😄
OS: Windows 98 SE
