New forum suggestions/Feedback
Reply 560 of 623, by konc
Ozzuneoj wrote on 2025-01-10, 01:44:
I don't think any other website I go to overrides my cursor and I don't understand why this one does. Especially when it is a relatively minor change for some but could be overriding essential accessibility settings for others.
If this is of any help, Snover's words about the custom cursor are in (the middle of) this large post.
Reply 561 of 623, by Ozzuneoj
konc wrote on 2025-01-10, 08:18:
Thanks, I hadn't seen that before.
And, it's totally okay for the person designing the forum theme to do quirky things if they choose, but... he did mention that time would tell whether browsers would fix the website cursor scaling thing, so he may not have to do anything about it... but it is now a 5 years later. It seems unlikely that they are going to fix this, so it would be nice for those that have trouble with it to be able to just click a button in their site preferences.
The biggest thing for me is just the text selection cursor when using the old color scheme. It has white and black lines next to each other which become light gray on just about any display when you move the cursor. The text box background is close to light gray in the old color scheme, so the cursor becomes invisible when you move it. With the standard Windows 10 text cursor the color is inverted so it is always visible regardless of the background.
Reply 562 of 623, by GigAHerZ
The ugly part of disabling custom cursor here is that the "hand" cursor for links doesn't work anymore. Everything is the plain ordinary "arrow". Links are not links for whatever reason here.
This forum's front-end devs have spent extra time to make something worse. Extra time, i remind you...
EDIT: I used chatgpt based on the mentioned css adjustments in a referred post to create adblock custom rules. (i use uBlock Origin myself) Seems to work.
And kudos for that snippet - it actually overrides all links as well to have the "hand" symbol in proper places. From earlier i used a shorter snippet that just removed all custom cursors and made everything into an "arrow" pointer.
I went an extra step and added "text" cursor for ordinary text on the page as well. That override was missing from the original overrides.
vogons.org##:root:style(cursor: default !important;)
vogons.org##input:style(cursor: text !important;)
vogons.org##textarea:style(cursor: text !important;)
vogons.org##:link:style(cursor: pointer !important;)
vogons.org##:visited:style(cursor: pointer !important;)
vogons.org##label:style(cursor: pointer !important;)
vogons.org##select:style(cursor: pointer !important;)
vogons.org##[type=submit]:style(cursor: pointer !important;)
vogons.org##[type=button]:style(cursor: pointer !important;)
vogons.org##[type=file]:style(cursor: pointer !important;)
vogons.org##[type=radio]:style(cursor: pointer !important;)
vogons.org##[type=checkbox]:style(cursor: pointer !important;)
vogons.org##.alert_close:style(cursor: pointer !important;)
vogons.org##p:style(cursor: text !important;)
If somebody puts so much time and effort into custom cursors, why isn't there a checkbox in profile to enable/disable custom cursor? Then everybody can choose their preference and nobody would bring it up anymore.
Reply 563 of 623, by Ozzuneoj
GigAHerZ wrote on 2025-01-10, 11:03:
The ugly part of disabling custom cursor here is that the "hand" cursor for links doesn't work anymore. Everything is the plain […]
Oh my goodness, thank you! Yes, I forgot to mention that just blocking the cursors the other way would get rid of the finger-cursor for links. In my case, I had a uBlock rule already that blocked the arrow which meant that I would get a TEXT cursor when I hovered over links, which was pretty annoying too. I just pasted your code into uBlock Origin and everything is normal now.
I would totally use the Windows 95 cursors if the text cursor stood out better with the old school color scheme (just using the invert colors would do it) and the others worked basically normally, but I know that for others the lack of scaling is a much bigger problem.
Reply 564 of 623, by UCyborg
I copied the selector from the web page's CSS, so it should only undo what web page set. Didn't see the issue with links, cursor changed properly to hand here.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 566 of 623, by appiah4
BEEN_Nath_58 wrote on 2025-01-13, 14:56:
Can we have a tagging feature? Sometimes it could be necessary to notify a user to a thread for any purpose
I would like to second this request.
Reply 567 of 623, by vetz
appiah4 wrote on 2025-01-14, 08:38:
Actually me as well. I've been adding fake quotes from users to get around this previously.
Reply 568 of 623, by GigAHerZ
+1 on tagging users.
Some time ago i also proposed a feature of "Kudos" or "Appreciation". A positive-only rating system for posts.
For example, i would thank every post in List of Currently Free Games when a game is posted there.
Reply 569 of 623, by Bruninho
+1 on this. It's so simple to end the debate about the custom cursor.
JOBS, Steve.
Reply 570 of 623, by BEEN_Nath_58
GigAHerZ wrote on 2025-01-14, 09:48:
+1 on this, just came to report it myself
Reply 571 of 623, by H3nrik V!
I was recently banned for not having a reachable email address. It turned out to be a short glitch on my provider's server as I am still using the same email now. Could there be like an extra attempt some minutes or maybe hours later before banning? It can't be the only email server ever having a short glitch? 😀
Reply 572 of 623, by Robbbert
Same happened to me. I suddenly found myself banned for no apparent reason, although email was mentioned in the cryptic message. All attempts to email the admins was met with silence. So I gave up.
5 months later I decided to try signing on, and amazingly it worked. So luckily I was able to get back here.
Reply 573 of 623, by Robbbert
Just now I got a message from this forum to say I should press Ctrl Alt Delete and reboot my computer, that error 500 had occurred, and click here to go to the index page (which is where I had attempted to go to in the first place). What's going on?
(and it's not even April 1st - it's March 1st)
Reply 575 of 623, by BEEN_Nath_58
ldeveraux wrote on 2025-03-02, 12:56:
is there a way to hide posts? There's a user who I blocked, but still see their posts. I would like to not see them 😉
although I don't have any opinion here, what strange thing on VOGONS would turn away your eyes at that extent?😮
Reply 576 of 623, by ldeveraux
BEEN_Nath_58 wrote on 2025-03-02, 21:36:
Multiple posts from a user, none of whose topics interest me. I do this on reddit all the time, out of sight, out of mind.
Reply 577 of 623, by Nexxen
After asking for promotion of paid services my suggestion is to update the terms of use explicitly addressing the issue of promoting paid services.
It only happened once but with the "no selling" de facto policy, maybe it'd be better to put it there and have it crossed out.
If two members agree on whatever it should happen through messages, privately. It's legitimate and happens elsewhere all the time.
Again, this is not my forum, whatever is decided is fine. But some thought should be put on the matter.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 578 of 623, by Pierre32
When I click this to clear watched thread notifications, I think that should be all that's required.
18.73 KiB
The popup messages that follow are very unnecessary.
14.06 KiB
9.62 KiB
Reply 579 of 623, by Joseph_Joestar
I made a couple of edits to my older (retired) PC build threads today to delete some old images and then got this message:
You can only edit a limited number of posts at a time. Try again in 1 day, 22 hours, and 15 minutes.
Why am I not allowed to edit my own posts for 2 days?
