First post, by Joseph_Joestar
0.0 Disclaimer:
This guide is provided "as is" and free of charge. There is no warranty or support of any kind. By using this guide, you acknowledge and agree that you do so at your sole risk. The author is not liable for any damages and claims arising from the use of this guide.
0.1 Introduction:
This guide will help you install the optimal drivers for gaming under WinXP 32-bit (with SP3) when using a PCIe X-Fi Titanium sound card. It has been successfully tested on a retail X-Fi Titanium (SB0880) and an X-Fi Titanium Fatal1ty Pro (SB0886) sound card. However, it isn't suitable for X-Fi Titanium HD PCIe sound cards as they have no WinXP driver support. This guide is also not suitable for any PCI based X-Fi sound cards (e.g. SB0460). It is also not suitable for any X-Fi Xtreme Audio models. Do not use it with those cards. Supported features:
  • EAX 1.0, 2.0, 3.0, 4.0 and 5.0 support for WinXP games
  • EAX Unified support for games that require eax.dll
  • OpenAL support for games that require OpenAL32.dll
Lastly, this guide and the driver pack that it uses are tailored to the US English version of Windows XP 32-bit with SP3. Installing these drivers on a non-English system may cause the volume control screen (and possibly other aspects of the OS) to appear in English. Additionally, this guide hasn't been tested with Windows XP Professional x64 Edition and compatibility with that OS is unknown.
1.Hardware and software requirements:
Before proceeding to the next section of this guide, make sure that the following hardware and software requirements are met. If they are not, the driver installation may fail.
1.1 Ensure that your X-Fi Titanium sound card is properly installed in a free PCIe slot
1.2 If your motherboard has an integrated sound card be sure to disable it in the BIOS
1.3 During the driver installation process, the X-Fi Titanium should be the only sound card in your system. Using a second sound card may cause the driver installation to fail
1.4 This guide has only been tested on Windows XP 32-bit with SP3. A clean install of Windows must be performed before attempting the driver installation procedure. Do not use any "unofficial updates" just apply the latest official Service Pack 3. Only install the drivers for your motherboard and graphics card until you complete all the steps in this guide
2. Preparation:
2.1 Download X-Fi Titanium driver version 2.17.0008 from here and extract its contents to C:\XF1
2.2 Download Creative Console Launcher (Beta) 2.61.49 from here and extract its contents to C:\XF1
2.3 Download Creative Dolby Digital Live Pack 3.00.06 from here and extract its contents to C:\XF1
2.4 Download Creative SoundFont Bank Manager 3.21.02 from here and extract its contents to C:\XF1
3. Windows Driver Installation
3.1 Run C:\XF1\XFTI_PCDRV_LB_2_17_0008.exe complete the installation procedure and restart your computer when prompted
3.2 After the restart, click Cancel on the Creative Software AutoUpdate screen, then go to Control Panel > Add or Remove Programs > Creative Software AutoUpdate > Change/Remove to uninstall it
3.3 Run C:\XF1\CSL_PCAPPBETA_LB_2_61_49.exe complete the installation procedure and restart your computer when prompted
3.4 Run C:\XF1\DDL_PCAPP_LB_3_00_06.exe complete the installation procedure and restart your computer when prompted
3.5 Run C:\XF1\SFBM_PCAPP_LB_3_21_02.exe complete the installation procedure and restart your computer when prompted
4. Configuring Creative utilities for optimal gaming performance
4.1 Go to Start > Programs > Creative > Creative Audio Control Panel > Mode and ensure that Game Mode is selected
4.2 Go to Start > Programs > Creative > Creative Audio Control Panel > Speakers and choose your speaker configuration as appropriate
4.3 Go to Start > Programs > Creative > Creative Audio Control Panel > X-Fi CMSS-3D. I suggest turning CMSS off if you are using speakers and leaving it on if you are using headphones
4.4 Go to Start > Programs > Creative > Creative Audio Control Panel > Encoder and enable Dolby Digital Live if needed (optional)
4.5 Go to Start > Programs > Creative > Creative Console Launcher > Mixer and mute any unused inputs (e.g. Line In, Digital In)
4.6 Go to Start > Programs > Creative > Creative Console Launcher > EQ and unselect Enable EQ
5. Installing EAX Unified and OpenAL
5.1 Download EAX Unified version 4.0.0.1 from here and install it
5.2 Download OpenAL Windows Installer 1.1 from here and install it
5.3 Restart your computer
6. EAX Testing
6.1 Download the Star Wars: Empire at War demo from here and install it
6.2 Run the Star Wars: Empire at War Demo and go to Options > Audio. You should see EAX 1, 2, 3 and 4 as supported and selectable
6.3 Download the Quake 4 Multiplayer demo from from here and install it
6.4 Start the Quake 4 Multiplayer demo and go to Settings > System > Advanced Audio Settings and set Sound System to OpenAL then click Close Advanced Audio
6.5 After the sound system re-initializes, press CTRL + ALT + ~ to open the console, then press Page Up four times and you should see that the game is now using EAX 5.0 via OpenAL
Assuming the tests were successful, your system should now be fully configured to run EAX and OpenAL games.
