TVGA 8800CS BIOS
First post, by MaLLy_R
Dear Great Vogons, please help.
I just bricked BIOS in my 8bit ISA Trident card. http://mally.tim.com.pl/8bit_isa/VGA_SV ... 0CS(!).jpg
IC is standard 27c256, all i can find is 2x 128kb for ISA 16bit ISA (and i don't know how combine them and will it work.)
Does Any of you have BIOS for this card?
Please help!
MIDI. I like MIDI... A lot! (Also stuck in 8bit PC era)
Reply 2 of 13, by MaLLy_R
Karbist wrote on 2025-01-16, 11:27:
You can try the bios files from vgamuseum.info https://www.vgamuseum.info/index.php/componen … dent-tvga8800cs […]
they are padded to fit in a 512kb rom, here's the 256kb version:
The attachment tvga8800cs.rar is no longer available
Thank You very much.
But will it work on 8Bit ISA card?
Reply 3 of 13, by waterbeesje
Basically the bios wil communicate with the system Board and graphical processor without looking at the 16 bit part. Even moest 16 bit cards wil work without Jake in any 8 bit slot. So I don't think it will be a problem at all.
Stuck at 10MHz...
Reply 4 of 13, by Grzyb
I have such a card, too - here's the dump from NSSI...
Reply 5 of 13, by MaLLy_R
Grzyb wrote on 2025-01-16, 22:39:
THANK YOU! Its working again!
(Wiszę ci piwo.)
I have another question to you: do you have jumper manual to this card?
I no matter what i set i doesn’t work with my monochrome TTL monitor.
Reply 6 of 13, by Grzyb
MaLLy_R wrote on 2025-01-17, 09:20:
Not quite, but these may be helpful:
https://retronn.de/ftp/driver/Trident/8800CS/ … aphics_Card.pdf
https://arvutimuuseum.ee/th99/v/U-Z/50080.htm
Reply 7 of 13, by MaLLy_R
Grzyb wrote on 2025-01-17, 09:48:
I tried those. No sync on TTL monitor.
Reply 8 of 13, by Grzyb
Can't get it to work with my "Hercules" (I believe it's actually dual-sync, 15 and 18 kHz) monitor, either.
Normal VGA operation is:
all DIP switches ON
JP2 2-3
First, I toggled DIP switches 1 and 2.
Second, I toggled JP2 to 1-2.
In both cases, the same result: right after power-on/reset I can see the BIOS screen, but it's distorted (wrong frequencies?), and a moment later it goes all black.
Reply 9 of 13, by MaLLy_R
Many thanks for checking it on your card.
Now i know its not just my card, i got similar symptoms to yours.
Reply 10 of 13, by Grzyb
BTW: do you, by any chance, have the software for that card - or for any 8800-series card?
I'm especially interested in the SVM.EXE utility - described in that PDF manual.
It's easily found for 8900 and 9000 chips, but can't find any version compatible with 8800...
Reply 11 of 13, by MaLLy_R
Sorry, i got no software nor drivers.
I wish had it too especially win 3.0 driver.
Reply 12 of 13, by ricardo.contieri
Hi everyone!
I had uploaded mine for a Brazilian clone version of the TVGA 8800CS here:
https://datassette.org/softwares/br-brasil-fi … cgv-tvga-8800cs
This version, signed by MICROTEC has a different character set, with a sans-serif font. I personally like it a lot. It is dated as of 02/06/89, v 1.0, model CGV - V.
On the other hand, I'm looking for an updated version for the BIOS of this board (higher than the 1.2, btw). There is a VESA driver for it that "updates" it, but I'd like to have it on the eproms directly.
Any ideas?
Thanks!
RC
Reply 13 of 13, by Grzyb
ricardo.contieri wrote on 2025-02-22, 14:01:
I've never seen an 8800 card with VBE in ROM.
Most likely there's no such a thing - those cards are from the 80s, when VBE wasn't a thing yet.
