Reply 40 of 472, by keropi
bertrammatrix wrote on 2024-09-11, 16:30:
Thanks for that...now I can be driven to insanity some more 😁
Was this on dos or windows xx? Right, so the MK just works with the generic drivers then
pure DOS, using unisound
ESS driver refuses to pass any arguments on the IBM ValuePoint system I am testing because it has an early "pnp bios" and you are supposed to use that to allocate resources (and ofcourse it's not possible on the IBM bios 🤣 )
Reply 41 of 472, by quigonhu
Great job guys!
Having the O2LT & O2RED this year. Magnificent cards, both of them!
I have really good memory of using ESS chipped sound cards decades ago. Can't wait for getting this top quality level ES1869 card.
If there is a special version plan, which could make me more eager to obtain one, please let me know-_^
BTW, I don't know if it's proper to ask, do you have any plan on retro PCI sound cards? May AU8830?? 😁
Reply 42 of 472, by keropi
quigonhu wrote on 2024-09-13, 03:38:
Great job guys! Having the O2LT & O2RED this year. Magnificent cards, both of them! […]
Great job guys!
thanks for the ongoing support quigonhu!
we do not have any plans currently for a PCI soundcard, can't say we never do it though 😀
Reply 43 of 472, by Rawit
stacker139 wrote on 2024-09-03, 21:52:
Like the "heart" of a PicoGus card on an add-on board?
If they do that it's practically a Gravis UltraSound Extreme which is also a ESS + GUS combo.
YouTube
Reply 44 of 472, by Paul_V
Marmes wrote on 2024-09-02, 12:27:
3) No SPDIF I/O unfortunately. We decided to keep this out due to cost. But there will be an I2S interface on expansion 😀
Did you happen to run any tests on I2S interface of es1869 ?
I always wondered if it would be possible to use it as an input for MT32pi on a pc/104 soundcard project I'm working on.
Did not have enough spare time to test that idea still.
Reply 45 of 472, by stacker139
1) Same filter as stock ESS cards.
2)This is solved here
GUS emulator on a add-on module with RP2040 (or PicoGUS without DAC):
Can the i2s input interface of the ES1869 (DAC inside ES1869) be used instead of a PCM5100 DAC in front of the i2s output (GPIO pins) of the RP2040?
Project: SB-XXXL, Extensive Sound Cards System
Reply 46 of 472, by bertrammatrix
keropi wrote on 2024-09-11, 17:07:
Thanks. This makes sense, I'm thinking that when I did get it to work under pure dos and got a freeze after it was perhaps something else I overlooked. Looks like the no sound issue under windows is probably something to do with a driver bug or something similar, or the game implements something in a way the ess driver doesn't like
Reply 47 of 472, by bertrammatrix
Great job guys!
PCI would be interesting.... I wonder if it would be "easy enough" when working with sound card chips that were designed to work with the SB-link interface for perfect dos compatibility. Then again, most motherboards that have SBlink have ISA anyways, so not sure what there would be to gain
Reply 48 of 472, by Hackcell
Interesting project! I'm 99% sure I'd end up buying one once it is released 😀
Reply 49 of 472, by mockingbird
bertrammatrix wrote on 2024-09-15, 17:56:
YMF724 with SBLink and a wavetable header would be nice.
(Decommissioned:)
Reply 50 of 472, by crusher
What a nice product as always team Marmes+keropi!! 😀
Can't wait to hold this in my hand...
Reply 51 of 472, by Kahenraz
Subscribing here for future notifications.
I love-love-LOVE the ES692 and the SOLO-1 is itself a fabulous chip. Looking forward to seeing this card come out. I hope that there will be a healthy amount of stock for this chip for lots of new owners.
The SB Pro channel swapping has been mentioned before. I've also read that some games compensate by swapping the channels, but this can conflict with cards that also do this in hardware, causing them to be flipped back wrongly.
Is it feasible to make swapping the channels configurable by a command-line utility for use in a batch file?
For example:
mk1869.bat /stereo LR
mk1869.bat /stereo RL
Reply 52 of 472, by Duffman
@keropi
Any chance you could implement something like this on the card? (the CD-ROM emulation part)
https://www.youtube.com/watch?v=L59Bp61Je4Y
Would be useful for getting CD Audio in DOS without an actual CD-ROM drive.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 53 of 472, by keropi
Kahenraz wrote on 2024-11-23, 22:52:
[...] Is it feasible to make swapping the channels configurable by a command-line utility for use in a batch file? […]
For example:
the ESS chip does not support channel swapping like this from what I have seen :\
Duffman wrote on 2024-11-25, 15:23:
@keropi
this is one of the reasons we have the isa passthrough and usb connector on the card - so anyone can develop any addon they want freely
once this is ready we will also release the specs and files for addon development
Reply 54 of 472, by keropi
New production samples arrived from factory - fresh from the oven 😁
We needed some layout adjustments with the major difference being that the USB port is now a USB-C one , this is was necessary because otherwise in most cases the USB-A port would be obscured. Keep in mind these are samples and we did not want to wait longer to get them - so not all parts are optimal: for example there will be color coded jacks on the black card and some passives will be upgraded - there was no stock but they are on order now)
So the MK1869 looks like this now:
And now for something new: taking inspiration from the original Gravis UltraSound EXTREME card let me present you the MK1869 XTREME
The main obvious change other than color is that the ES690 wavetable gets replaced with a Gravis InterWave 4MB setup.
This one took quite some time to figure out routing so everything fits on a PCB that does not exceed the length of the 16bit ISA slot.
MK1869 XTREME was designed to be a compact yet very capable soundcard and I think that this goal is met 😀
so that's it for now - next step is manufacture a proper stainless steel bracket and ship some preview units so we get some more feedback on both
thanks for looking!
Reply 55 of 472, by Aladim
Looking forward to see both versions in action. Amazing development, and one of my favorite chips with good performance and great compatibility.
Reply 56 of 472, by Aladim
mockingbird wrote on 2024-10-20, 14:07:
YMF724 would be a fantastic choice for a PCI card, and it runs a lot of DOS tittles perfectly. It can be used on later generation motherboards. Most don’t have WT headers, it would be a nice project for a non isa card.
Reply 57 of 472, by Kahenraz
Aladim wrote on 2024-12-24, 18:16:
I have been casually looking out for these for the past couple of years and have only ever found one, so they do exist. They are just exceedingly rare.
The only caveat is that I don't think there are any YMF7xx drivers for Windows 3.1. DOS, 9x (VxD) and WDM drivers exist though. You can probably still get some sound in Windows 3.1 using the DOS drivers, but this is not optimal.
Reply 58 of 472, by mockingbird
Kahenraz wrote on 2024-12-24, 20:27:
Care to back that up with a pic? I have never seen one, and I have seen pics of many variants.
I'm not concerned about Win 3.1... For Win 3.1, build a 486.
(Decommissioned:)
Reply 59 of 472, by igna78
MK1869 Extreme is amazing, the only thing I wish was different is the ability to use memory SIMs (I don't like soldered memory on sound cards) 😉
