Reply 55481 of 59894, by Wes1262
what could be causing a gpu to artifact slightly during the post screen, but work perfectly in 3d and in windows? no artifacts at all that i could notice. It's a Geffo 256 SDR/SGRAM
Reply 55483 of 59894, by bestemor
keenerb wrote on 2024-12-15, 16:20:
devius wrote on 2024-12-15, 16:09:
A Socket 370 board with 6 ISA slots??
That's exactly what I said. So much room for activities!!!
And look at that deep infestation of yellow mushrooms all over the place, just itching to explode 🤯
Now that would create a lot of activity .
Reply 55484 of 59894, by Kahenraz
bestemor wrote on 2024-12-15, 19:36:
And here I thought I had the ultimate 440BX with five ISA slots. This one has be beat!
Wonderfully obnoxious and gratuitous overkill with 5 ISA slots and a Tualatin
Reply 55486 of 59894, by BitWrangler
Media storage day *tap tap tap* yup this ware is hard, I can touch it.
Got one of those generic 3.5 double row boxes, hoping this is a sturdier one, I discovered one I had had got the lid cracked up and popped a hinge, from only having one more layer of disk box on top of it.
Then these really appealed to me, a lot of my 5.25 stash is in really shabby card retail 10 pack sleeves so harder storage more gooder. Kodak, pioneers of the digital camera who didn't think it would go very far so doubled down on film and went bust 🤣 They used to do disk media too. These cases fold open and splay so you can look through disks easy. 4 of them there.
Both came with a small amount of disks, a project manager and planner on 3.5 and PC Mag disks and a Norton Commander type shell thing, some programming stuff. Will have to give my 5.25 on the XT a clean to make sure it has a good shot at trying to read stuff.
Reply 55487 of 59894, by Ozzuneoj
I'd much rather have a board covered in those than a board covered in these. 😁
If none of those tantalums go boom in the first few minutes of running they'll probably last another 25 years without degradation, assuming the system is powered on from time to time. The fact that DFI used so many tantalums is a sure sign that the ITOX3 was an expensive industrial board meant for situations where marginal aluminum electrolytics wouldn't be sufficient.
I have one of these boards myself and I have been waiting for a Via C3 1.2Ghz to fall into my lap to complete the system. Another user did a similar build and I believe it turned out really well. I actually made up a list of the possible soundcard combinations for it. My goal would be to have the largest variety of hardware MIDI and FM synths possible in one computer (without some crazy ISA backplane setup...). 😁
Reply 55488 of 59894, by AppleSauce
BitWrangler wrote on 2024-12-17, 00:25:
Media storage day *tap tap tap* yup this ware is hard, I can touch it. […]
Oh wow you have the exact same floppy storage container I do.
I think I found it in an op shop ages ago , they do come in handy.
The attachment 20241217_202047.jpg is no longer available
But I also have a 5.25 drawer a friend helped me get , I'm not sure if it is technically for photos or disks but it works well enough and looks cool.
The attachment 20241217_202104.jpg is no longer available
Reply 55489 of 59894, by Nexxen
AppleSauce wrote on 2024-12-17, 12:15:
POSSO drawers. I have one 5.25 and 2 3.5. They come black and grey.
I've been looking for 5.25 for quite some time but either the price is high or shipping is higher than a supercar.
They have a full range of products, VHS, audio tapes, HDDs (IRC). Stackable 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 55490 of 59894, by H3nrik V!
I think, back in the days with Amiga 500, we used to remove those partioning plates from those boxes, thus having room for a whopping 100 diskettes! 😎
[Edit] quoted the wrong image
Reply 55491 of 59894, by AppleSauce
Nexxen wrote on 2024-12-17, 12:41:
POSSO drawers. I have one 5.25 and 2 3.5. They come black and grey. I've been looking for 5.25 for quite some time but either th […]
Ah okay , good to know , are they somewhat sought after?
looks like they even had a CD one.
https://www.etsy.com/au/listing/1069268644/po … listing_details
Reply 55492 of 59894, by PcBytes
Arrived today:
- Matrox Parhelia 512 128MB - works although HDMI output looks pretty bizzare... not sure if it's a issue with the card or my DVI adapters are downright incompatible with this thing. No artefacts so that's a good sign
- FIC PA-2013 - needs recap, looks okay-ish otherwise. Can't figure out the revision exactly - I can tell it's a REV2 board (no LM75 onboard) but that's it. No idea whether it's the one with AGP issues or not.
