The quest for the perfect retro laptop: a saga
Reply 921 of 1120, by vorob
Why? VEXP works with any Chips&Tech video.
Nope, only with selected chips and properly works only with 640x480 and 800x600 resolutions. Even on proper chip, but with 1024x768 panel it just makes squeezed picture bigger, but not full screen.
Toshiba 460 gave me these results:
The attachment IMG_7312.jpeg is no longer available
The attachment IMG_7314.jpeg is no longer available
With bios stretch disabled vexp don’t change games output.
Bios option only affect 320x200 games, 640x480 always place itself in a centre of the screen:
The attachment IMG_7313.jpeg is no longer available
Reply 922 of 1120, by vorob
Hi, got few questions I wanna clarify,
Firstly, could you please explain the difference between the C&T F65554 and the F65550 graphics chips? I noticed the F65554 is used in the current Toshiba 460CDT and my Siemens 710M, while the F65550 is found in the Toshiba 430CDT. What are the distinguishing features between these two 2D graphics cards? I was under the impression that prior to the advent of 3D accelerators, the CPU was responsible for most graphical computations while the GPU primarily handled image output. Is there a way to benchmark 2D GPUs?
Additionally, I have observed that older Toshiba models feature the ESS688 and Yamaha OPL3 sound chips, whereas the newer models only come with the Yamaha OPL3-SA. Could you shed some light on what happened to the ESS chipset in the newer models?
Reply 923 of 1120, by 3lectr1c
Regarding the sound card specifically, the OPL3-SA is not the same as the OPL3. The OPL3-SA is a whole sound chip whereas the OPL3 is just an FM synthesizer, so the OPL3-SAx/SA3 chips have additional features. The earlier Toshibas used the ESS688, which was basically everything that made up a sound chip of the time EXCEPT for the FM synth which it did not have internal emulation for, so pretty much any laptop that uses the 688 will have an OPL3 nearby to handle that.
The OPL3-SAx and similar chips seem great in theory but I've personally had driver problems in DOS and just haven't been able to get it working well, at least on my one laptop with the chip (WinBook XL). Might be issues specific to my machine.
Also, it is my understanding that the ESS 1688 is pin-compatible with the 688, but it does not require any additional hardware as it does FM synth internally.
Owner of https://www.macdat.net, the largest vintage laptop documentation resource on the web!
Reply 924 of 1120, by MAZter
vorob wrote on 2024-09-16, 18:23:
I can only provide fps comparison for some laptops:
TwinHead SlimNote P79TE, 65554 & 200Mhz MMX:
PC Player benchmark 640x480: 14.6 fps
Doom: 64.39 fps
Quake 640x480: 16.8 fps
Duke 3D 1st level street: 46 fps
Nec Versa 6200MX, 65550 & 166Mhz MMX:
PC Player benchmark 640x480: 12.5 fps
Doom: 59.18 fps
Mitsubishi Apricot EL, 65550 & 150Mhz MMX:
PC Player benchmark 640x480: 10.7 fps
Doom: 55.16 fps
Duke 3D 1st level street: 30 fps
Hitachi MX133T, 65550 & 133Mhz
PC Player benchmark 640x480: 11.4fps
Doom: 55.2 fps
Duke 3D 1st level street: 26 fps
Fujitsu LifeBook 635T, 65550 & 133Mhz
PC Player benchmark 640x480: 11.1 fps
Doom: 54.84fps
Duke 3D 1st level street: 17 fps
Toshiba Tecra 510CDT, 65550 & 133Mhz
PC Player benchmark 640x480: 10.1 fps
Doom: 36.45fps
Duke 3D 1st level street: 8.6 fps
Reply 925 of 1120, by vorob
Thanks! But this could also be because cpu is faster. Need to somehow balance them 😀
Reply 926 of 1120, by MAZter
vorob wrote on 2024-09-17, 06:51:
Yes, unfortunately I don't have laptops with similar CPU and different GPU. 65550 & 65554 is very similar, both produced in same time:
https://www.vgamuseum.info/index.php/cpu/item … nologies-f65550
https://www.vgamuseum.info/index.php/componen … s-b65554-hiqv64
Reply 927 of 1120, by Thermalwrong
vorob wrote on 2021-04-29, 21:34:
My God, why can't these laptops stretch 320x200 to full screen?)
