Can’t run Simon the Sorcerer
Reply 120 of 125, by carlostex
DustyShinigami wrote on 2024-12-29, 18:15:
Yeah, I suspected as much. It's a bit like BASS - I can't use the Roland sound canvas without losing the speech. It has to have the Sound Blaster option in order to get speech, music and SFX. I think before, when I used my onboard sound, I had the MT32 option enabled, and that was as close as I could get.
Re: Beneath a Steel Sky CD - Roland music + SB Speech
Reply 121 of 125, by DustyShinigami
carlostex wrote on 2024-12-29, 21:07:
Oh awesome. Thank you for pointing me to this. 😁 I wonder if something can be done with Simon, too.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 122 of 125, by carlostex
DustyShinigami wrote on 2024-12-29, 21:16:
Simon already has MT32 + Speech. It's soundtrack probably won't sound too good in a general MIDI module, but if you have a SC-55 you can use the MT-32 mode on the SC-55 at least. Not sure if Simon uses any custom patches
EDIT: Apparently it will sound best on a Roland CM-32L, so that's what one will need to use. General MIDI would require the game to have the soundtrack midi files redone.
Reply 123 of 125, by DustyShinigami
carlostex wrote on 2024-12-29, 21:32:
Oh no, I tried toggling the MT32 on the SC-55 as well, but I don't think it worked. The problem is I'm not sure if it gives you the option of selecting the 330 port when choosing the MT32 option.
OS: Windows 98 SE
Reply 124 of 125, by carlostex
DustyShinigami wrote on 2024-12-29, 21:51:
port 330 is standard in the game, as far as i know.
Reply 125 of 125, by DustyShinigami
carlostex wrote on 2024-12-29, 21:59:
I'll have to try re-installing it again and see.
OS: Windows 98 SE
