My Tandy 2500 SX/33 386
First post, by jpolo
I picked up this system a few years ago when I got the itch to relive the days I spent as a kid playing DOS games on the PS/2 Model 60 286 my dad had brought home from work in the late 80's which was our only computer up to 1995. I went with a 386 because I remember some stuff (like wolf3d) being intolerably slow on a 286 and wanted a bit more choice in the library. I went with a Tandy just because I think it's a neat package with concessions like PS/2 ports, built in IDE/floppy/parallel/serial, a removable CR2032 battery, and volume adjustment/headphone jack for the PC speaker, which I route to line in of the sound card (this model does not have tandy graphics/sound, it's a pretty standard PC). I've been adding to this system over the years (it was completely stock) and now I feel it's pretty much done, though I'm debating adding a GUS I have saved for a 486 or early Pentium build that may or may not ever get finished.
Radioshack keeps an awesome database of Tandy computer documentation, there is tons of info about this model here: http://support.radioshack.com/support_computer/1730.htm
Here's a video of a demo I used to run on the 286 running on this machine, this was mindblowing back in the day: https://www.youtube.com/watch?v=6wiKKA8jLCw
Specs
CPU: 33MHz Intel 386SX soldered on the board
RAM: 10MB total- 2MB soldered to the board and 2X 4MB SIMMs, the max this motherboard recognizes
HDD: 420MB IDE Quantum TR42A 3600RPM (upgraded from the original 100MB 3200RPM HDD)
Video: ISA Tseng ET-4000AX 1MB "Machspeed 9301" (upgraded from onboard Cirrus CL-GD5402 256kb) if anyone has the manual for this particular card I would love to see it, just want to know what the jumpers do
Sound: ISA Creative Vibra 16 CT2800, I like these cards because they have a real OPL3 and great signal:noise ratio and you can get them brand new for $15
Speakers: Altec Lansing ACS400 comically large "multimedia" speakers
CD-ROM: Reveal branded 4X Mitsumi
Monitor: Packard Bell PB8530MS Trisync VGA (it's a rebranded NEC Multisync II, I share it with my X68000 which needs a trisync monitor)
Input: Tandy Enhanced Keyboard AT with PS/2 adapter (looks like it should have nice clicky keys like a Model M but it's actually completely awful, just using it because it looks "right" for this machine), Logitech 3-button PS/2 mouse, Gravis Gamepad, Kraft Premium II, Generic Reveal joystick, Logitech Wingman 3001 (game controllers hooked to a 4-way switch)
Pictures
The complete system
Front
Unfolding the case
CT2800
ET4000AX - any info about the jumpers on this card would be appreciated!
All cards removed to reveal the motherboard (the two empty DIP sockets are for expanding the onboard video RAM, max is 512kb)
Wide shot to show how ludicrously small this motherboard is
BIOS config screen
Topbench
AUTOEXEC.BAT
@ECHO OFF
REM C:\DOS\SMARTDRV.EXE
REM LH C:\DOS\MSCDEX.EXE /D:MTMIDE01 /M:10
C:\DOS\SHSUCDX /Q /D:MTMIDE01
C:\DOS\CTMOUSE.EXE /3
LH C:\DOS\DOSKEY.COM
SET SOUND=C:\APPS\VIBRA16
SET BLASTER=A220 I5 D1 H5 P331 T6
SET MIDI=SYNTH:1 MAP:E
C:\APPS\VIBRA16\DIAGNOSE /S
C:\APPS\VIBRA16\MIXERSET /P /Q
PROMPT $p$g
PATH C:\NC;C:\QEMM;C:\APPS;C:\DOS
SET TEMP=C:\TEMP
SET DIRCMD=/o:gne
echo.
CONFIG.SYS
SWITCHES=/f
DEVICE=C:\QEMM\QEMM386.SYS RAM NW3
DOS=HIGH,UMB
DEVICE=C:\QEMM\LOADHI.SYS /R:1 C:\MTM\MTMCDAI.SYS /D:MTMIDE01
BUFFERS=15,0
FILES=40
STACKS=0,0
FCBS=4,0
LASTDRIVE=D
BREAK=ON
Output of MEM
Memory Type        Total  =   Used  +   Free
Conventional 640K 19K 621K
Upper 132K 22K 110K
Reserved 384K 384K 0K
Extended (XMS) 9,084K 220K 8,864K
Total memory 10,240K 645K 9,595K
Total under 1 MB 772K 41K 731K
Total Expanded (EMS) 9,504K (9,732,096 bytes)
Free Expanded (EMS) 8,864K (9,076,736 bytes)
Largest executable program size 621K (636,096 bytes)
Largest free upper memory block 83K (84,640 bytes)
MS-DOS is resident in the high memory area.
Reply 1 of 27, by keenmaster486
Hey hey hey! That's a nice machine you've got there. How good do those speakers sound when you crank up some tracker music or a demo, for instance?
Also, QEMM rules 😈
World's foremost 486 enjoyer.
Reply 2 of 27, by chinny22
Very nice looking PC, not much room for expansion but "Pizza box" case dimensions always seemed more pleasing to the eye
386 is bit early for me but can appreciate them (Our 1st PC was a 486 in 95) which came with 8MB RAM, so that should be fine for a 386.
Funny enough it came with 420MB HDD as well
Coin battery AND ps2 ports very nice indeed!
Reply 3 of 27, by matze79
Does the Machine support Tandy combatible 3-Voice Sound ?
Reply 4 of 27, by jpolo
Also, QEMM rules 😈
thanks, I haven't really messed with demos and tracker stuff on this machine because I don't have the GUS in there but they sound great with SB stuff in games
Sadly it doesn't do the tandy graphics/sound
Reply 5 of 27, by Cloudschatze
Actually, the 2500 SX/33 has the same "Tandy Sound" PSG and DAC functionality found in the earlier, TL/SL/RL systems. In the 2500-series (and 1000 RSX), access was moved to 16-bit port addresses though (1E0h - 1E7h), so most Tandy-supporting software doesn't know to look for it.
