Best CGA & Hercules monochrome games
Reply 320 of 343, by Jo22
BitWrangler wrote on 2024-07-16, 17:44:
rmay635703 wrote on 2024-04-16, 21:49:
The frustrating aspect of CGA is that it had a leftover 384bytes of ram that was used for very little […]
Jo22 wrote on 2024-02-20, 11:37:
Thanks, I admit I have a bit of a love/hate-relationship with CGA. One one hand, I love to tinker with it, while simultaneously […]
One one hand, I love to tinker with it, while simultaneously wished there was "more".
There were missed opportunities so to say.
Like a 4 colour mode for 640x200 resolution or a 640x400 mono mode.
Both would have helped at increasing the level of detail in games back in the day.
Ok, strictly speaking, such CGA modes do exist!
..just not for official IBM CGA. 🙁
640x200 4c is being part of Plantronics and Tandy/PCJr, which are "Super CGAs" of some sort.
Plantronics has full 32KB of RAM, for example.
The full RAM expansion that IBM CGA should have had from very start.
I'm saying this because IBM CGA uses 16KB of RAM, but has an 32KB wide framebuffer slot.
Ie, it uses 16KB for graphics data, but it's being doubled (the cause was incomplete address decoding, I assume. A hardware bug).
Some games/applications may even depend on that mirror copy, not sure.
At a minimum IBM could have had all 4 colors palletized into the 16 available allowing for pallette rotation and other tricks but they instead used a strange selection of very limited fixed pallets with only the background selectable.
384 bytes (which conviently align pretty well to rows) is enough to have a full 192 pallet changes per screen (without extra cpu overhead)
Even with 4 colors out of 16
if 192 of the 200 lines vertical resolution could be palletized independently would allow for some amazing effects despite the per line limitation.
Lots of possibilities if ibm would have been motivated to make their hardware as flexible as possible within the limitations of the time.
Maybe 50 cents of added cost would have made CGA much more user and programmer friendly CGA had more logic than it needed, streamlined for functionality it could have been much more interesting
I think there was a lot of first rodeo with the video chip and get it out the door before New York cancels it stuff going on. They did try a lot harder with EGA
Hm. Since we can't change the CGA logic postmortem, maybe the extra memory can be used to hold header information, at least?
I know this isn't necessary, because a dump of CGA video memory on disk isn't being limited to same filesize as physical bideo memory.
But it would be acceptable "filling material", maybe.
Provided that it doesn't cause any visual much distraction on screen.
Because, having a clean 16 or 32 KB memory dump including all header information might be nicer than dealing with odd numbers.
Or maybe we can change CGA circuit a bit, postmortem?
I mean, if the vintage computing community comes to a consensus, maybe a fix for IBM CGA board could be designed after all those years? A CGA 2.0?
To get away with certain design choices that caused issues or unnecessary limitations?
640x200 4c mode? More palettes?
It should be something that's well documented and applicable to CGA clones, too.
Some sort of revised CGA specification, which in 99% of applications doesn't break compatibility.
It would need time, I suppose. It shouldn't be rushed, considering the historical relevance.
These are just some thoughts, of course.
Reply 321 of 343, by BitWrangler
Let's just copy Tandy's, Amstrad's or Plantronics' homework.
Reply 322 of 343, by Jo22
BitWrangler wrote on 2024-07-16, 19:09:
Fair enough. Plantronics is closest to IBM CGA, I think.
Also in terms of release date. It was been released shortly after CGA.
Plantronics had offered an upgrade to full 32 KB of video RAM, for example.
IBM CGA had 16 KB physical memory, but occupied 32KB. So the 32KB frame buffer had been there right from the start.
It's as if 32KB had been period correct.
Tandy 1000 and Schneider PC1512 had different memory layouts and no real Motorola CRTC, unlike Plantronics Color Plus.
That being said, there are differences between those two.
Just doing a Plantronics clone isn't the goal, maybe.
It's rather about fixing CGA to unleash its existing potential that had been sealed away in the past 40 years.
Reply 323 of 343, by jasa1063
I fondly remember playing Broderbund's Shufflepuck Cafe on Hercules graphics back in the 80s.
Reply 324 of 343, by OldCat
Benedikt wrote on 2024-07-08, 12:34:
Have you published the source code somewhere or (if not) have you considered doing so?
Is it a purely interpreting emulator or does it incorporate dynamic binary translation, too, where applicable?
No, it's a misunderstanding - I only played GB emulator on one of my Toshiba luggables with plasma screen. I was sure it was T3100 with CGA screen, but I may have misremembered and it was T5100 with EGA. See bellow.
DEAT wrote on 2024-07-16, 03:03:
This looks like no$gmb, but I have not come across any version of no$gmb that has Hercules support. Interesting!
