Reply 440 of 545, by elmatero
- Newbie
StriderTR wrote on 2024-12-10, 09:09:I have an IBM branded PR166+ in my current DOS build, may drop this one in there to test it, and if it works, it's a bit faster. Though for most DOS games I play, the current PR166 (133MHz) is good enough. 😜
DOS Build: https://theclassicgeek.blogspot.com/2024/02/a … s-3x-retro.html
Your build use very similar motherboard to mine: ATC-5020+. I have started my projekt from 6x86 PR150 (120 Mhz), but then i get 6x86 PR266 (I used it as 225 and 233 Mhz -perfectly stable) and now i have MII-333GP 3x83 Mhz (but i use it as 3,5x75 MHz - 263 MHz because my motherboard don't have 83 fsb option). This 333 is max what this motherboard can handle and it fits perfect for my nostalgic hardware and software requirements 1996-1999 😀
ATX 1998 build: Cyrix MII-333GP@263MHz on A-Trend Atc-5020+, 64MB SDRAM, Ati Rage Pro Turbo 4 MB PCI, Yamaha YMF719e , Windows 95b
