First post, by ApostolCV
- Newbie
Hello there 😀
For some time now I have owned two strange Slot-kets.
When i get first and try to use it i came to the conclusion that it was broken. System with it do no POST .
But when i get second with same issue i try to find what can be wrong .
So i take multimiter and some old documentation with SLOT 1 and Socket 370 pinout.
Downwards you can see photo with 3-x Slot-kets : were market by me like A,B,C.
Slot-kets B,C do not work/post . Slot-ket A is full-workerd with Support PPGA 370 CPU (Mendocino) , Coppermine (P3/Celeron), VIA CPUs.
[attachment=-1]frontS1.jpg[/attachment]
With some measurement i discovered that at slotkets "B,C" voltage at socket pin AN11 that should be VTT 1.5V is 2.0V.
On slotket "A" that work it's correct and equal 1.5V.
I chech mottherboard ...
In both cases, the motherboard outputs 1.5V on pin A1 of the Slot 1 connector. A1 is VTT voltage.
Does anyone have any thoughts about this? Or have you encountered something similar?
