Reply 28980 of 30758, by dominusprog
- Oldbie
DarthSun wrote on 2024-12-29, 00:09:You have to go with Via as well. UOSP is worth installing (+kernel enhanced+EIDE UDMA addon/repair). At me: Epox MVP3G2/2x128MB […]
dominusprog wrote on 2024-12-28, 16:06:So I start working on the super socket 7, and I encountered a couple of issues. One, the BIOS detect the hard drive as UDMA-82, […]
So I start working on the super socket 7, and I encountered a couple of issues. One, the BIOS detect the hard drive as UDMA-82, which is got fixed by downgrading the BIOS. But no matter which version I put into ROM, installing the VIA chipset driver and enabling the DMA for HDD will cause the Windows to freeze during boot. On top of that, the throughput of both RAM and HDD are lower than expected, so is it the fault of Windows ME or the Apollo chip?https://theretroweb.com/motherboards/s/a-tren … c-5200m-v1#bios
At me:
Epox MVP3G2/2x128MB SD @112MHz CL2-3-3-6/AIW Radeon9800Pro@398/351/Awe64/IDE-SD-8-32GB/Maxtor 33GB/LG DVDR/DTK 300W/RIG
So I found an unofficial patch, but files were removed. Can you provide a link?