It was no$gmb, thanks! Couldn't rememeber for the life of me the name. But as I wrote above - definitely not Hercules, I thought CGA, but it may actually have been T5100 with EGA graphics card and four shades of orange plasma screen. It would make sense then: four shades of orange mapping well to four shades of gray/green on Gameboy. So probably that.
Apologies for the confusion, everyone.
Reply 325 of 343, by OldCat
jasa1063 wrote on 2024-07-16, 19:46:
Thanks for sharing!
Reply 326 of 343, by mkarcher
OldCat wrote on 2024-07-17, 10:42:
I looked at your photo in detail. I seem to be able to identify the pixel grid. It looks like the 160*144 gameboy image is placed in a 320*200 frame, and displayed on a 640*400 plasma panel. This perfectly fits the specification of the T5100 display. The T3100 only had two shades. I wonder how they displayed EGA 640*350 on that panel. Letterboxing EGA on a display with square pixels will result in an extremely wide image
Reply 327 of 343, by DEAT
I decided to check this further since nocash never supported EGA in his emulators, and it turns out I was wrong: no$gmb does support CGA and Hercules! For some reason it's not documented anywhere and there's no settings to change it in the last version (v2.5), unlike his other emulators which do have CGA/Herc support.
Somehow I didn't notice on the history page that v1.3 had added CGA and Hercules support - I decided to dig through every DOS version listed and the F1 help page for every version from v1.3 to v2.3 lists CGA and Hercules support, though it turns out every version from v1.3 will auto-detect the video mode - when you run no$gmb /? on v1.3 and v1.4 specifically it also mentions that you can use the /c parameter to force CGA support, and /h to force Hercules support. Turns out those parameters do work on v2.5 as well!
This is definitely a bad case of misinformation from my end - apologies for that. I've updated my previous post with additions.
win16.page | Twitch
Reply 328 of 343, by OldCat
Okay, now that you mention it, something unclogged in my memory. So I used to play CGA games on T5100 with EGA, because it had four shades of orange intensity on the screen (as opposed to only two on T3100's screen). Similarly, I played EGA games on my T3200SX with VGA screen, but with sixteen shades of orange, so that there is one-to-one mapping instead of forced dithering. Someone could cal that weird, but what can I say, I really like these plasma screens. There are weirder fetishes out there.
So coming back to no$gmb - I remembered that I played it on T5100 in CGA mode so that four shades of green from GB map one-to-one to four colours of CGA that will then map one-to-one on four shades of orange on T5100 plasma screen. And that is what my screenshot actually shows. QED. Thank you for prodding my memory!
Reply 329 of 343, by OldCat
mkarcher wrote on 2024-07-17, 19:55:
Hey, thanks for being investigative! Your reasoning is 100% correct.
I would check that mode, but I don't have that machine anymore.
Reply 330 of 343, by Thandor
I came across another one that runs in CGA and hasn't been mentioned in this topic! Dangerous Dave 😀. Photo is taken on actual hardware (ARC ProTurbo 88 with Tulip CGA monitor, on-board videochip can be configured for MDA/CGA/EGA. Originally came with MDA monitor.)
Interesting phenomenon is that Dave flickers when he's moving in the upper part of the screen. On the bottom-part he appears to be solid.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 331 of 343, by bocke
Hi peeps.
I came upon this topic this morning, but I'm in a rush, so I haven't read it all. I saw the last page where you asked about improved CGA re-implementations.
Not aware of any improved ones, but I've seen small CGA reimplementations. You can even buy them from Aliexpress. Those are based on other open hardware projects, of course.
This one, for example, is full fledged reimplementation:
https://github.com/hkzlab/CGA_Redux/tree/master
There are also a FPGA based solutions such as Graphics Gremlin:
https://github.com/schlae/graphics-gremlin
This guy even made a HDMI mod to Graphics Gremlin:
https://yeokhengmeng.com/2023/09/hdmi-isa-gra … or-vintage-pcs/
As CGA games are concerned, you might not be aware that there are several new ones on Itch.io. Some are good, some are... Well, people tryed. 😀
Of those good, I'd recommend Cyningstan's "opus": http://dos.cyningstan.org.uk/games.
Most of his games also come with source, including CGA graphic library, input library (keyboard) and a game engine for strategy games.
Other interesting new games I've seem recently were games by Jani Nykänen (yeah, I did copy/paste on the last name 😀)
The Cures of CGA and Mushrooms look amazing. Unfortunately they don't work as well.
Reply 332 of 343, by Jo22
^Hi! Thanks for the tips! 🙂
Btw, there are a few more new DOS games at itch.io.
They might be not all listed, though, because some are ports.
Ie, they exist for multiple platforms and the DOS ports each are just one of the many platform builds and simply use VGA thus, rather than CGA.
