First post, by Harry Potter
I believe I have a program that mount .iso files on my Win98SE tower but that it broke upon my last reinstall of Windows. I'm looking for a name and, if necessary, an URL of such so I can find or reinstall it.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 1 of 16, by myne
Daemon tools
https://www.philscomputerlab.com/daemon-tools … windows-98.html
I think we can trust Phil
I built:
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 4 of 16, by Harry Potter
You're right, but I believe I still have it on my computer. It's busy compressing a Zip disk right now, so I'd better wait.
Reply 5 of 16, by Harry Potter
I found a version on one of my flash drives while transferring files to it, but, when I tried to install it, it said there's a driver conflict. I was using the defaults for these options. Apparently, it was already installed. However, when I right-click an .iso file, the only useful option was Open With. 🙁 What do I need to do to finish installing it?
Reply 6 of 16, by Harry Potter
When I double-click on the Daemon Tools icon on my desktop, I get an error message referring to "C:\Windows\daemon.dll." I'm wondering if replacing this file will help, but I've been unsuccessful in reinstalling Daemon Tools. How do I replace that file?
Reply 8 of 16, by Harry Potter
Umm...yes. The system was running into Exception oE errors, and I tried to reinstall Windows. In the end, it helped only slightly: the error appeared less often. Unfortunately, I'm now getting a VFAT Device Initialization Failed error. 🙁 First, I was wondering why DOS applications stopped running in Windows mode again. I rebooted in DOS mode using the F8 menu and typed MEM and found too little memory. 🙁 I disabled the "dblspace" option in MSDOS.SYS and rebooted. I forgot what happened next, but I then disabled the line in autoexec.bat that loads the RAM drive and got system crashes. Reenabling the line caused the mentioned error.
Reply 9 of 16, by megatron-uk
If you deleted C:\Windows, can you understand why any applications installed in other directories may be complaining about files missing under c:\windows?
https://www.target-earth.net
Reply 10 of 16, by Harry Potter
Umm...yes. I just wanted to see if I can replace that file and, if necessary, other files.
Reply 11 of 16, by DaveDDS
Btw, If all you need is to be able to browse the ISO and extract some files...
I do that all the time with: 7zip
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 12 of 16, by Harry Potter
I have 7Zip. Apparently, I need to set a file association. 😀 BTW, I also want to mount an .iso file as a virtual CD. I believe I may have other software on the computer that can do the job, but as I mentioned, the computer broke badly. I don't want to reinstall Windows again, so I'm looking for another way to fix its current problem.
Reply 13 of 16, by myne
Why didn't you just download and install the copy I linked?
I built:
Reply 14 of 16, by Harry Potter
If you mean about Daemon Tools, I tried a copy I had, but there was a driver conflict error. I think the copy to which you linked would result in the same. I tried to reinstall Windows, and now, during the boot process, the system spontaneously restarts. 🙁
Reply 15 of 16, by myne
I don't miss the days of playing windows.
I built:
Reply 16 of 16, by Harry Potter
I don't know why, but it got past there now. Now, I have another problem: I was reinstalling Windows at the time, and now, I'm getting the exception error while it's installing the hardware. 🙁
