Reply 620 of 1150, by PC@LIVE
- Oldbie
As a friend of mine from retroHW pointed out to me, in 478 uATX cards there are usually only two DDR RAM banks, this is quite common, maybe 🤔 there are also some with three or four RAM slots, however considering that the maximum installable, usually is 2 GB 🇬🇧, only two banks are enough to reach 2 GB 🇬🇧!
From what I remember, apart from the RIMMs, there are no other types of memory on the 478, except for the first versions that had SDRAM, I think there are also cards with SDRAM and DDR, they are probably PCCHIPS with non-Intel chipsets, on this I would like to briefly make a hint.
In my opinion, a card with an Intel chipset is preferable, but for non-specific uses, you can very well use a VIA or SIS chipset, I think there could be 478 cards with ATI or NVIDIA chipsets, but I'm not sure.
Instead, there are few motherboards, with PCI-E instead of AGP, I have an ASROCK with a VIA chipset, but I have to work on it to solve a problem, and make it work (let's hope so!).
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