You're missing some software, if you get hold of and run stretch.exe on any Toshiba laptop with the WD90C24 graphics chip then it'll stretch out to the full 320x240 / 640x480 with applications / games that display at 320x200 that would otherwise have black bars. I can't find this utility online anywhere other than in this archive of a T4850CT hard drive: https://archive.org/details/toshiba-t-4850-ct
Not the cleanest archive but here's the stretch utility which should work on all WD90C24 equipped Toshiba laptops:
The attachment WD90C24-Stretch.zip is no longer available
That should include the:
  • Toshiba T1950CT / T1960CT
  • T2400CS / T2400CT / T2450CT
  • T4700CT / T4700CS / T4800CT / T4850CT
  • T3600CT / T3400? / and probably some others that I haven't realised.
Just been testing it on the T4850CT / T1950CT / T2450CT / T2400CS and it's good on all of them.
edit: For an installer, the 1RCA72.IMG (RCA72 Companion Disk) floppy image of the T2450CT recovery floppy disks is a proper installer for this. It just puts stretch.exe into the c:\dos directory and you can either type stretch manually or add it into the autoexec.bat
Reply 928 of 1120, by vorob
Thermalwrong wrote on 2024-10-30, 05:21:
Thank you for working on my old message. I'll give it a shot. I remember having a similar utility on my laptop; it definitely stretched DOS text stuff but didn't affect games. I'll try your file. I keep this laptop mainly because of its mouse and its vintage look. However, I'm quite disappointed with its gaming performance, particularly the WSS sound, which I couldn't get to work under DOS. So, it's in the closet, waiting for better times.
Reply 929 of 1120, by stanislavz
Hello. I am lloking for some decent laptop, mostly for moo2, doom, and f29. Plus some latest dos / win98 games from novalogic. Which i run on celeron 300 before
While normally i am thinkpad fan, i do have some old siemens stuff. And there is plenty of siemens scenic mobile laptops. All looks similar case, some shows usb on pentium 166mmx. Some are pentium2 300mhz. Anb beeing siemens - they would be manufactured longer, compared to main stream laptops. So - how do they looks and feels in dos ?
Reply 930 of 1120, by megatron-uk
Thought I'd share my experiences looking for a good all-round DOS laptop. Not surprisingly it mirrors many of the comments already mentioned so far:
Toshiba Satellite Pro 480CDT
- Pentium 233MMX
- (Up to) 160MB (EDO SODIMM)
- 12", 800x600 TFT screen
- PCI C&T 65555 2MB video (BIOS option to stretch full screen + VEXP dos utility)
- ISA Yamaha OPL3-SA3
- 2x PCMCIA/Cardbus, Line in, mic, headphone out, vga, parallel, serial, IR port, PS/2, 1x USB
- One internal drive bay (cd or floppy) + one external drive connector
- (decent) top mounted stereo speakers, volume wheel
Toshiba Tecra 550CDT
- Pentium 266MMX
- 12", 1024x768 TFT screen
- PCI S3 Virge/MX 4MB (BIOS option to stretch full screen only)
IBM Thinkpad 385ED
- Pentium 166MMX
- 16MB standard (think it supports up to 80MB) EDO SODIMM
- 12" 800x600 TFT OR 12" 800x600 FRSTN (aka DSTN)
- PCI Neomagic 128ZV 1MB (BIOS options to stretch full screen + Fn hotkey)
- ISA CS4236B (DOS support)
- 2x PCMCIA/Cardbus, mic, headphone out, vga, parallel, serial, IR port, PS/2
- Built in floppy and cdrom
IBM Thinkpad 600X
- P3 450-600
- (Up to) 576MB (PC100 SODIMM)
- 14", 1024x768 TFT screen
- AGP Neomagic MagicGraph256ZX 4MB (BIOS options to stretch full screen + Fn hotkey)
- PCI CS4297A (AC97 only) + PCI CS4624 (DOS support)
- stereo speakers (under keyboard front)
The two Toshiba models are visually very similar; if they didn't have badges on you would be hard pressed to tell the difference - the 550CDT is a few mm thinner... though that's not saying much - they are both over 2" thick.
The C&T 65555 on the 480CDT offers the ability to scale 320x200 content full screen via the BIOS option, and the VEXP utility offers some slight tweaks to how text modes are displayed, so it's really not bad at all. It will not scale 640x480 content up to native res (so for example Sim City 2000 looks similar to the unscaled Doom II image below):
The attachment 480cdt_scaling.jpg is no longer available
The Neomagic chips can scale both 320x200 and 640x480 content to (mostly) fit full screen via the BIOS option, and has the bonus of being able to do this on-the-fly using the Fn+hotkey combination:
The attachment 600x_scaling.jpg is no longer available
The Thinkpad 385ED is, in my case, severely let down by the FRSTN screen - you really don't want one of these for games at all... but the scaling does work (including via Fn+hotkey), if you are a masochist and want a DSTN screen:
The attachment 385ed_scaling.jpg is no longer available
The S3 Virge/MX on the 550CDT has a basic BIOS stretch option, but it's not great - probably the worst of the models I've tested so far. Unfortunately that machine has also proven the most fragile - the first time I took the original HDD caddy out to replace the internal drive (which had some dairy farmers milk-management system installed!) the ffc cable disintegrated, and I have no way of using a HDD with it at present:
The attachment 550cdt_hdd.jpg is no longer available
The OPL3-SA audio on both Toshiba machines is, as you would expect, first-class in terms of DOS support and sound quality. The CS4236B on the 385ED is fairly decent sounding - most people would be quite happy with it, and the initialisation tools are easy to use. The CS4624 on the 600X does have DOS initialisation tools... but the FM quality is absolutely hopeless - try playing the Descent or Duke3d setup routines and you can hear immediately that most of the notes are wrong, or in some cases, completely missing. It's not an option, IMO.
Both Toshiba models are susceptible to battery leakage. The 480CDT has two batteries under the front left of the keyboard, and they are pretty easy to remove. The 550CDT on the other hand just has one, but it's at the rear right , in front of the LCD hinge and requires the entire system to be stripped down - it's far more involved. Fortunately both systems in my case were not damaged (the 480 had started to leak along the battery cable itself, but this was cleaned easily, the 550 had no leak at all - but I still removed the batteries).
My needs are perhaps a little more niche than some of those listed so far; I want a mainly-DOS system, compact, with solid SB-compatible audio and good sounding FM. Must have PCMCIA support in DOS with audio line-in to mix Roland SCP-55 audio with the onboard digital/fm output. I don't have any requirements for Windows 95/98 performance.
From the evidence so far, putting aside any theoretical performance or edge-case compatibility issues (let's face it - any PCI/AGP vga adapter is going to be more performance than virtually any DOS game will need), if you want full-screen scaled video in DOS, then a Neomagic or C&T chip is the way to go. So far I am preferring the 480CDT as the best option... though if you were to find a 385ED with the TFT screen it would be a decent choice. (it's even chunkier than the Toshiba models though....)
The next model I have on the bench is a Thinkpad 240, but this currently has a broken screen - all working except the screen. So I'm trying to source a replacement (but it's proving difficult).
https://www.target-earth.net
Reply 931 of 1120, by 3lectr1c
The Virge MX scales excellently on my Kapok laptop with it - weird. Must be a BIOS thing then.
Reply 933 of 1120, by megatron-uk
I've got two more laptops to add to the list:
IBM Thinkpad 240
- 10.4" 800x600 TFT
- Celeron 300/366/400
- 64-192MB (unofficial support to 320MB)
- PCI 2MB Neomagic 128XD
- PCI ESS 1946 Solo-1
IBM Thinkpad 240X
- 10.4" 800x600 TFT
- Celeron 450 / Pentium III 500
- 64-192MB
- AGP 2MB Silicon Magic LynxEM+
- PCI CS4281 (+CS4297 AC97)
Both models offer a HV expansion option in the BIOS which scales both VGA 320x200 and SVGA 640x480 to full screen. Sadly, unlike earlier Thinkpad models, the ultra-compact 240/240X lost the Fn+Hotkey combo which toggles the expansion mode whilst running.
The screens are shared parts between the two models, so are identical in terms of brightness/quality (I've actually used the screen from the 240X to temporarily repair my 240). Scaling performance from both chips appears largely the same; not great, but at least having full-screen, border-less options. I can live with it:
240
The attachment 240_scaling.jpg is no longer available
240X
The attachment 240x_scaling.jpg is no longer available
The CS4281 chip in the later 240X does technically have DOS support (CS4281-CM DOS driver required), but I've been unable to get it to work in the Thinkpad (https://www.dosforum.de/viewtopic.php?t=7100). The CWRDOS.EXE initialisation tool won't set up the chip properly - tried without memory managers, with only XMS, with XMS+EMS, every combination possible and it won't fully initialise. This makes it completely useless as a DOS gaming device.
The ESS Solo-1 in the earlier 240 on the other hand works great in DOS. There are a few hurdles to jump through to configure it (ESS Solo-1 easy(ish) setup with ESSOLO.INI (No Windows/ESSOLO.SYS Required!)), but it seems to work nicely afterwards, and with that distinctive 'ESS ESFM' sound.
Both laptops suffer from a tiny onboard mono speaker which doesn't do the audio justice - but you can always use headphones (the full set of ports: mic, line-in and headphone-out are all present).
I suspect I'll be leaving the 240X 'headless' and be putting the 240 through its paces with my list of games to test how it handles them (including testing loopback audio mixing of the Roland SCP-55). It has the major advantage over the Toshiba models of being absolutely tiny, and not weighing as much as a small child....
Reply 935 of 1120, by 3lectr1c
I discovered the other day that my Brother Meritus A53 laptop does near-perfect DOS scaling, in spite of having a Chips & Tech 65555 video chip. Yes, it can even play Keen 4 without the overlay in the top left corner glitching. Keen text still looks slightly off if you look really close but you can hardly tell. A million times better than any other C&T laptop I've seen.
Take a look at the attached photos.
It has an OPL3-SAx, so audio sounds good of course. That being said, it has all the same infuriating driver issues that my WinBook XL with the same audio chip has. I can never get it to work fully reliably - I constantly have to run the SETUPSA /S multiple times to get audio to *actually* work, and it still glitches in some programs. For that reason I actually prefer my ESS laptops just because even if they're technically not 100% perfect, they're like 98% perfect sound-wise and I can't tell the difference.
Anyways, still an excellent DOS machine, my grumpiness about the OPL3-SAx aside. Good keyboard, decent speakers, all the ports and drives you could want. Lackluster build quality, but nothing a bit of epoxy can't fix.
Biggest problem is that you won't be able to find one - this particular laptop is very rare. One showed up on eBay a few months ago, I was curious just as to what the heck it was, so I bought it.
See my website here for more info and detailed specs on it: https://macdat.net/laptops/brother/meritus_a53.html
The attachment a53_01.jpg is no longer available
The attachment a53_02.jpg is no longer available
The attachment a53_03.jpg is no longer available
The attachment a53_04.jpg is no longer available
The attachment a53_05.jpg is no longer available
Reply 936 of 1120, by vorob
3lectr1c wrote on 2024-12-28, 06:25:
It's certainly not a perfect scaling. Picture is squeezed. Proper one is scaled to fullscreen.
Sample from my collection. Left is good scaling and right one is bad, inproper.
The attachment photo_2024-12-28_12-37-15.jpg is no longer available
The attachment photo_2024-12-28_12-40-40.jpg is no longer available
Reply 937 of 1120, by megatron-uk
I may have to update my report on the Thinkpad 240 - whilst FM does work, I was a little premature in announcing the ESS 1946 / Solo-1E worked perfectly.... I'm unfortunately not able to get any digital/fx/soundblaster audio from it at all.
All of the posted ESS drivers (multiple versions of essolo.sys, essolo.com, as well as the pciset .bat based method) result in no soundblaster output... and worse; the essolo.com driver repeatably locks the machine with every variation of config that I've tried with it.
I'll keep persevering with it, as the combination of a 240, a 240X, a replacement screen and a new power supply has not been cheap!
Reply 938 of 1120, by 3lectr1c
vorob wrote on 2024-12-28, 09:38:
It's certainly not a perfect scaling. Picture is squeezed. Proper one is scaled to fullscreen. […]
You want the type of scaling that this laptop and your Siemens Nixdorf does - the fullscreen scale breaks the aspect ratio. That’s what causes games like Keen 4 to glitch and text to get all messed up. DOS games weren’t even designed for 4:3, they’re 320x200/640x400. The most accurate scaling is that which preserves the aspect ratio so nothing gets stretched out of proportion.
If you just prefer to play fullscreen with the messy text, then that’s fine, but is not accurate scaling.
Reply 939 of 1120, by vorob
3lectr1c wrote on 2024-12-28, 16:18:
It seems like there's a bit of confusion here. The 320x200 resolution, often referred to as Mode 13h, is indeed a limitation of the hardware at the time. However, games were developed with the intention that they would be displayed on 4:3 CRT monitors. These CRTs naturally stretched the "wider" 320x200 resolution to fill the 4:3 screen, making the aspect ratio appear correct to the viewer.
While the technical resolution is indeed 320x200, it's important to remember that the developers designed their graphics and layout with this vertical stretching in mind. So, what might seem like inaccurate scaling today was actually how the games were meant to be viewed back then. When you force a modern LCD to maintain the 320x200 aspect ratio, you’re essentially seeing it in an unintended way that doesn't reflect the original experience.
Check this for example: https://doom.fandom.com/wiki/Aspect_ratio