Through use of a specific driver, all of Sierra's SCI0 titles can produce 3-voice music and digitized sound (where applicable) on these systems, while all of their SCI1 games, as well as several titles from Broderbund, Virgin, and Disney, will natively utilize the 1E0h-addressed PSSJ chip.
Reply 6 of 27, by MMaximus
Beautiful system. Somehow I didn't know there were any 386 in the Tandy line-up until now.
Hard Disk Sounds
Reply 7 of 27, by jpolo
Whoa, awesome, do you have a link to somewhere I can read about this in more detail?
Reply 8 of 27, by Mr.Tibb
Do you know what DRAM chips are needed to upgrade the onboard video to 512k? I've recently acquired a 2500 SX/33 as well...
Reply 9 of 27, by Miphee
A 386 with coin battery. The world would be a better place if other manufacturers had followed this design.
Reply 10 of 27, by Jo22
Miphee wrote on 2020-07-20, 19:00:
Well, using a watch's battery wasn't common in the 1980s, except for exotic stuff (battery-backed RAM in NES cassettes)..
People rather used these barrel batteries or Dallas Clocks.
The latter was tricky to fix, but at least didn't leak.
And to be fair, no one assumed that a 10 year lifespan was too short for such short-lived technology.
Better equipment had external battery packs, also. But not the AA/Mignon-Type, but some special battery packs with a standard connector.
Edit: Correction. Knob cells err.. coin cells were a popular power source for spy bugs since the 1960s. Or so I heard. Ahem. 😇
Reply 11 of 27, by Miphee
Jo22 wrote on 2020-07-26, 12:00:
It seems that manufacturers viewed the battery "problem" differently.
Designers who made disposable computers chose the barrel type. I've read somewhere that it was common knowledge back then that barrel batteries may leak but nobody cared because it was cheap. NiCd batteries were used from the 1950s so designers knew exactly what they were dealing with yet they chose to place them directly on the sensitive motherboard without any protective casing. Textbook planned obsolescence. These batteries were also unreliable and often died early due to thermal exposure so designers had to install the option for external batteries as well. They knew it was shit and still used them.
Designers who chose the Dallas-type chips wanted their products to last. It was a properly encased quality product that was immune to thermal effects. It also had a lifespan of 10 years (when the board was not powered so it was much more than 10 years) so designers didn't feel the need to make it replaceable.
AT&T workstations used easily accessible sealed external lithium battery packs. If a company has 200 of those workstations it has to be easily serviceable. Just like the IBM Wheelwriter that used 3xAA external batteries.
The point of my little rant here is the barrel battery (or the capacitor) plague could have been avoided if manufacturers didn't want to cut corners all the time to save money.
Reply 12 of 27, by Jo22
Miphee wrote on 2020-07-26, 14:28:
It seems that manufacturers viewed the battery "problem" differently. Designers who made disposable computers chose the barrel t […]
I see. You may call them "Double-A" batteries..
I call them "mainboard killers". 😉
Reply 13 of 27, by Miphee
Jo22 wrote on 2020-08-08, 15:03:
That's exactly what I have in my IBM 6747, 3xAA batteries. 😁 When I first saw them I thought somebody left them there accidentally.
No, turns out it's an essential part of that typewriter. The batteries were fused together with rust and alkaline solution.
I also found them in my IBM model 70, someone replaced the original batteries with an AA battery pack. It leaked too but no damage because it was far from the motherboard.
I wish these leaky old battery types would just die out already.
Reply 14 of 27, by Benson879
Hey! I know this is an old post but I have the exact same system. Only difference is I have none of the upgrades, pretty much the system as is. Just added a couple 4 MB Simms as well.
Noticed this poster modified their hard drive- “HDD: 420MB IDE Quantum TR42A 3600RPM (upgraded from the original 100MB 3200RPM HDD)”
Would this be worth it for me to look into upgrading storage space? Or should I also upgrade other aspects of the system as well before making that attempt? Any alternative solutions as well to upgrade storage?
If it becomes too much that needs to be upgraded, I’d almost rather leave this as is and look into obtaining another 486 or Pentium computer.
Reply 15 of 27, by ralphmaif
jpolo wrote on 2016-09-02, 17:42:
Sorry for the thread necromancing, but I recently picked up a Tandy 2500 SX 25 and would like to know if the update for this class of machine detailed above is still available, and if so from where/whom. I've checked the SCI Wiki and Internet Archive and found a lot of useful info and utilities, but I've yet to locate the mentioned driver.
Reply 16 of 27, by rmay635703
This is something I always found aggravating is finding various patches and files from decades past, various threads archive them but time marches on
Sierra/Dynamix sound driver hacking
Reply 18 of 27, by bofh.fromhell
ralphmaif wrote on 2025-05-08, 00:31:
Also if you haven't already check out "Necroware"'s Septandy videos of a basically identical machine:
https://www.youtube.com/watch?v=-lva7gzWuRE
He fiddles quite a bit with the sound and ofc. also upgrades the hardware.
Reply 19 of 27, by ralphmaif
bofh.fromhell wrote on 2025-05-13, 20:05:
Also if you haven't already check out "Necroware"'s Septandy videos of a basically identical machine: https://www.youtube.com/wa […]
Ah lovely, he's got some chops. The ride he's modifying in that video is an 1000 RSX which is similar in the 386 bus moving the sound chip address for sure. The board itself is quite smaller than the 2500 sx specs, though. Same principles in redirecting will apply for sure.
