Retro 3D print topic
Reply 60 of 113, by douglar
Is it just me or do AGP cards have a sharper taper on the slot side?
Reply 61 of 113, by Veeb0rg
red_avatar wrote on 2024-12-10, 09:54:
I've designed a stackable box for floppies since I have hundreds of them and wanted a better way to store them than those old pl […]
I've designed a stackable box for floppies since I have hundreds of them and wanted a better way to store them than those old plastic boxes. This system allows unlimited stacking and uses relatively little filament:
If anyone wants the STL or 3MF lemme know.
Those look pretty nice, I'd be interested in the STL..
Reply 62 of 113, by douglar
"3DHoJor Matte PLA Filament 1.75mm" is a very nice beige
The attachment Photo Jan 17 2025, 3 21 35 PM.jpg is no longer available
Reply 63 of 113, by Lynxman
I make a lot of 3D printed stuff. I've designed several drive bays and cases. I've designed mostly ITX-cases for modern hardwware that resemple old Wedge computers but am working on an ATX case now for my P4 system.
Lots of free and paid things for sale on my Cults3D profile. Example: https://cults3d.com/en/3d-model/various/itx-s … case-tahustvedt
Reply 64 of 113, by Lynxman
My current ATX case project. Designed to be super compact and minimalist.
Reply 65 of 113, by Lynxman
I use eSUN PLA-Matte Light Khaki filament to match the old IBM grey. It's a perfect match.
Reply 66 of 113, by douglar
As I worked through the AGP & PCIE, I realized that:
  1. AGP & PCI cards have tabs for stands that work better than mounting on the contacts
  2. PCIE cards are often heavier cards that need better support or the mount points start breaking off
  3. Stands with big flat bases use a lot of plastic, are prone to misprint, & hard to lift from the printing pad
  4. Needed to improve support for double width cards
So here's the new batch. Might be a little tweaking over the next few days, but pretty much done at this point:
ISA/VLB Card Stand:
https://www.tinkercad.com/things/16pMpNOqcl8- … d-stand-30-gram
https://www.thingiverse.com/thing:6919767
The attachment ISA_VLB.png is no longer available
PCI Card Stand:
https://www.tinkercad.com/things/iYex3uzUq3u- … d-stand-23-gram
https://www.thingiverse.com/thing:6919775
The attachment PCI.png is no longer available
AGP Card:
https://www.tinkercad.com/things/5mAiN2849sr- … d-stand-25-gram
https://www.thingiverse.com/thing:6919778
The attachment AGP.png is no longer available
PCIE Card Stand:
https://www.tinkercad.com/things/gHMSxvgj37Y- … d-stand-36-gram
https://www.thingiverse.com/thing:6919789
The attachment pcie.png is no longer available
edit -- Lol! First cards I tried to put in a PCI rack were a sawed off PCI sound card that wa 4 mm shorter and an ASUS sound riser that looks like PCI if you are dyslexic. Looks like I need to spin another batch.
Reply 67 of 113, by wbahnassi
I'll share my post for Dell Optiplex 466 drive rails:
Dell OptiPlex 466LE 5.25" drive rails
Full res photos are in the original thread
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 68 of 113, by Major Jackyl
wbahnassi wrote on 2025-01-20, 14:13:
Nice! Those look like they'll fit my Optiplex GM5100, too. I already made some, but I'll confirm that these probably fit a LOT of Optiplex(s) from that era.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 69 of 113, by wbahnassi
Glad to hear that Major Jackyl 👍
Reply 71 of 113, by danieljm
Got a 3D printer for Christmas and just learning how to design stuff. I think I've seen something like this before, but I can't find anything now, so I tried to design something myself. Since I'm new to all of this, I assume I could have done things better and I'm open to suggestions.
The attachment IMG_1406.JPEG is no longer available
The attachment IMG_1407.JPEG is no longer available
The attachment IMG_1409.JPEG is no longer available
It's specifically for the Startech IDE2SAT2. I sized the holes on the sides for M3 heat set inserts that are 4mm deep. And if anyone makes one, be careful when removing the supports from the clips. I wanted them to be thin enough to flex for getting the adapter in, but I'd guess they could snap relatively easily. It probably looks like the drive sticks out a lot, but I think it's about right for trying to get a proper grip on it to pull it out.
