BitWrangler wrote on 2025-01-05, 15:02:
StriderTR wrote on 2025-01-05, 09:50:
Played around with my DOS machine for a bit today. Repaired a flaky 5V line going to the PS/2 port, I stole it (bodged) from the USB port right next to it. Problem solved.
I've seen that happen where there's a re-settable fuse on the PS/2 power, and it gets "half blown" or doesn't reset properly or something. These are also known as PPTCs and the type seen on motherboards are usually a pinkie nail sized square green thing with a symbol that looks a bit like 1X1 but is actually two Vs overlapping. Think it's usually the "1812" footprint, but volt/amp ratings are different for ones that look the same. Part of their operation is thermal, so to get them to behave right, you can use an iron or hotair to "pretend resolder" them and they might pass current properly again after they've cooled down an hour.
I am only "somewhat aware" of them, not an expert, but my thoughts on why they misfire is: Heatsoaking from the motherboard, they either get warm enough that a sub threshold spike sorta trips them.... orrrr, they get a bonafide reason to pop but due to the motherboard continuing to run and stay warm for a while after, don't cycle cold right and reset properly.
I thought I was going crazy, I recently repaired a bad data line connection to that area thanks to a ripped out via and lifted trace. Everything was working good until the other day. So I tore it all back down and started probing around, 5V line was only making contact when the board was flexed, but could not figure out exactly where or why it was happening. Visually, everything "looked good". So, I finally just bodged in a jumper from the 5V line feeding the USB ports next to it that don't get used in this build anyway.
I will have to go back and see if I can find that fuse the next time I tare into it, just to see. 😀
On a side note...
I decided to tare apart an old Barracuda Spam Firewall from the early 2000's to recover the MB and PSU from it. I haven't seen one of these in years...but the motherboard and PSU, if good, still are useful on their own.
Someone had soldered some wires for the front panel display directly to the LPT port on the back, quick and dirty, but it seems to have worked for them.
After making the obligatory blood sacrifice to the PC gods in hopes everything still worked while removing the solid 10oz. copper cooler, it reveled an old Sempron 2200+, nothing special. Cleaned up all the old paste and burned dust out of the cooler. Will use a standard cooler if the MB is good.
Tested the PSU and it seems to be good. Now all I need to do is test the MB. Wish me luck! If it's good, can be used for a future build, I'm thinking XP era. 😀
