First post, by sentinel
The documentation in the VDMS.ini file isn't too descriptive. It tells me to change 'buffer' to change the latency. But which increases or decreases latency - I'm not too familiar with the hardware buffers, especially in an emulation setting.
Also, just making sure, that this is what I need to change if the sound is having trouble keeping up with the animation. There are moments when it's lagging, and there are times that it's at normal rate of speed.
Thanks in advance. I *love* VDMsound. 😁