But yeah, I'd love to hear what people think.
Oh, and I followed Lnyxman's advice and got the eSUN matte PLA Light Khaki, and it's just about perfect. It would be nice if it wasn't quite so matte, but it's a minor thing.
The attachment Startech IDE2SAT2 5.25 drive bay.zip is no longer available
Reply 72 of 113, by Major Jackyl
danieljm wrote on 2025-01-26, 05:11:
Got a 3D printer for Christmas and just learning how to design stuff. I think I've seen something like this before, but I can't […]
I like it. I would make it deeper, to use the rear screw holes and make the plane the board is on go all the way across. Going to print one of these guys later. I finally got printer fuel (been WEEKS)
Daily Units:
Reply 73 of 113, by douglar
I got one too!
I like the brass fittings, that's really nice. The honeycomb bottom is nice.
The whole thing will be a little more stable if you can extend it. I usually don't make the side walls so thick. I do stuff like this:
https://www.tinkercad.com/things/5LkwQCvuvwb- … -and-full-rails
I used to go to the public library to print and they had a smooth platform printer. With that one, I could get a high gloss plate if I printed face down:
https://www.tinkercad.com/things/1J83BClQEr9-35-bay-cover
Reply 74 of 113, by douglar
Introducing the Everything Tray!!!!
https://www.tinkercad.com/things/ixiW4imXIO5- … g-rack-54-grams
It is a little heavier, but also a little sturdier, and card don't fall into the middle as much.
It takes up to 8 cards that can be any combination of ISA, VLB, PCI, AGP, or PCI-E
It does AGP, ISA, PCI-E really well.
The attachment Good Rack.png is no longer available
VLB cards that are missing the center can be a little loose. PCI can be a little loose.
The attachment Good Rack 2.png is no longer available
One of the ISA slots is modified to handle those wacky backwards pci audio risers.
Does reasonable well on old cards with strange or kissing brackets.
The attachment Good Rack 3.png is no longer available
Reply 75 of 113, by Lynxman
H3nrik V! wrote on 2024-12-03, 07:12:
Made a 5.25" bezel to house 2 USB connectors (Bulgin PX0843/a which can be separated from the big, round housing and plug in her […]
Made a 5.25" bezel to house 2 USB connectors (Bulgin PX0843/a which can be separated from the big, round housing and plug in here)
Anyone in luck finding some beige PLA filament? Or is painting still the way to go.
I'll share both STL and Fusion files, if anybody wants (it could be ½-1 mm narrower, I guess - or it may be my printer not being trimmed properly.
https://www.bulgin.com/us/products/front-pane … -connector.html
"eSUN PLA-Matte Light Khaki" is as good as indistinguishable from the old computer grey. To my eyes it's a perfect match. Some cases are brighter or darker or hav yellowed but it's extremely close to my original IBM and my Aopen case shown here (which is slightly yellowed at the top only).
The 5-1/4 bays and the little 3-1/2 hard drive bay under the floppy are printed with this material:
Reply 76 of 113, by Yoghoo
Lynxman wrote on 2025-01-27, 14:14:
It indeed is. Using this filament already for some time. Created a couple 5.25" bays a couple of days ago for some zip drives. Still need to install them in two pc's but as can be seen from the photo it's an exact match. If you use a fine textured plate and print face down you get the same texture as the zip drive itself.
Reply 77 of 113, by red_avatar
Sweet, I ordered 2kg. eSun isn't the best filament but colour trumps quality in this case.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 78 of 113, by danieljm
Major Jackyl wrote on 2025-01-26, 05:42:
douglar wrote on 2025-01-27, 00:01:
I got one too! […]
I got one too!
Thanks for the suggestions guys. Here's an update. Let me know if you like it better.
The attachment Star tech drive bay longer.png is no longer available
The attachment Startech IDE2SAT2 5.25 drive bay longer.zip is no longer available
Reply 79 of 113, by douglar
danieljm wrote on 2025-01-28, 05:12:
That looks more sturdy. If you are inserting and removing drives, the extra length and screw points will help keep it in place.
After you do a couple, you might start finding ways to reduce the weight without losing strength or function.
