First post, by Doombringer4u2nv
These speakers are an important part of my DOS gaming PC as I had them since new. I dug them out recently for my first retro dos build.
Anyway, I lost the DIN cable that connects the the two satellite speakers. I bought a generic DIN cable (same pin pattern) and the wiring must be different. I do not get sound on the lower speakers on the "slave" satellite.
No way to take the speaker apart as it must be glued or something. I took all the screws out and it is NOT coming apart without breaking it. Its a long shot but does anyone know how the DIN cable is suppose to be wired?
I suppose i can just run jumper wires from one DIN to the other DIN until it starts working to figure it out but not sure if that can damage something sticking wires in the wrong DIN "holes".
Not electronically education but I also thought about poking around with a volt meter on the DIN supplying signal to the "slave" speaker but again not sure if I can blow something doing that. Any thoughts would be great.
JD
ABIT BH-6, Pentium III 500, 256 mb RAM, Nvidia MX420 Video Card,SB16 CT1770 SCSI, GUS David Larsson Clone, SCSI ZIP 100mb, SCSI TEAC CDROM, IDE Hitachi CDROM, IDE LS-120 Drive, 3.5 Floppy, Viewsonic PF790 Monitor (DOS6.22, Win98 SE)
Reply 1 of 11, by dominusprog
Find the ground pin and go from there. For example, if pin 2 is ground on both speakers, you'll have to connect the pin 1 to pin 1 and so on.
Reply 2 of 11, by JidaiGeki
I took apart some ACS450 speakers in Feb 24. They do have glue around the entire assembly, so I got it apart using a plastic spudger. It took a while as I had to go carefully.
The ACS500 is different to the 450 as it has Pro-Logic I think? Anyway, you can probably go pin-to-pin on those speaker connections as the wiring is unlikely to be complicated. I didn’t get photos of the DIN plug circuit but I do have a pic of the 450’s internal connector and wiring. To be 100% sure you will need to crack yours open though. Keep us posted, there isn’t much info out there on these speakers.
The attachment IMG_0107.jpeg is no longer available
The attachment IMG_0109.jpeg is no longer available
The attachment IMG_0097.jpeg is no longer available
The attachment IMG_0098.jpeg is no longer available
The attachment IMG_0099.jpeg is no longer available
Reply 3 of 11, by Doombringer4u2nv
Thank you for the pics. I know now I will not be dealing with any plastic clips. Looks like the "platforms" are what glued and holding it together.
JD
Reply 4 of 11, by Doombringer4u2nv
I I was able to get it apart. Unfortunately I broke the power pcb with the pry tool. I am posting a pic to show others that if you use a pry tool go up at least 2 inches from the base of the speakers to avoid doing what I did. It looks like the trace that I broke is a ground trace and I will just solder a jumper wire over the break.
The Dolby board is huge. I now know what two DIN pins go the the "lower" center speakers on the satellite . I will rewire my DIN wire and see what happens. Will post when I get it working or either blow it up . 🤣.
Reply 5 of 11, by tehdrewsus
Hello! First time posting... This thread in particular brought me here.
I just purchased a set of ACS500's with the ACS250 sub. they're... functional. But they're WAY more "used" condition than the seller let on, and although it doesn't blow me away, I can definitely smell tobacco/tar built up. I may make a restoration thread. Upon getting into them one of the wires is broken, which is odd to me. Is there a good way of getting the separator flaps out?
Reply 6 of 11, by Doombringer4u2nv
tehdrewsus wrote on 2025-01-15, 18:51:
The rear part of the "flaps" was glued with silicone. The front part looks like they used epoxy so no way of removing the entire flap but no need too anyway really.
Reply 7 of 11, by Doombringer4u2nv
Could you please put a ohm meter on both ends of the DIN cable and tell me what pins are what? Like is pin 1 on one side pin 1 on the other side and so forth. A standard MIDI DIN cable will no work with these speakers and I think they crossed a wire in the cable or something.
Reply 8 of 11, by tehdrewsus
Doombringer4u2nv wrote on 2025-01-18, 14:09:
After 25+ years, they came apart without too much of a fuss. I removed them so I could remove the speakers without cutting wires and having to re solder. on to more testing though. these don't work near as well as the seller let on... go figure.
Reply 9 of 11, by JidaiGeki
For what it's worth, I've tested the ACS450 speaker cable and it's wired straight through. While it's not impossible, I wonder if A-L would have created a special cable for the ACS500, given these were a mass produced speaker with common parts to the ACS400 and other sets. Certainly none of the pictured speaker interconnect cables in ACS500 sold listings have special markings. Hopefully tehdrewsus has a multimeter!
Reply 10 of 11, by Doombringer4u2nv
To finish the post. The DIN cable is pin to pin on the ACS 500. No crossover wires. The aftermarket replacement cable I was sent did have a cross as why it didn't work. I was sent the wrong cable and it cause the frustration.
Reply 11 of 11, by nali
dominusprog wrote on 2025-01-05, 05:32:
I know it's an old topic, but be careful with this.
Many amplifier are in a "bridge" configuration.
This mean the speaker is connected to 2 active pins of the amplifier component, out of phase 180 °C. Not between one active pin (via a capacitor) and the ground.
I've been playing with electronic for about 30 years, and I don't know any other way to identify pins other than opening the device and check inside.
IIRC, for some triphonic system like the ACS45-2, there's a 4 amplifiers component. 2 output are bridged for the bass, and 2 are used via a capacitor for the satellites. But it's something you can't guess, you have to open it and check.