Here are some games:
https://itch.io/c/443894/modern-dos-games
The DOS version of the game The Curse of Rabenstein was reviewed by user root42 a few years ago, for example.
https://www.youtube.com/watch?v=TDACdY9xz4k
@OldCat I've run Kirby's Dreamland on the PC/XT version of no$gmb on a 4,77 MHz PC with on-board CGA and green monitor. CPU was a NEC V20.
So this really works. The 4 shades of CGA palette matched the Gameboy palette quite okay.
Edit: Pics added.
Reply 333 of 343, by bocke
Jo22 wrote on 2024-12-18, 22:19:
Oh, that interested me too. 😀 I saw it (no$gba) a while ago and wondered how would it behave on the real machine.
Looks cool.
Btw, about Chinese CGAs and Book8088 and related stuff, there is a GitHub repo with the information here:
https://github.com/pengan1987/book8088stories
All the projects seem to originate from Chinese electornics enthusiast forum MyDigit.cn and are culmination of sevral years of development. It's basically story of homebrew retro PC recreation. Pretty cool. The translation to English has been done by ChatGPT.
Edit:
there is some info on CGA implementation here:
https://github.com/pengan1987/book8088stories … 8_isa_cga_en.md
Unfortunately, the posts on the MyDigit.cn don't show images or attachements to non-registered users. So I couldn't check if there are any schematics for it. But other articles on the GitHub page have some download links, so it might be included in one of them.
Reply 334 of 343, by Jo22
bocke wrote on 2024-12-21, 03:04:
Looks cool.
Thanks! With an Turbo XT or an 16-Bit PC (8086/V30) performance would be quite in the playable range.
I've played Shantae (GBC) on a 10 MHz 286 with VGA at acceptable speed.
As is, an 4,77 MHz PC is tolerable for playing RPGs. Like Pokèmon or Zelda.
It's certainly cool looking on an 8088 laptop with LC display from the 80s.
If no$gb had partial support for "8080 emulation mode" of the V20/V30 a speed up would be quite noticeable.
That being said, implenting this would be tricky, since the DMG CPU was a Z80 derivative with an extra sound core.
So the emulator would need to decide when to use pure software emulation and "8080 emulation mode".
And that's easier said than done, I suppose.
CP/M emulators had same issue. There were separate versions for V20/V30 and 8088/8086.
The versions using "8080 emulation mode" were very quick, but could not run popular Turbo Pascal 3 and its compiled programs which did depend on Z80 registers.
Anyway, I'm just a layman here.
Reply 335 of 343, by Benedikt
Btw, about Chinese CGAs and Book8088 and related stuff, there is a GitHub repo with the information here: https://github.com/pen […]
Edit:
There is rather comprehensive documentation on what appears to be the current homepage for those CPLD-based CGA cards: http://8086cpu.com/lm6/79.html
Considering that this is a commercial closed-source product, the author is quite generous with the documentation that includes all schematics as PDF, including schematics of the logic implemented using the two CPLDs. Even the PCB layout is available, albeit only in PDF form.
It might actually be possible to lift pin A14 of the 32KiB SRAM, add a wire to an unused pin of the CPLD below it, and add Plantronics ColorPlus mode via a modified reimplementation of the CPLD bitstream, but I really don't have time for that right now.
Reply 336 of 343, by Kekkula
I did try the colony on dosbox and the game seems interesting... but when I try it it on my olivetti m24 I run out of memory error.
Version I found loads metawndo.exe and it takes 100kb memory. Has anyone got the game running in system that has only 640k?
Reply 337 of 343, by Jo22
Kekkula wrote on 2025-05-17, 20:10:
Hi, did you use DOSBox or DOSBox-X?
- Because DOSBox-X supports M24 graphics (DCGA), too.
Re: Olivetti/Logabax/AT&T/Toshiba 640x400 hi-res graphics mode
So the game might be trying to use 640x400 mode on your M24..
The Colony is one of the few games with bative support for it! :)
Reply 338 of 343, by Kekkula
Tried with dosbox-x but looks like version I could find of the game doesn't have cga files.
Dosbox-x starts the game always in ega mode if macine type is set to vga and dcga is run. If you select cga the game just hangs.
Reply 339 of 343, by Kekkula
Here is some secret information that I acquired past few days...
The colony has switch outside the game so one can actually change graphics modes.
So I ran colony /? And was amazed 😮
It showed command options for graphics and for mouse... of course too fast to read and no way to stop scrolling before text got outside the screen.
(I had no way to stop the scrolling since my self made keyboard adapter thingy doesn't support pause key and |more or /P switches didn't work, so I had to grab phone and take picture from start of the scrolling.)
But after running command colony /display:a /mouse:m1 /config I actually got the game to start.
Of course the game works on such low end machine about 2fps speed 😁
