First post, by DustyShinigami
- Oldbie
Hi
I'm having some trouble flashing the BIOS for my motherboard, which is this - https://theretroweb.com/motherboards/s/msi-ms-6156-bx11#bios Firstly, is it possible to change it from AMI to AWARD? My current version of AMI looks to be 1.2. However, if I can change it to AWARD, the latest version of 1.6 supposedly allows me to use HDDs over 65GB, which is what I need. The latest for AMI online looks to be only 1.1, which only corrects the CPU's name from Katmai to Pentium III. It doesn't look to include any other fixes.
I tried loading AWARD 1.6 in DOS, but it comes up with this Flash Utility - https://i.imgur.com/tRdW1yK.png. The box is blank and I'm not sure what to put there. I tried giving it a name, but that didn't work. If a .bin file is required, I couldn't get it to add it. It did also come up with a request to write something to a floppy disk, so I tried putting one in, it wrote some files, loaded that utility back up, and then proceeded to emit a constant beeping sound that wouldn't stop unless I shut the machine off.
The readme suggests I add the files to a bootable floppy disk, but whenever I tried to boot from it on startup, it kept complaining it wasn't a valid disk. And I tried a second floppy. Same issue. So in the end, I tried to do it directly from the HDD.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
