Dos Box and Window 11
First post, by FamilyTreeMan
Hello Everyone,
Some Time Ago I installed DosBox 0.74 to run a set of GW-Basic programs for Family Tree Data on a Windows 10 computer.
That Computer has become so slow that I can't use it anymore, and I have installed DosBox 0.74-3 onto a Windows 11 computer.
I have copied all the Data, the Basic Programs (and GW-Basic) from the old computer into the same file structure, I also added my AutoExec lines from the 0.74 config file into the 0.74-3 config file, but it does not work correctly on the Windows 11 Machine.
Have I missed some key steps in this process ?
What I am seeing is that the GW-Basic Program seems to load up, but it does not autorun. When I manually issue the Run command it runs but I then get a file error, that seems to indicate that some of my Mount Statements have not worked correctly.
Any ideas what I might be able to do to get it running like it used to on the Windows 10 machine ?
Hoping that someone can help me sort this out.
This is what I added to my Config file:
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
Set First="YES"
mount a c:\dosboxft\dbprograms
mount b c:\dosboxft\dbdata
mount c c:\dosboxft\dbdata\ord
mount m c:\dosboxft\dbsortspace
mount d c:\dosboxft
gw-basic a:menu1/s:256/f:6
I Get this error:
120 OPEN "b:PERSFILE" AS #1 LEN = 256
Illegal function call in 120
Regards,
FamilyTreeMan.
Reply 1 of 1, by ratfink
Could it be a write protection issue?
