Old ISA memory expansion
First post, by demyx
Hello everyone,
I'm trying to bring back to life an old flooded IBM 5150. Inside, in addition to MB, floppy controller and parallel port, I found this memory expansion that I can't find any evidence of on the internet.
I can't find any photos to trace the brand and model.
I hope someone from the community can help me...
Thanks!
Reply 1 of 4, by dominusprog
So, what's the problem? Is it not working?
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 4, by douglar
I've got this one that is labeled 708-086. It is also known as a DTK-PII-129. It has an extra bank of chips and the layout is a little different, but there are a number of similarities.
https://theretroweb.com/expansioncards/s/dtk- … 9-640k-ram-card
Perhaps you have an early DTK ram card.
Reply 3 of 4, by demyx
Hi, first of all thanks for the reply.
I still don't know if the card works or not, as soon as possible I will do a test and share the result.
My thought is turned to the row of empty sockets, I have a lot of ram and I could fill them all, the problem arises from the fact that I would not know how to set the jumpers.
I saw the close similarity with the PII-129, for sure the 3-position jumper of the card combined with the 6-position switch, will equal my 8-position switch, but the problem of the settings remains...
I will continue to search, maybe with a bit of luck something will pop up...
Reply 4 of 4, by douglar
demyx wrote on 2024-12-12, 16:46:
Hi, first of all thanks for the reply. I still don't know if the card works or not, as soon as possible I will do a test and sha […]
The PCB looks < 1985 to me but it is possible that the "15 87" on the back of the card suggests that the card was made in the 15th week of 1987. Maybe?
Unfortunately the FCC ID's for DTK don't go back any earlier than 1988, so that date doesn't help us. I would have had a hard time identifying my card if that PII-129 sticker fell off.
The jumper settings for my card are here: https://theretroweb.com/expansioncard/documen … ee746365713.pdf
Maybe you can figure out what the jumpers do if you follow the traces. It's a pretty simple card.
