First post, by Jackhead
This time its based on the first Asus Maximus Formula sockel 775 X38 Mainboard.
The option using time correct case was gone with the decision of use an custom watercooling system.
So choosing a modern case i find the fractal north xl in black interesting. The XL Version can handle my radiator i want to use. And maybe more if i need..
When i was looking for a GPU i found a little nice setup of two 7950 GX2, both with an waterblock installed. Still have one with the air coolers.
It should be my new XP pc up to DX9.
The Asus has two full x16 pcie slots what makes it interesting for me to try the two GX2. Will see how this work out at the end.. One should be also totaly fine.
I just started the build, so it will be a buildlog here. All the parts will come in next days..
Parts List so far:
Board: Asus Maximus Formula X38 LGA775 Rev 1.03
CPU: Q9550 - cooled with cuplex kryos HF
RAM: GeIL EVO One 1066 CL5-5-5-15 - 2x 2GB
GPU: 2x Nvidia Geforce 7950 GX2 - quad SLI
SPU: Asus Supreme2 FX pcie x1
PSU: 850W be quite! straight Power 11 CM
Case: Fractal North XL black
Custom water cooling from Aquacomputer parts
Lets start with some pictures from the parts i got so far:
Its 360 radiator from aquacomputer i had for some time. The kryos is waiting for a adapter kit to fit the 775 socket.
The attachment GgIg46_XkAA2_UX.jpg is no longer available
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - MPU-401AT with YucatanFX / Roland CM64
Win98SE: Asus XG DLS 1x SL4XY - SG Voodoo 5 6000 PCI - 1GB RAM ECC- Audigy 2 ZS - MX300
Reply 1 of 19, by RetroPCCupboard
Interesting build. Though I think perhaps the Pentium 4 will be a bottleneck?
Reply 2 of 19, by Jackhead
Most likely yes, but we will see what the prescott is able to.
Reply 3 of 19, by agent_x007
Looks amazing.
You do know X38 will need "hacked" drivers to work in QuadSLI (since it's not officially supported), right ?
Single 7950 GX2 will work in SLI no problem though.
What sound card/hard drive and OS you plan to use ?
Reply 4 of 19, by Jackhead
agent_x007 wrote on 2025-01-04, 14:09:
Looks amazing. You do know X38 will need "hacked" drivers to work in QuadSLI (since it's not officially supported), right ? Sing […]
Looks amazing.
I was thinking that quad SLI is just above XP a problem. Did you have a link to that hacked drivers?
Still not sure i use two of them because my CPU bottleneck, but will see.
If i really go quad sli, i think i cant use a soundboard, because the pcie slots shared with the pci ones.
If not i would go with a SB XFI Elite Pro
GPUs arrived today:
The attachment Ggc5bKmXkAAw-1E.jpg is no longer available
Need to replace the thermal paste first, and also add putty for the VRams.
Reply 5 of 19, by agent_x007
Original QuadSLI was invented to work on WinXP (Quad SLI works on pre-DX10 stuff, which You have 😀)
Only Kepler generation and newer doesn't allow SLI under XP.
I don't have a link to a driver for you sadly.
But there may be a tool that hacks driver (if it's supported), to get SLI working on early Intel X-series chipsets, IIRC.
Again this is only something that I remember being "a thing", not sure if it's still available.
Reply 6 of 19, by Jackhead
agent_x007 wrote on 2025-01-04, 19:51:
Original QuadSLI was invented to work on WinXP (Quad SLI works on pre-DX10 stuff, which You have :)) Only Kepler generation and […]
good to know thanks! Found the drivers from Phil: https://www.philscomputerlab.com/sli-on-chine … therboards.html
Reply 7 of 19, by PC-Engineer
Quad sli unfortunately doesn't work very well, even under Windows XP and Windows 7 with NVIDIA chipset. I have experimented a lot with it (two of 7950GX2) and had the same experiences as everyone else before. Newer drivers didn‘t made it much better.
https://www.computerbase.de/2006-08/test-nvid … 0-gx2-quad-sli/
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 8 of 19, by Jackhead
Some more work done. Installed the radiator with 3 slim noctuas.
Unfortnatly the P4 CPU i got was garbage so i switched to a Q9550 instead.
Installed the waterblock on the MB.
