Reply 55720 of 57768, by AGP4LIfe?
- Member
G-X wrote on 2025-01-14, 21:31:AGP4LIfe? wrote on 2025-01-14, 16:09:Picked up this nice boxed Radeon 3850 AGP for just under 100$. Yea kinda spendy, but it's in really nice condition with the box and all accessories, including the case sticker!
Tested and works great 👍 I finally have the fastest agp card in the collection 😀Looks mint! Not cheap indeed (was lucky to have scored both of mine under 50, one boxed the other isn't) but yours looks like it was hardly ever used. Are you going to do anything cooling wise on the bridge chip? Most people suggest to add cooling but i haven't used mine yet except for some testing.
Yea its quite minty fresh, still even has some new electronics smell to it. 😁 It will mostly go on the wall, but I will run some Crysis on it using my FX-60 NF3 System first!
As far as the bridge chip , I am not too concerned about adding extra cooling to it. I'm sure if they engineered it to be used without a heat sink its probably just fine. Its also directly by my CPU cooler so it will have air running over it.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
