First post, by Manu270891
I'm trying to make the redbook audio tracks work on Requiem: Avenging Angel. I'm using the https://github.com/ayuanx/ogg-winmm wrapper with the extracted tracks, and it works, but only if the ISO image is mounted. The ISO image just contains the data partition, no audio partitions (it's an ISO image, it's not a BIN/CUE image which can contain several partitions). It's really surprising that it works this way because I hex-edited the exe to skip the disc check. I always launch the game through "D3D.exe" and it has the same behavior in the spanish exe, the USA1.2 exe and the USA 1.3 exe.
Is there any way of making the tracks work without mounting the disc image?
Thanks!