The attachment IMG_7905.JPG is no longer available
The attachment IMG_7906.JPG is no longer available
The attachment IMG_E7907.JPG is no longer available
Reply 9 of 19, by Jackhead
So anything ready now. The bad cooler design got me to use the second card on air for testing.
Im using driver 275.33 and tryed all the SLI patches with no luck activating SLI so far. Is there a hacked bios or driver im missing for X38??
The attachment GhBvvT6WEAAmp7h.jpg is no longer available
The attachment GhBvvT7WcAATU7U.jpg is no longer available
Reply 10 of 19, by Jackhead
got it working with SLIpatch 1.5 and Nvidia driver 93.81 !
The attachment IMG_7921.jpeg is no longer available
3dmark03 , with fsb400 3,4GHz default settings in Quad SLI 33785 points, Single card scores 20500
The attachment IMG_7924.jpeg is no longer available
Reply 11 of 19, by H3nrik V!
Awesome!
Reply 12 of 19, by agent_x007
I think QuadSLI isn't working correctly ?
Why PCI-e speed is at x8 1.1, instead of x16 1.1 ?
Here's an underclocked 7900 GTX single card (600/1400) + OC'ed X3370 CPU on P45 DDR3 platform.
25k in 3DMark 2003 :
The attachment 3DMark 03.PNG is no longer available
6456 in 3DMark 06 :
The attachment 3DMark 06.PNG is no longer available
Reply 13 of 19, by H3nrik V!
agent_x007 wrote on 2025-01-12, 23:44:
X38 and X48 chipset has 2x PCIe 16 channels, I guess that quad SLI uses 4 PCIe slots (all though it's only 2 physical cards) thus only 8x available for each, wheres the single 7900GTX only uses one slot, having the full x16 available?
Reply 14 of 19, by Jackhead
i also notice that x8. But it makes sense that the 7950gx2 each board layer use x8.
Thanks for the compare with the 7900gtx. For a "non SlI" X38 board i think the quad SLI scales pretty good!
I still need to test games because i need a soundcard. But i ordered that X1 supreme FX2 card for the dedicated slot, because no other free slot available.
I think first Game i will test is Doom3, because i want use the system as early XP DX9 mashine (2002-2006) running on high resolutions.
Reply 15 of 19, by Kampfkoloss
Nice! What a beast of a machine. I like to pair my Q9550 with a radeon HD 7970 or a R9 290, I'm not so much a fan of NV-SLI microstuttering and it's more efficient than a SLI. How did you manage to get rid of the stuttering? Or is it not that noticable?
(\__/) This is Bunny. Copy and paste Bunny into your
(=’.’=) signature to help him gain world domination!
(“)_(“)
Reply 16 of 19, by chrismeyer6
Man that system is awesome. Definitely love the water cooling. Well done my friend!
Reply 17 of 19, by Jackhead
I did not played much so far. But i did change some stuff. First i installed a supreme2 Sound card. Works great with the quad SLI.
For the TFT i used a Asus monitor that support 1600x1200. Its that Art RGB line. Really good TFT..
The Fan Control from the MB is really bad, so i switched to a hardware solution inside to setup the voltage for the fans.
Doom3 runs on max settings 1600x1200 and 8x AA on solid 60fps with Quad SLI enabled. I think doom3 is capped on 60fps. But when i go up to 16x AA fps drops to 25 . But even with 8xAA it looks really good and performance is great!
I run FSB400 with 1066 Ram and CPU 3,4GHz.
Pretty happy with the setup 😀
It fits perfectly after my Voodoo5 setup and before my win Vista 32bit titan sli stuff.
Reply 18 of 19, by dr_st
Jackhead wrote on 2025-01-22, 12:12:
Ah, those were the days. 😀 My QX9650 Vista desktop spent most of its useful life running at the same RAM and FSB speeds (effective CPU speed 3.6GHz). It was remarkably stable and cool with the default overclock settings on the ASUS P5Q PRo. But eventually the board gave out, and a few years later the next one. Now I don't bother overclocking it, since it's already kinda unstable...
Reply 19 of 19, by Jackhead
I also want to say something to the case, if you have hot GPUs the fractal cases did a really good job on air cooling.
I testet also the Torrent from Fractal. The combi with 3x140 front fans, and open mesh on the back did work great!
dr_st wrote on 2025-01-22, 13:29:
Maybe because the NB SB overheat? They are really a problem what i see. Adding a fan on some point did help, but its still the hottest point in the build.
