Reply 420 of 534, by TgamesFR
rasteri wrote on 2024-12-16, 18:24:TgamesFR wrote on 2024-12-16, 17:41:Indeed as visible on logs it see my KVM but he have issues parsings keyboard and mouse plugged on it.
Here the logs you requested :Ah, your mouse uses 16-bit positioning data, support will likely come in next hidman firmware version.
What make/model of kvm switch is it?
Thanks for your answer.
Also i've rechecked on my keyboard arrow keys not working too in "81 Key Mode".
For my KVM it's from Aliexpress i have since over 15 years.
Model No: KVM-21UA
https://aliexpress.com/item/1005003020917318.html
It's a very cheap one but really works never got any issue with older Windows 98, Me & 2000.
All keyboards/mouses i've plugged on it since i have never got a single issue.
Like others KVM it's plug and play nothing to install.
Main reason i got it 15 years ago was full compatibility and stability with very old Windows and the cheap price ofc 🤣.
Even if it says USB 2.0 it works fine with USB 1.1 ports and devices, while ago i had a PC with low speed ports and devices and it was working too.