- Commate S7AX - same, even as far as I won't even attempt powering it on until I recapped it. Last Commate board I had (a SiS 530 based one, S7SXB) killed TWO K6-2 chips I had, and its own chipset. Not repeating the same mistake twice.
- Soyo SY-5EMA+ v1.1 - also needs recap, looks good otherwise.
All are a bit rusty on the ports but nothing some sandpaper won't fix.
Reply 55493 of 59894, by Nexxen
AppleSauce wrote on 2024-12-17, 13:01:
Ah okay , good to know , are they somewhat sought after? […]
Sought after, IDK, but they aren't that easy to find. I bough the 2 3.5 floppy drawers for 20€.
Reply 55494 of 59894, by AppleSauce
Anyways speaking of stuff I got recently , I have joined the x68000 club and I'm in the process of getting upgrades and peripherals for it ,
but I'm already at the point that it softboots , runs games from both drives and has a working keyboard and FM audio and also SFX.
The attachment 20241214_145416.jpg is no longer available
The attachment 20241214_151901.jpg is no longer available
I've wanted one for ages but bit the bullet not that long ago and went through a pretty stressful journey of repairs and setup , but it's now mostly working.
While the software is all mostly in Japanese which is a bit of a barrier , the operating system is very much like DOS which makes it feel a bit more familiar.
The attachment 20241214_155032.jpg is no longer available
I do have a SACOM midi card on the way and a trackball mouse , but I've heard the SACOM might have compatibility issues even though it has the exact same midi interface chip as the sharp midi card so I'm not sure what that's about.
But I guess I can always spring for an sharp one if I can get one for an okay price.
Either way I've got a pretty potent midi stack including a CM32P that I also got not long ago to upgrade the 32L to a CM64 and the PCM expansion cards that work with gemini wing so I'm very much looking forward to listening to some of that well composed music.
The attachment 20241218_003055.jpg is no longer available
Also the NEC Multisync has technical issues and probably is going to need a good service very soon.
Reply 55495 of 59894, by PC@LIVE
Tomorrow I'm going to pick up a batch of three motherboards, and today I ordered three more, I hope that among these I can make at least two or three work, I don't remember batches with all the boards working, except cards that I bought individually, and then I managed to make work.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 55496 of 59894, by AGP4LIfe?
Picked up another Geforce 3 from the bay, I have such a huge soft spot for GF3's for some reason.
I find this unit particularly interesting.
Its a Gainward Geforce 3 Ti 200 128MB Golden Sample. Its quite fast for a GF3 & 128MB version.
GF3Ti 200 64MB -- 175 Core / 200 Mem
GF3Ti 200 128MB -- 175 Core / 200 Mem
GF3 Std 64MB -- 200 Core / 230 Mem
GF3 T2 GS 128 -- 210 Core /240 Mem --
GF3 Ti500 64MB -- 240 Core / 250 Mem
The attachment GF3.png is no longer available
As you can see its Factory overclocked on both the Core and Mem ABOVE even the standard GF3 Clocks, but carries the Ti 200 Badge.
Zoom Zoom.
It gets more interesting. Even though it carries "Ti 200" In the name, the core is actually a GF3 standard core! not a Ti 200. Which given the large factory overclock makes sense I guess. Pretty neat. Meaning this is actually a GF3 Standard with 128MB of ram! in disguise! 😁
The attachment GF3C.png is no longer available
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 55497 of 59894, by AGP4LIfe?
I also picked up an excellent condition Creative CT6971 Geforce 256 DDR 32MB, from across the ocean for a great price.
Going in a Pentium II 450 build. Another huge soft spot for these.
Reply 55498 of 59894, by Kahenraz
Besides being a collector's item, I never understood the draw of the 256 DDR versus a GeForce 2. Technically speaking, there isn't any driver advantage and it suffers from all the same problems as all post-TNT cards in Direct3D 5 games.
For Windows 9x retro machine with slower CPUs, my go-to is a TNT2 for compatibility or a GeForce 2 if I want TnL and better performance.
Reply 55499 of 59894, by BitWrangler
It on left side of arbitrary round number other GPU on right side of arbitrary round number.... i.e. fastest card of the the Nineteen hundreds... if you want to LAN Party like it's 1999.
