Reply 100 of 144, by DustyShinigami
 - Oldbie
Shponglefan wrote on 2024-12-05, 15:19:You'll need a joystick (DB15) to MIDI adapter. These come in a variety of form factors. […]
DustyShinigami wrote on 2024-12-05, 14:18:It looks like it's only going to include a power cable/pack, but I wanted to check if I need any other cables for it? I know a joystick serial cable is often mentioned, but will that be needed if I'm using an ISA sound card with MPU-401 output? Or do I need to get a MIDI cable of some sort?
SerdaShop has one that is basically a board that plugs in the joystick port and has two MIDI out ports: https://www.serdashop.com/DB15MIDI You'll need a separate MIDI cable to connect the adapter and the SC-55. Note that this particular adapter means the joystick port cannot be used for a joystick at the same time.
There are also other adapters that include a DB15 pass-through for joystick connections in addition to MIDI connections. Some of them will have MIDI cables that would plug directly into the SC-55. Others (for example, MediaVision's MIDI Mate) would require an additional MIDI cable to connect to the adapter.
Whether you need a separate MIDI cable comes down to how the adapter is designed.
Sorry, totally forgot you already linked to that adapter. ^^; But with that, would I still need the mixer you mentioned?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