The attachment SWEAW_Demo.jpg is no longer available
The attachment Quake4_Demo.jpg is no longer available
For clarity, I put this guide together because Creative's latest official drivers for PCIe X-Fi Titanium sound cards have some issues with games that use OpenAL. Specifically, those drivers would occasionally cause sounds not to play in such games. This is why I'm using an older driver version 2.17.0008 from 2010 which doesn't have that problem. As far as I can tell, this problem doesn't effect PCI X-Fi cards, so you should be able to use the latest official drivers with those without any issues.
Final note: some games (e.g. Quake 4) change the Windows speaker configuration to "Desktop Stereo Speakers" when started for the first time. If you're using surround speakers or headphones, you may need to quit the game, and repeat step 4.2 to re-set the speaker configuration to your liking.
Reply 1 of 12, by Joseph_Joestar
This post is reserved for listing the X-Fi Titanium models that were confirmed to work with this guide:
  • SB0880 (retail X-Fi Titanium) - confirmed working by me
  • SB0886 (X-Fi Titanium Fatal1ty Pro) - confirmed working by me
Reply 2 of 12, by Joseph_Joestar
Minor update: I've re-structured the steps slightly, to make a few of the sections self contained.
Among other things, this allows sections 4, 5 and 6 to be applied to PCI X-Fi cards as well, assuming you have the correct drivers installed. As noted earlier, PCI X-Fi cards don't suffer from the OpenAL issue that affects their PCIe counterparts. So it should be ok to use the latest official drivers from Creative's website for X-Fi PCI cards .
Reply 3 of 12, by gmaverick2k
Thanks, replaced my xonar dx with x-fi titanium in my xp build, v. useful guide
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 4 of 12, by Joseph_Joestar
gmaverick2k wrote on 2025-07-13, 15:15:
Cheers!
Out of curiosity, did you notice any difference in how EAX sounds between the two cards?
Reply 5 of 12, by gmaverick2k
Joseph_Joestar wrote on 2025-07-13, 16:07:
Cheers!
havent gotten to the stage of testing eax fully. Only tried F.E.A.R, farcry (which is eax 2), wc3 with eax. With headphones the x-fi titanium is clean even when i've connected though my speakers aux port. the xonar dx I found to be very crisp sounding as its given more juice from the floppy connector.
Reply 7 of 12, by Joseph_Joestar
Barley wrote on 2025-07-13, 18:43:
Thanks! Do you recommend this method over just installing the Daniel K driver pack?
I had occasional issues with the Creative Console Launcher when using DanielK's X-Fi pack under WinXP. It would sometimes freeze up, and I had to close and restart it. No such problems with the version included in this guide.
That said, this might have been a local issue on my end, and not necessarily related to DanielK's pack. I haven't investigated it thoroughly. But I never saw it again after downgrading the driver and utilities to the versions listed here.
Reply 8 of 12, by Barley
Joseph_Joestar wrote on 2025-07-13, 18:50:
Thank you again. Would you recommend following your guide for Windows 7 as well (I'm dual booting XP and 7 and am following these steps on the XP side)?
Reply 9 of 12, by Joseph_Joestar
Barley wrote on 2025-10-16, 15:58:
Technically, it should work, but I haven't thoroughly tested this driver and the accompanying utilities under Win7. You would also need to download and install Creative's ALchemy, as it isn't covered by this guide.
By the way, at one point my card somehow reverted to a generic audio device under Win7, as if the driver had been uninstalled. To be fair, I was testing different versions of Nvidia drivers at that time, so maybe uninstalling/re-installling Nvidia's High Definition Audio component somehow messed up the X-Fi drivers, but I can't be sure. Completely uninstalling and re-installing the X-Fi drivers fixed the issue. For reference, that never happened under WinXP, where I was also doing the same Nvidia testing.
Lastly, I rarely play EAX games under Win7, except for the few DirectX 10 capable titles such as BioShock. So I don't have a whole lot of information on how this driver would behave there, aside from the odd issue that I mentioned above. If you do end up trying it, feel free to share your experiences here.
Reply 10 of 12, by Barley
Joseph_Joestar wrote on 2025-10-16, 17:23:
I will share if I try it.
All of my games will be on the XP side, but I will install select games in Windows 7 to play around with the various widescreen fixes, mods, and unofficial patches that are not compatible with XP 32-bit.
Reply 11 of 12, by Barley
Barley wrote on 2025-10-16, 17:30:
I ended up using the Daniel_K drivers for my Windows 7 install. It's working fine, but I meant to ask you: do you ever change the audio mode (for instance, for listening to music or watching movies)? Ideally, I'd want to use Entertainment Mode for these tasks (I like enabling SVM for movies especially). However, most of the time I forget to change the mode manually, and the Creative AutoMode Switcher is temperamental for me.
Reply 12 of 12, by Joseph_Joestar
Barley wrote on 2025-10-21, 15:29:
I do sometimes watch DVD movies on my WinXP rig, and it does make sense to switch to Entertainment Mode in that case. However, be sure to change back to Game Mode when playing games, as both other modes top out at EAX 3.0 and lack other game related functionality.
This is explained in Creative's help/manual files from the official driver CD. And if you want even more info on EAX and X-Fi cards in general, I highly recommend downloading the X-Fi Demo Disc. Although this one came with the Elite Pro model, it works just fine on my Titanium Fatal1ty PCIe.
