First post, by CallMeRive
So, I have a bunch of Windows 2000 bootable installation discs that I've already used to install Windows on a couple retro-machines (P1).
I have a bunch of CD-ROM drives that work.
But one pretty special motherboard - PCPartner MB520N (35-8258-XX) (graphical BIOS!) - refuses to boot from any Windows 2000 bootable installation disc. The message is always "CDBOOT: Couldn't find NTLDR".
The attachment NTLDR.jpg is no longer available
I tried different CD drives. I tried different discs (all of them confirmed good). I tried burning new W2K discs in ISO 9660, Joliet etc formats with different filename lengths.
What I found out so far:
1. The message might mean that the bootloader cannot find the file \I386\SETUPLDR.BIN on the CD (for example, due to filename format used when creating CD). Described here: https://www.pcreview.co.uk/threads/cdboot-cou … 33/post-1933808 . That's why I tried making disks with Joliet etc.
2. When I boot into DOS using Universal Boot Disk floppy on that machine, I can access the CD and read it, \I386\SETUPLDR.BIN is present and readable.
Reply 1 of 11, by myne
Probably a limitation of the combination somehow. Sounds like the inbuilt 2k cdrom driver isn't detecting it.
Simplest workaround:
Boot from floppy, copy CDROM\i386 to hdd, run setup from there.
I built:
Reply 2 of 11, by Start me up
myne wrote on 2024-12-20, 02:01:
Nope. Windows 2000 has not loaded it's CD driver, yet. If this message is from Windows 2000 then Windows 2000 is still using the BIOS to access the CD content.
Reply 3 of 11, by Cyberdyne
Some BIOSes have a broken implementation of CD booting. Especially some (bad)(no)name motherboard.
Reply 4 of 11, by wierd_w
I'd make, then use a plopboot diskette.
That will give you a much superior eltorito boot experience on broken bioses.
Reply 5 of 11, by CallMeRive
So far I tried to make Windows 2000 installation floppy disks, but failed - I have only 3 working 3.5 diskettes and it needs 4. Ooops!
wierd_w wrote on 2024-12-21, 02:38:
That's a very interesting thing, TY. I've just tried it and it boots from a floppy but then either spits out "Boot record signature AA55 not found (0000 found)" for Windows 2000 CDs or just quietly hangs with a Windows XP CD. I checked that the discs countain a valid boot record, 2048 bytes, ending with 55AA (not AA55, tho).
Again, I tried 3 different CD-ROM drives...
Reply 6 of 11, by myne
Don't overcomplicate it.
Make dos disk.
Format c
Copy i386
Install from c:\i386
Aa55 Iirc is a boot rom signature for bios oproms.
Nfi why you'd get that error.
I built:
Reply 7 of 11, by wierd_w
If this thing really is this cranky, then yes, installing from an i386 folder may well be the best option.
This is if:
El torito fails (funky things even with plopboot. I'd suspect your image isnt bootable, but...)
4 diskette set fails (dont have 4 diskettes)
USB boot media fails (plopboot CAN boot from a usb 1.1 only host, even without bios support. Hold shift key down when selecting the option to force usb 1.1 mode)
An i386 folder on a small FAT volume will bootstrap install, in this 'worst case' situation.
Reply 8 of 11, by CallMeRive
I solved the problem by getting a Gotek (didn't think I would ever need one, but here we are). Case closed, thank you, everybody.
Reply 9 of 11, by myne
Well, you really didn't.
All you needed was a dos boot disc, format a partition, copy files, run setup.
But hey, I'm sure it'll be useful at some point.
I built:
Reply 11 of 11, by myne
Why didn't a dos boot disc work?
I built:
