Reply 440 of 539, by rasteri
TgamesFR wrote on 2024-12-21, 03:45:Now the only remaining thing is the 16-bit report for fixing my mouse indeed =).
16bit mouse support has been merged. Seems to work on my two mice that use 16bit.
rasteri wrote on 2024-12-28, 21:38:Yeah as you say there's a 12MHz crystal. That's the only real change.
OK - Thanks a bunch.
It sounds important so I'll order new PCBs, but the HASL-free front and back plates in black are $16 extra fee per side. 🙁
I already have front/back plates but didn't order them in lead-free. I didn't think about touching them so I wish I spent the extra money back when I originally ordered them...
sofakng wrote on 2024-12-28, 23:59:I already have front/back plates but didn't order them in lead-free. I didn't think about touching them so I wish I spent the extra money back when I originally ordered them...
It's not a massive issue really, just don't go licking it.
Or if you're that worried, coat them in clearcoat
Makes sense. Thanks! 😀
sofakng wrote on 2024-12-29, 01:39:Makes sense. Thanks! 😀
Oh actually - the new plates have the LED and button in the same place, if you don't have this then get the new ones
Hey hey, I’ve been out sick for a few weeks - feeling better finally. I was able to get 11 boards finished up. Still need to program and test but getting closer to getting them up for sale for those who want to buy one pre-assembled.
I got the LEDs reoriented and everything looks great on each board. I have some extra parts even (since some of the components can only be bulked bought from LCSC).
Thanks for all the hard work on the firmware. You guys rock!
rasteri wrote on 2024-12-28, 23:45:16bit mouse support has been merged. Seems to work on my two mice that use 16bit.
Thanks for adding support for my 16bit mouse, indeed it works for me too (pointer, left, right, wheel and middle button).
Althought i've encountered 2 issues :
[1 ] Now HIDman power devices on my KVM only 1 times on 4.
Before it was always working, so i need switch ON/OFF the KVM multiple times until it get fully detected.
Here the full logs :
ESC main menu
Logging HID Data. Press ESC to stop...
I0 L8- 00 00 00 00 00 00 00 00
reenumerating all ports
port 0
gdd len8
mps 64
addr ok 0
gddfull ok 18
Device Descriptor
12 01 00 02 09 00 00 40 40 1A 01 01 11 01 00 01
00 01
0x1A40 0x0101 0x0111
Config Descriptor
09 02 19 00 01 01 00 E0 32 09 04 00 00 01 09 00
00 00 07 05 81 03 01 00 FF
gcd ok 25
Found hub
4 port hub
Doing new thing - 64
new enum. failed
new enum. 9
checkn port 0
ps- 0x101 pc- 0x01
port 0 attached
fullspeed
gdd.fail
enum.fail
checkn port 1
ps- 0x100 pc- 0x00
checkn port 2
ps- 0x101 pc- 0x01
port 2 attached
fullspeed
gdd.fail
enum.fail
checkn port 3
ps- 0x100 pc- 0x00
port 1
gdd.fail
done reenumerating
port 0
gdd len8
mps 64
addr ok 0
gddfull ok 18
Device Descriptor
00 01
Config Descriptor
gcd ok 25
Found hub
4 port hub
new enum. failed
new enum. 9
checkn port 0
ps- 0x101 pc- 0x01
port 0 attached
fullspeed
gdd.fail
enum.fail
checkn port 1
ps- 0x100 pc- 0x00
checkn port 2
ps- 0x101 pc- 0x01
port 2 attached
fullspeed
gdd.fail
enum.fail
checkn port 3
ps- 0x100 pc- 0x00
port 1
gdd.fail
done reenumerating
port 0
gdd len8
mps 64
addr ok 0
gddfull ok 18
Device Descriptor
00 01
Config Descriptor
gcd ok 25
Found hub
4 port hub
new enum. failed
new enum. 9
checkn port 0
ps- 0x101 pc- 0x01
port 0 attached
fullspeed
gdd.fail
enum.fail
checkn port 1
ps- 0x100 pc- 0x00
checkn port 2
ps- 0x101 pc- 0x01
port 2 attached
fullspeed
gdd.fail
enum.fail
checkn port 3
ps- 0x100 pc- 0x00
port 1
gdd.fail
done reenumerating
port 0
gdd len8
mps 64
addr ok 0
gddfull ok 18
Device Descriptor
00 01
Config Descriptor
gcd ok 25
Found hub
4 port hub
new enum. failed
new enum. 9
checkn port 0
ps- 0x101 pc- 0x01
port 0 attached
fullspeed
gdd len8
mps 64
addr ok 0
gddfull ok 18
Device Descriptor
12 01 00 02 00 00 00 40 6D 04 35 C3 02 06 01 02
03 01
0x046D 0xC335 0x0602
Config Descriptor
09 02 3B 00 02 01 04 A0 FA 09 04 00 00 01 03 01
01 00 09 21 11 01 00 01 22 41 00 07 05 81 03 08
00 01 09 04 01 00 01 03 00 00 00 09 21 11 01 00
01 22 77 00 07 05 82 03 40 00 01
gcd ok 59
enum.OK
checkn port 1
ps- 0x100 pc- 0x00
checkn port 2
ps- 0x101 pc- 0x01
port 2 attached
fullspeed
gdd len8
mps 64
addr ok 0
gddfull ok 18
Device Descriptor
12 01 00 02 00 00 00 40 6D 04 8B C0 03 27 01 02
03 01
0x046D 0xC08B 0x2703
Config Descriptor
09 02 3B 00 02 01 04 A0 96 09 04 00 00 01 03 01
02 00 09 21 11 01 00 01 22 43 00 07 05 81 03 08
01 22 97 00 07 05 82 03 14 00 01
gcd ok 59
enum.OK
checkn port 3
ps- 0x100 pc- 0x00
Interface 0
InterfaceProtocol 1
Interface 0 Report Descriptor -
05 01 09 06 A1 01 05 07 19 E0 29 E7 15 00 25 01
75 01 95 08 81 02 95 01 75 08 81 01 95 03 75 01
05 08 19 01 29 03 91 02 95 05 75 01 91 01 95 06
75 08 15 00 26 FF 00 05 07 19 00 2A FF 00 81 00
C0
set report mode - 1 - 1
Report 0 usage 6 length 64
startbit 56 it 4 ip 0 chan 0 cont 0 size 8 count 6
startbit 48 it 4 ip 0 chan 0 cont 0 size 8 count 6
startbit 40 it 4 ip 0 chan 0 cont 0 size 8 count 6
startbit 32 it 4 ip 0 chan 0 cont 0 size 8 count 6
startbit 24 it 4 ip 0 chan 0 cont 0 size 8 count 6
startbit 16 it 4 ip 0 chan 0 cont 0 size 8 count 6
startbit 8 it 4 ip 0 chan 0 cont 0 size 8 count 1
startbit 0 it 5 ip 0 chan 0 cont e0 size 1 count 8
SetReport
Interface 1
InterfaceProtocol 0
Interface 1 Report Descriptor -
05 01 09 06 A1 01 05 07 19 00 29 E7 15 00 26 E7
00 75 08 95 14 85 01 81 00 C0 05 0C 09 01 A1 01
85 02 15 00 25 01 75 01 95 07 09 B5 09 B6 09 B7
09 CD 09 E9 09 EA 09 E2 81 02 95 01 81 01 C0 06
43 FF 0A 02 06 A1 01 85 11 75 08 95 13 15 00 26
FF 00 09 02 81 00 09 02 91 00 C0 06 43 FF 0A 04
06 A1 01 85 12 75 08 95 3F 15 00 26 FF 00 09 04
81 00 09 04 91 00 C0
Report 1 usage 6 length 168
startbit 160 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 152 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 144 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 136 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 128 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 120 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 112 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 104 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 96 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 88 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 80 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 72 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 64 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 56 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 48 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 40 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 32 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 24 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 16 it 4 ip 0 chan 0 cont 0 size 8 count 14
startbit 8 it 4 ip 0 chan 0 cont 0 size 8 count 14
Interface 0
InterfaceProtocol 2
05 01 09 02 A1 01 09 01 A1 00 05 09 19 01 29 10
15 00 25 01 95 10 75 01 81 02 05 01 16 01 80 26
FF 7F 75 10 95 02 09 30 09 31 81 06 15 81 25 7F
75 08 95 01 09 38 81 06 05 0C 0A 38 02 95 01 81
06 C0 C0
Report 0 usage 2 length 64
startbit 56 it 0 ip 1 chan 0 cont 0 size 8 count 1
startbit 48 it 3 ip 1 chan 1 cont 6 size 8 count 1
startbit 32 it 3 ip 1 chan 1 cont 5 size 10 count 2
startbit 16 it 3 ip 1 chan 1 cont 4 size 10 count 2
startbit 0 it 5 ip 0 chan 1 cont 1 size 1 count 10
Interface 1
InterfaceProtocol 0
05 01 09 06 A1 01 85 01 05 07 19 E0 29 E7 15 00
25 01 75 01 95 08 81 02 81 03 95 06 75 08 15 00
26 A4 00 19 00 2A A4 00 81 00 C0 05 0C 09 01 A1
01 85 03 75 10 95 02 15 01 26 8C 02 19 01 2A 8C
02 81 00 C0 05 01 09 80 A1 01 85 04 75 02 95 01
15 01 25 03 09 82 09 81 09 83 81 60 75 06 81 03
C0 06 00 FF 09 01 A1 01 85 10 75 08 95 06 15 00
26 FF 00 09 01 81 00 09 01 91 00 C0 06 00 FF 09
02 A1 01 85 11 75 08 95 13 15 00 26 FF 00 09 02
Report 1 usage 6 length 72
startbit 64 it 4 ip 0 chan 0 cont 0 size 8 count 6
startbit 8 it 5 ip 0 chan 0 cont e0 size 1 count 8
port 1
gdd.fail
done reenumerating
I0 L8- 00 00 29 00 00 00 00 00
HIDman v1.1.5a
1. Key
2. Mouse
3. Game
4. Adv.
ESC to exit menu
Goodbye
[2] My mouse buttons to adjust pointer speed (DPI) are not working, so i've noticed the pointer goes really faster than it should.
And if i manage to setup it from another PC it's always faster than the recorded setting in my mouse. No idea why however.
For bug[1] i've fixed it by restoring thoses files :
- test.c
- testdata.c
- testdata.h
from the commit "hub initialization tweaks" (11d30a0324d4f5232fff57a887ce7ee3c92e6364).
I don't know which test exactly broke the hub init on lastest commit but it's cleary there.
After restoring thoses files my problem with my KVM is gone.
For bug [2] i've noticed something interesting :
My buttons to adjust mouse sensibility works only on first initialisation of the hub (when i power ON the PC).
Then it broke on each reconnect of the KVM. HIDman led blinks but the pointer speed remains same.
About that speed is like 1.5x-2x more faster than the same DPI settings directly plugged in USB.
Everything else works always but i need sort of be sure of the sensibility i want before reswitch on the KVM otherwhise it stay stuck until next reboot.
EDIT:
For bug [2] nethermind, it not bug on my Windows 98 SE PC, i guess it's prob something only related to my modern PC (where i don't care it was just for testing).
It's probably related to how modern hardware still support PS2 Mouse.
As long i don't have the bug on old PC it's good, i can switch ON/OFF there no problem it always catch thoses buttons !
So to resume, no problem so far now i gonna now full enjoy HIDman ! 😁
TgamesFR wrote on 2024-12-29, 07:23:For bug[1] i've fixed it by restoring thoses files : […]
- test.c
- testdata.c
- testdata.h
Those three files aren't used in a normal hidman build. My guess is something went wrong with your build the first time, unrelated to those files.
Are you doing a "make clean" before every "make"?
Andy
rasteri wrote on 2024-12-29, 13:42:Those three files aren't used in a normal hidman build. My guess is something went wrong with your build the first time, unrelated to those files.
Andy
Yes i did, i even deleted the whole folder and redid a "git clone https://github.com/rasteri/HIDman.git".
And each time i do "make" in firmware folder thoses files get used. No idea why.
But it's fine when you will push a compiled version it won't be a issue so for me 😉.
Right now i've tested the 1.1.5a version with my setup the whole day, absolute no issue with my KVM, keyboard and mouse !
The only small minor thing is about the mouse going faster than the real DPI set but i can lower the DPI to have something ok.
This doesn't work on my kvm 🙁
This is the KVM I have: https://www.amazon.com/gp/product/B08QCR62VL
HIDman doesn't seem to enumerate devices on the hub. But it works fine when I connect a keyboard directly.
By the way, should HIDman be getting power from USB or from PS2? Maybe there is some differential between the +5V on my hub and the +5V coming from PS2. Maybe I should sever the PS2 power?
My current setup is a Raspberry Pi connected to my hub/KVM, a custom script running to get keyboard input from the Linux device, piping that to a Python script and issuing PS2 commands through an Arduino device. It works, but it can lag behind if I type too fast. I could never get a serial mouse to properly work (in fact I started a whole thread about it: Re: Serial mouse in Windows 2000 ) so I am currently just using a PS2 mouse for my retro PCs and a USB mouse for my newer PCs.
Since I have had trouble emulating a PS2 or serial mouse, maybe the HIDman can still help me out. If I could connect it as a client to my raspberry pi then maybe I can still use it to issue PS2 commands.
I'm using v1.1.4
dylanrush wrote on 2025-01-06, 22:18:This doesn't work on my kvm 🙁
hidman gets power from PS/2. It should not be getting power from USB (apart from during firmware upgrades).
A large unpowered KVM might not be a very good fit for this application. Drawing that much power from the PS/2 port may be problematic.
Nonetheless, try this beta version, it's got the new KVM init code.
If that doesn't work get me a HID log (start it logging, then plug in your KVM and try switching the output a few times)
(This version of the code might be laggy but the full version will fix that)
One of my ten pre-assembled units flashes as usual with proper USB ID and everything, but only pulses the green LED very briefly when supplied with power. Never changes to blue, never presents as a keyboard as indicated by a BIOS error message. Can't spot any soldering imperfections - partially defective controller maybe?
(The one unit that once absolutely did not like being connected to a gameport has now recovered, gonna keep that one)
sudo ./python3 ch55xtool -f hidman_axp_v1.1.4.bin
Found CH559 with SubId:17
BTVER:02.40
UID:67-CA-79-BC-00-00-00-00
Erasing chip flash. Done.
Flashing chip. Done.
Finalize communication. Done.
Bzzz wrote on 2025-01-08, 00:23:One of my ten pre-assembled units flashes as usual with proper USB ID and everything, but only pulses the green LED very briefly when supplied with power. Never changes to blue, never presents as a keyboard as indicated by a BIOS error message. Can't spot any soldering imperfections - partially defective controller maybe?
Sounds like it's always going into the bootloader, check for shorts around the crystal and the two capacitors beside the crystal
Can't really see anything there, also no obvious shorts on the micro. Probably best to check if the crystal is actually running.
Bzzz wrote on 2025-01-08, 09:37:Can't really see anything there, also no obvious shorts on the micro. Probably best to check if the crystal is actually running.
Attached is a pic showing the trace that enables the bootloader
Check across C5 with a multimeter, see if it's shorted.
If so the short may be the capacitor itself, or underneath the crystal or something
Unfortunately v1.1.5b didn't work with my KVM either. I don't think it's too much power draw because I was able to plug both my KVM and a Logitech wireless keyboard/mouse into the USB ports and the Logitech one worked. I used the Logitech one to dump the HID data while I cycled the KVM. Data below
If you have some code change suggestions, I am not familiar with your code base but I'm handy enough to take a change, compile it myself and start to understand it.
I am going to start hunting for a new KVM if anyone has some suggestions for one that is known to work with this device.
port 0
gdd.fail
port 1
sp 53
gdd len8
mps 8
addr ok 0
gddfull ok 18
Device Descriptor
12 01 00 02 00 00 00 08 6D 04 2B C5 01 12 01 02
00 01
0x046D 0xC52B 0x1201
Config Descriptor
09 02 54 00 03 01 04 A0 31 09 04 00 00 01 03 01
01 00 09 21 11 01 00 01 22 3B 00 07 05 81 03 08
00 08 09 04 01 00 01 03 01 02 00 09 21 11 01 00
01 22 94 00 07 05 82 03 08 00 02 09 04 02 00 01
03 00 00 00 09 21 11 01 00 01 22 62 00 07 05 83
03 20 00 02
gcd ok 84
Interface 0
InterfaceProtocol 1
75 01 95 08 81 02 81 03 95 05 05 08 19 01 29 05
91 02 95 01 75 03 91 01 95 06 75 08 15 00 26 A4
00 05 07 19 00 2A A4 00 81 00 C0
set boot mode - 1 - 0
SetReport
Interface 1
InterfaceProtocol 2
05 01 09 02 A1 01 85 02 09 01 A1 00 05 09 19 01
29 10 15 00 25 01 95 10 75 01 81 02 05 01 16 01
F8 26 FF 07 75 0C 95 02 09 30 09 31 81 06 15 81
25 7F 75 08 95 01 09 38 81 06 05 0C 0A 38 02 95
01 81 06 C0 C0 05 0C 09 01 A1 01 85 03 75 10 95
02 15 01 26 8C 02 19 01 2A 8C 02 81 00 C0 05 01
09 80 A1 01 85 04 75 02 95 01 15 01 25 03 09 82
09 81 09 83 81 60 75 06 81 03 C0 06 BC FF 09 88
A1 01 85 08 19 01 29 FF 15 01 26 FF 00 75 08 95
01 81 00 C0
set boot mode - 0 - 0
Interface 2
InterfaceProtocol 0
Interface 2 Report Descriptor -
06 00 FF 09 01 A1 01 85 10 75 08 95 06 15 00 26
FF 00 09 01 81 00 09 01 91 00 C0 06 00 FF 09 02
A1 01 85 11 75 08 95 13 15 00 26 FF 00 09 02 81
00 09 02 91 00 C0 06 00 FF 09 04 A1 01 85 20 75
08 95 0E 15 00 26 FF 00 09 41 81 00 09 41 91 00
85 21 95 1F 15 00 26 FF 00 09 42 81 00 09 42 91
00 C0
set report mode - 0 - 0
done reenumerating
I0 L8- 00 00 00 00 00 00 00 29
dylanrush wrote on 2025-01-08, 22:43:Unfortunately v1.1.5b didn't work with my KVM either.
So I've added an option in 1.1.5c to forcibly re-redetect devices, just in case your KVM is taking longer to initialize than other hubs. You access this from the HID log.
Get everything set up, and select HIDman's port on your KVM. Then go into hidman's menu, start a HID log, and press "R" to redetect. See if this makes your hub appear. Maybe try it 2 or 3 times.
(Obviously asking you to do this every time you switch KVM isn't realistic but it'll provide useful debug info)
rasteri wrote on 2025-01-09, 22:38:So I've added an option in 1.1.5c to forcibly re-redetect devices, just in case your KVM is taking longer to initialize than oth […]
I ended up getting a new KVM which was at least recognized by HIDMan. It would indeed register a few keystrokes. But it spammed the enter key and wasn't really working.
I also got a OmniView F1D104 PS2 kvm to go between my USB KVM and my retro machines. This unfortunately does not supply power over PS2! So my HIDMan was not working with my OmniView.
However the OmniView did support my serial mouse with my raspberry pi solution. So now everything is working for me with my raspberry pi.
I would like to get the HIDMan working with this setup. Maybe it's as simple as providing external power instead of power over PS2? At any rate my project is working end to end, just with occasional hiccups with the keyboard, so that may be a project for another day.
dylanrush wrote on 2025-01-17, 19:38:I ended up getting a new KVM which was at least recognized by HIDMan. It would indeed register a few keystrokes. But it spammed the enter key and wasn't really working.
Try going back to 1.1.4, maybe there's a bug in 1.1.5c.
Try powering it through the USB ports on the front of hidman. You can use the same USB A-to-A cable you use to upgrade firmware (except plug it into a USB power supply instead of your computer)
